Need help! Boot problem!
    Need help! Slow boot after HDD crapped out.
    My HDD recently crapped out (the CoD) so I need to buy a new one, but I am already having an issue.
    I have my OS on an SSD, but ever since the HDD crapped out it is taking longer to boot. It used to take just seconds, but now it is taking 15 seconds or so, which while not very long, is still too long compared to what it used to be.
    Once I hit the screen with the blue Windows logo, the circle goes around a few times, where as before it would go a full turn and then maybe a half turn.
    I have Windows 8.1. Before the HDD crapped out, it wasn't a problem. The HDD still functions, but it is way too slow to be useable and will probably fully crap out soon. If I leave it plugged in, it takes longer than this to boot (the situation I am describing is with the HDD completely removed (unplugged)).
    When I installed the OS, I think I had both drives plugged in, but I cannot remember for sure. I installed the OS just a month ago though.
    I need help fixing this or to know why it is suddenly happening after the HDD crapped out.
    Thanks.
    I think I fixed it.
    I initially tried easyBCD, but that didn't work and I ended up deleting my Boot Menu. I created a new one and selected "Skip the boot menu" (is that OK?) because it kept giving me an option to select Windows 8 at startup.
    I fixed the slow boot times by using my installation USB media and running a command prompt and then running bootrec.exe /fixmbr and it boots normally now, as fast as it used to from what I can tell.
Boot problem with win 8.1 in General Support
Hello all, I am having problems booting my computer ever since I manually removed a DVD from the drive. It boots if I turn off the comp and then insert DVD but even them it takes like 10 min to boot. DVD was just a movie no software or os. Not sure how to return system boot to it's original state....
Corrupt Boot Problem in General Support
I'll try to keep this short as possible. I bought parts to build a new PC. It has an SSD so it'll boot fast, and boot fast it did. Unfortunately, something happened a few days later (boot got corrupt someway or another) and I got this message. 48042 So I go about my way to restore Windows....
Solved Dual Boot Problem No. 2 in Installation & Setup
1. Windows 7 on first drive 2. Windows 8 on second drive 3. Manually swapped drives by unhooking cable and plugging it into whichever I wanted to boot. 4. WD MyBook worked fine as long as I swapped the individual drives around. Then . . . 5. I partitioned the Windows 7 drive and put...
Solved Boot problem in BSOD Crashes and Debugging
I have Windows 8 Enterprise x64 installed on my laptop (HP Compaq Presario CQ61-345SQ) and since recently I have been experiencing booting problems like, when I start the PC Windows doesn't load at - I see only the logo and that's it, no circulating dots to indicate loading, nothing. When that...
Windows 8 Boot Problem in Installation & Setup
i decided windows 8 was better and i should delete windows 7(after i backed up important files) but i when i tried to format it without uninstalling windows first(that was dumb) windows 8 didnt boot.I put in the installation disc of win 8 and clicked repair.Now it boots but when i open the...
Solved Win 8 boot problem. in Installation & Setup
I installed Win 8 on a spare computer the had Win 7 on it. I could shut it down & restart it several times using my password from Win 7 It worked beautiful, Then suddenly a new Starup Screen showed up with the vertical slide & the screen showed this; My full Name under it my correct Email...
I installed Win 8 on a spare computer the had Win 7 on it. I could shut it down & restart it several times using my password from Win 7 It worked beautiful, Then suddenly a new Starup Screen shoed up with the vertical slide & stated My full Name under it my correct Email Address & under...
