Solved stuttering mouse and lag help
TonyB
So i have done everything i can think of to fix this even re-installing mouse software, but for some reason not all the time i will get mouse lag and stutter were i will move the mouse but the pointer barely moves on my screen, is there a fix for this? someone help please.
    Myself
    MSI Z77A-G45
    8 gigs
    PNY GeForce GTX 660 Ti
    onboard
    Samsung Sync Master s27B550
    1080p
    Antec NeoECO 620 watt
    custom case
    Fans
    steelseries apex
    stellseris sensel
    Unknowen
    Google chrome
    Norton 360 from comcast
Brand, model and wired or wireless would be helpful to help you. Wireless could be getting a disturbance from something else, i have a Logitech M570 trackball mouse which has a USB receiver gave me same type of issue when receiver was plugged into back USB port. Move it to a different place.
Need as you may know to periodically clean it, could also cause this, dirty contacts, dust. Any new updates for this mouse ? Try without software see how it works ?
    Windows 10 Pro 64bit
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    AZZA Cosmas Black Gaming Case
    84mbps /94mbps
    Norton Security 2015
SteelSeries Sensei wired mouse product number 62150 rating 5vdc 200ma
    Myself
    MSI Z77A-G45
    8 gigs
    onboard
    1080p
    custom case
    Fans
    steelseries apex
    stellseris sensel
    Unknowen
    Google chrome
See this is wired and a gaming mouse. This happen to be occurring in games only ?
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Nope it also does it in windows as well i have not notes it in games.
    Myself
    MSI Z77A-G45
    8 gigs
    onboard
    1080p
    custom case
    Fans
    steelseries apex
    stellseris sensel
    Unknowen
    Google chrome
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Seems to be talk about driver software for this mouse a lot, mostly in games because it is a gaming mouse. I would suggest to try it without the drivers and software. How long has this been going on ? How long have you had this mouse ?
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
just started the last few days i did just update the software today so maybe that will fix it but time will tell its kind of a sporadic issue.
    Myself
    MSI Z77A-G45
    8 gigs
    onboard
    1080p
    custom case
    Fans
    steelseries apex
    stellseris sensel
    Unknowen
    Google chrome
I looked i have it installed already i wonder what else it could be whats wired are all mice usb 1.1?? i have it in my usb 2.0 port as well as my keyboard and they both report usb 1.1 with my diagnostics software, i tested the usb port by unplugging the mouse and plugging in a usb 2.0 jump drive and it says usb 2.0 but when i plug my mouse and or keyboard back in they say usb 1.1 is that normal?
    Myself
    MSI Z77A-G45
    8 gigs
    onboard
    1080p
    custom case
    Fans
    steelseries apex
    stellseris sensel
    Unknowen
    Google chrome
Usb 1.1 is before usb 2.0 . You are saying have mouse and keyboard plugged into USB 2.0 ports in back PC but show 1.1 ?
Possible need to update USB drivers for Universal Serial Bus Controller. How old is PC ? Doesn't seem old from your PC specs.
Look here in one of the paragraphs Resolving USB Speed Issues, "This Device Can Perform Faster" Error
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Also look for chipset driver updates check manufacturer site of your motherboard. Even for any other updates.
Using a USB Hub ? Possible have USB 1.1 and 2.0 on system.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
All usb 2.0 and chip set is updated all ready did that last month with latest one, its only the keyboard and mouse that show this i can unplug the keyboard and plug in a usb 2.0 thumb drive and it shows usb 2.0. but keyboard show usb 1.1 as well as mouse maybe its suppose to be like this. I don't get any error about faster or nothing. as they are usb 2.0 ports, it even shows this when i take the keyboard and plug it into a usb 3.0 port it reverts to usb 1.1 as well as the mouse.
    Myself
    MSI Z77A-G45
    8 gigs
    onboard
    1080p
    custom case
    Fans
    steelseries apex
    stellseris sensel
    Unknowen
    Google chrome
O.K., no problems with keyboard then ? Still try to narrow it down to the mouse software drivers, by removing them see how it works with Windows 8 Drivers as said before. Seems as though when you just updated it this is when issue occurred.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Nope keyboard works a ok? so far mouse seems ok since i updated its software, still trying to figure out why it would identify as usb 1.1 when everything else i plug in to the same ports says usb 2.0, is wired but maybe they are designed like this, i cant imagine it though as there less than a month old. The keyboard does have a hub in it maybe that is it? but it seems to identify my usb 2.0 stuff to though.
    Myself
    MSI Z77A-G45
    8 gigs
    onboard
    1080p
    custom case
    Fans
    steelseries apex
    stellseris sensel
    Unknowen
    Google chrome
Alright i had this confused, i thought either you never tried to update the software or this happened after you updated the software, but i see now you had just updated the software and it seems fine, that's good to hear. Post back to let us know how it works.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
Where are you seeing it show as USB 1.1 ? And could be right that this is just the way this keyboard and mouse work as 1.1.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
OH PC Doctor USB port test says that my keyboard and mouse are running USB 1.1 Full Speed. and other devices are usb 3.0 super speed and usb 2.0 high speed. But like i said i can unplug the keyboard and the mouse and plug a usb 2.0 thumb drive in and the ports are usb 2.0.
    Myself
    MSI Z77A-G45
    8 gigs
    onboard
    1080p
    custom case
    Fans
    steelseries apex
    stellseris sensel
    Unknowen
    Google chrome
Not familiar with this program, does seem odd that it is running at USB 1.1 speed. Yes, seeing as thumb drive is working in same port as 2.0 speed.
Looking through specs of mouse i do not see where it tells me if it is USB 2.0 or 1.1 even 3.0 , figure most products are USB 2.0 or 3.0 capable these days.
This is the new drivers software you said you put it in and it works fine now,
SteelSeries Engine for Windows
OS: Win XP, Win Vista, Win 7, Win 8, Win 8.1 (32/64 bit bit).
Region: INT. Version: 2.9.2014.1. Released: 2014-10-13
Download (51.7 MB)
Also saw a firmware up dates states this,
Updated firmware for Sensei (v252) and MLG Sensei (v519) to address USB 3.0 issue for UEFI
Firmware Update Tool
Region: EN. Version: 1.27.0.0. Released: 2014-10-13
Download (3.9 MB)
Release notes
Release notes:
SteelSeries Firmware Update Tool 1.27.0.0
Released: October 13, 2014
Did you ever try this firmware update ?
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
yes thats correct i also updated software on keyboard so i have two different ones as the keyboard runs steelseries engine 3.0 now. but mouse is still that one. I cant for the like of me figure it out as well very strange in deed. this is pc doctor its installed by default and is one of the only few programs i kept from alienware dell. PC-Doctor Computer & Android Hardware Diagnostic Software Tools, PC Repair Kits yes it auto updates the firmware when you install the new software its the nice thing about steelseries.
    Myself
    MSI Z77A-G45
    8 gigs
    onboard
    1080p
    custom case
    Fans
    steelseries apex
    stellseris sensel
    Unknowen
    Google chrome
Well firmware update was my last guess for mouse as issue with USB. Although i do not feel may be software of these components causing that issue. You did say lag and stutter on mouse went away with software update ?
And other devices plugged into same port register as USB 2.0, because my other thought was Drivers for USB Serial Bus Controllers and or chipset drivers which you said were recently updated.
Not sure if this is way it is suppose to work, the mouse, from research at SteelSeries it does not specify anything related, just saying it's USB, not which type ( 2.0, 1.1, 3.0) , the Firmware update stated it fixed issues with USB 3.0 which is odd to say it would only be USB 1.1, but on UEFI.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
