Why, when my netbook is on power save mode (CPU clocks dow
    Windows 8.1 64 Bit
    netbook 59% max CPU usage when on power saving mode
    Why, when my netbook is on power save mode (CPU clocks down to 0.97GHz from 1.67GHz), its CPU usage won't go past 59% when doing something intensive? Is Windows 8.1 limiting the CPU usage besides underclocking it? Is it measuring the CPU usage with respect to a full clocked CPU? Am I missing something? Windows XP shows 100%.
    Any clue will be appreciated.
    Hello Derek,
    Double check to see what your min/max processor state is set to in your power options. I like to keep mine set like below.
    Power Plan Settings - Change in Windows 8
    Hope this helps,
    its called processor Scaling, and its done for powersaving and thermal considerations. its performed by reducing the clock multiplier on the CPU, and thus reducing its overall frequency (GHz). most processors are 100-166Mhz but the clock rate allows it to perform multiple operations per cycle. Some will tell you that it is more harmful to the hardware than it is good. Put your power option to high performance and a shortcut on your start page for sleep...
    Windows 8.1 64 Bit
    Thanks to both
    I have it configured on 5% on max and min in Power save and I use balanced when more power is needed or it's plugged in, the netbook works fairly well on this mode as I use it for basic things as word processing and Internet browsing while saving battery.
    But my problem is that in this setup the CPU usage is up to 59% and I don't know if Windows 8 is limiting the usage or it's a new way to measure CPU usage, In XP and previously with 7 I get 100% with this same settings (in XP with Samsung drivers and utilities).
    Notice the spike, it's because I've changed to Balance and back to power save mode.
    Derek,
    Yep, the 59% is just what is currently being used. It's not for what is able to be used.
    A good setting in your power options is 5% MIN and 100% MAX like in my screenshot. This way Windows will be able to use up to 100% of your CPU if needed.
    Windows 8.1 64 Bit
    Quote Originally Posted by Brink View Post
    Derek,
    Many thanks again Brink, but why does XP show 100% CPU usage under the same circumstances?
    I know your setting is the optimal one in most cases, but I have to use the netbook for long times on battery and I have to do this to get it, as it's old (+3 years) and its battery is somewhat degraded.
    My doubt is if Windows 8 is limiting CPU usage besides underclocking (thus reducing performance even more) it or is a new way to measure usage based on its maximum clock? I would try running a benchmark like Passmark comparing both but it would heat my netbook a lot and would took plenty of time.
    If you have your MAX % set low in power options, then that would limit the CPU usage.
    Windows will also automatically reduce CPU usage if it detects that the CPU is overheating.
    Windows 8.1 64 Bit
    So Windows 8 is limiting the CPU usage besides underclocking the CPU while XP doesn't. It works fairly well for a netbook underclocked to 1GHz and 59% max CPU usage. Good job MS optimizing Windows 8 on slower hardware.
    Many thanks for your help and patience.
    Glad we could help.
    Yep, depending on what you set for min/max in power options, it will have Windows scale up and down the processor based on demand. It's all designed to help save battery life, energy, and reduce heat when the CPU doesn't need to be run at 100%.
Hello, Every time I start and restart my Windows 8.1 laptop it goes automatic in Power Save mode. How do I turn this off and late it every moment in High Performance? Thanks in advance!
This morning Windows did an automatic update and when it restarted my tertiary Dell monitor will not work. It works fine on another laptop, just not on my Toshiba. When un and replugging the Dell monitor I get a message saying the monitor is in power save mode and to move my mouse or press a...
Power Save problem? in Performance & Maintenance
I installed Windows 8.1 a month or two ago. I can't say I like the general look of it but it seems reliable enough. However.... About 4 times each day, my hard drive will 'stall' very briefly (as if the power's been removed) and then immediately start up again a fraction of a second later. When...
After waking my computer from power save (monitor turns off after inactivity) all I get is a blank screen. Monitor turns back on but only shows black. System is still responsive (numlock/capslock still work and I can sometimes make it make sounds by pressing random keys). After this happens,...
Power Save when screensaver is running in Performance & Maintenance
I have set up power save for 20 minutes. If I don't have a screensaver running then both PC and Screen go into power save mode after that time. But if I have the screen saver running then it does not go into power save at all, ever. If I stop screensaver (by moving the mouse) and go to the...
I'm trying to diagnose a problem with my laptop: When set to EFI boot mode, if I completely shut down and power off my laptop, it restarts by itself after a few seconds. This does not happen when the laptop is set to CSM boot mode. I'm in the very early stages of troubleshooting; at this point...
