Help, Laptop will not turn on
    Okay so I have got an Asus Vivobook S550CA Laptop and it came installed with windows 8 - Specs
    CPU: Intel Core i5 -3337U Mobile
    GPU: Nvidia Geforce 635m 2gb DDR3 + Intel HD Graphics
    RAM: 8gb
    When I was just doing work on my laptop, It just shut down. Even when the charger is in, no lights are shown not even the charging one
    • I attempted to turn it on by pressing the power button... Nothing happens
    • I then tried Removing the battery and plugging the AC in - then turning on, Nothing happens
    • tried removing AC + Battery, Pressing Power for 60 seconds and pluging ac in before turning on again - Didnt work
    I would really appreciate if someone could help me
    Did you check voltage on the adapter ? but most likely something died on the MB, in all probability power section.
    Easy way to check voltage on adapter without special equipment?
    Quote Originally Posted by BradNunchr View Post
    Voltmeter, test lamp for cars, 12v headlight bulb.
    Could be bad power supply box.
Laptop Turn Off in General Support
Hi, i have an Acer Aspire E1-570, Windows 8, that just shuts itself down for no apparent reason and will not turn back on, sometimes for days! Have tried removing battery, letting it cool down, all to no avail. When charger is plugged in, unit feels warm (not hot) underneath towards the front. No...
Laptop: Asus Vivobook S550CM 8GB Ram everytime i press the power button, it just lights up then turns off. please help. I recently used ASUS Backtracker to fix my other issues.
Hi, I have an Asus laptop running Windows 8.1. I have an hdmi cable connected to my tv with a wireless logitech keyboard and mouse. Is there anyway to turn the laptop without opening the lid by using the keyboard? I have searched and people suggested getting some external button which I am not...
Hi, I have an ultrabook running windows 8 but it doesn't have a dedicated function button that lets me turn off the display. Is there anything built into windows 8 that can let me turn off my laptop display with just a couple of clicks or a new keyboard shortcut? Thanks
Recently I did a clean reboot(or something like that) on my laptop. Now when I hibernate it and I turn it on all it shows is a blank black screen.
hi..ad3fskj;l im using a small laptop with an external keyboard. the keyboard from the laptop seems to have a problem. it types random keys as if something stick is holding it down. ^that happens at random times and occurs with random keys. i've decided to use this external keyboard. how can...
Hi to all Eight forum. I m here with a strange problem, it happens from yesterday, the problem is when I playing games on my Dell inspiron N4050 and then the main power where the charger pluged in is turn off (it is the most problem in my country that there is heavy short fall of power), the...
