Help, Laptop will not turn on
BradNunchr
Okay so I have got an Asus Vivobook S550CA Laptop and it came installed with windows 8 - Specs
CPU: Intel Core i5 -3337U Mobile
GPU: Nvidia Geforce 635m 2gb DDR3 + Intel HD Graphics
RAM: 8gb
When I was just doing work on my laptop, It just shut down. Even when the charger is in, no lights are shown not even the charging one
  • I attempted to turn it on by pressing the power button... Nothing happens
  • I then tried Removing the battery and plugging the AC in - then turning on, Nothing happens
  • tried removing AC + Battery, Pressing Power for 60 seconds and pluging ac in before turning on again - Didnt work
I would really appreciate if someone could help me
Did you check voltage on the adapter ? but most likely something died on the MB, in all probability power section.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
