Seeking help in setting up a Ramdisk by using 'ImDisk'
    South Asia
    Windows 8.1 Enterprise 64-bit (6.3, Build 9600)
    I rarely upgrade my notebooks since Iíve been setting my hands on this HPís ENVY TouchSmart 15 Series Notebook which came with the following specifications:
    - Intel 4th Gen Core i7-4702MQ Processor with 6MB Cache
    - Samsungís 8192MB DDR3 SD RAM
    - 1TB 5400 RPM Hard Drive
    - ADATAís 24GB SSD Acceleration Cache
    - 15.6Ē Diagonal Full HD BrightView LED Display with 1920x1080 Resolution
    - Touchscreen, Multitouch enabled
    - Intel HD Graphics 4600
    - NVIDIA GeForce GT 750M with 4GB DDR5 RAM
    - Windows 8.1 RT (x64 Edition)
    When Iíve explored the PC through factory installed operating system in it, Iíve been disappointed to see the multiple RAID Volume Settings between HDD and SSD. Anyhow; Iíve ignored the pre-installed settings and then tested the custom applications one by one in order to verify the performance.
    A considerable amount of latency and slow performance Iíve so far faced while operating my Outlook PST resource which is of 28GB of size. Because of the sensitivity and importance of resource Iíve to keep with me most of the time, Iíve thus decided to extend the amount of RAM available with the notebook as well as to replace the 1TB HD with Kingstonís 480GB SSD.
    So here is current standing available with us:
    - Kingstonís 16GB DDR3 SD RAM
    - Kingstonís 480GB Solid State Drive
    - Windows 8.1 Enterprise (x64 Edition)
    At this stage Iíve allocated 19900-22800 MB of paging file on ADATAís 24GB SSD and donít wish to use its meagre amount of storage space for any other purpose. Whereas the system managing paging file already existed on Kingstonís 480GB SSD has been removed.
    What I now wish to do is to fully configure ADATAís 24GB SSD as Ramdisk as well as to manage the paging file (your suggestible size) on the same.
    As Iíve never experienced this cherished ĎImDiskí before and Iím little confused in configuring the optimal settings as per my wishes.
    As far as applications are concerned, I use Adobe Photoshop, Microsoftís Expression Web, PowerPoint, Visio and Outlook simultaneously.
    Iíll highly appreciate your expert opinion in this regard.
    South Asia
    So anyone suggest me to go at some other forum for finding an applicable solution?
    Windows 10 Pro Prieview x64
    A RAM disk is as the name suggests a virtual disk that exists in RAM. You can't configure it to use a disk (although some products let you back up your RAM disk to disk). There is no evidence that using a RAM disk will improve your performance as you would be setting aside a portion of your RAM for a specific purpose therefore leaving you with less for general use which will increase paging and decrease performance.
    Memory management in Windows 8 is very efficient.
    You will see a big increase in performance by replacing your HDD with SDD and doubling your RAM. I would suggest that you do nothing with RAM disk or your paging file. Most likely your small SSD will be slower than your large one so putting it on there will decrease performance. Start of by leaving the paging file system managed and see how your peak commit charge is under normal use - see here Blogs - Mark's Blog - Site Home - TechNet Blogs
    South Asia
    Quote Originally Posted by adamf View Post
    Thank you so much for your prompt response. Yes; I've misunderstood previously about the RAM disk and now leaving the settings intact as per your recommendations.
Ramdisk Software? in Software and Apps
hey guys, I need recommendations on the best latest ramdisk software.. i was using Primo Ramdisk but it was from like 2012 or something.. anybody use/know the latest greatest ramdisk software to make ramdisks? I have 16gigs of ram and windows only uses 3 right now.. thanks
%appdata% on ramdisk in Performance & Maintenance
hi Everyone, so I'm on 8.1 and just like previously on 7 and XP and before that, using ramdisk's currently I have MSI laptop with 16GB or RAM so for past two months I've been using three separate ramdisk mounted with softperfect ramdisk, one of them for temp files which has no image saving...
Chrome running from ramdisk? not exactly in Performance & Maintenance
so I have been trying to use ramdisk's on my new laptop GS70, I've been using them for years with excellent results so obviously I got one taking care of temp variables in windows and other temporary files, this one is not saved to an image file then I have two more both of them are saved to...
Or do I have to wait till they gets updated to support 8.1?
Constant DRIVER_POWER_STATE_FAILURE 9f at hibernation while using pagefile on RAMdisk Windows 8.1 Pro (32-bit) RAM = 10 GB When the DRIVER_POWER_STATE_FAILURE 9f on hibernation started, I wasnít sure about the culprit, because I had made several changes on my computer. One was using...
My parents bought a PC last year running W8. I set up there talktalk E mail accounts in the W8 Native E mail client from the Mail tile at the start screen without any problem. All worked fine until recently when in order to download an app they had to register an Outlook E Mail address. Not sure...
More uses for Ramdisk? in Performance & Maintenance
I'm running Windows 8.1 on a desktop with 8GB of ram. I've created a 2GB Ramdisk, (SoftPerfect) and have updated my system environment variables so that all temporary files are placed on the Ramdisk. I've also set a symbolic link so that my Chrome browser cache uses the Ramdisk. I've done this to...
