Need Help in SFC/Scannow
midou35000
Coming Over
Canada
Hi,
So i itried Sfc/scannow command in cmd and when it has finnished i have got this :
So i have uploaded the CBS.log file and can anybody tell me what is the thing that has not got fixed.
Thanks.
  • CBS.log.zip
    Windows 10
    HP
    Intel Core i7
    Nvidia Geforce GTX 680
    idfk
    15' 1080p display
    70Mbps
    Google Chrome Canary
    AVAST Premiere 2015
But how did you know that i have component store problem?
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
my understanding is, sfc checks your installed files against the component store for any differences
if it finds a difference it replaces the files
if the component store gets corruption, sfc cannot check for the correct version and so gives errors like the one you have
dism & sfc work together, if sfc fails, run the dism and then the sfc again after that finishes
    Dell Inspiron 3521
    i5
    4 GB
    AMD Radeon
    IE
Okay am running the dism its on 20% see ya when its done.
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
it might take a while on 20%, when I have ran it it looks like it has hung, but it will get there
    Dell Inspiron 3521
    i5
    4 GB
    AMD Radeon
    IE
Okay you stopped my worries.
    Windows 10
    HP
    Intel Core i7
    idfk
    15' 1080p display
    70Mbps
    AVAST Premiere 2015
