using my cpu without thermal paste totally no (Fan) too
    Win 10 Enterprise X64
    My cpu was running just fine normal use 44C full load 51-54C
    suddenly the normal became 49C and full load 69-72C the temps started to raise in summer
    seems the junk Fan its horrible any ways it makes noise only
    can you believe? this cpu was running without the fan for +5 months
    Why? because When I checked this fan it has poor quality and junk noisy fan
    removed it the thermal paste was thick and drying this fan is totally torned (not touching the cpu) : looks like all this period my thermal paste and CPU was doing
    the job turned the computer on without any fan cpu pushed to OS running at normal at 49C so what//
    this fan looks like have bent metal not stable on the cpu any ways I put it until I get new one now
    I underclocked to 1200mhz to save the cpu at 44 idle 49 load totally the fan is doing nothing
    so what I keep my eyes on the temp until I replace this fan it
    Wynnum Australia
    Windows-10-Pro-Build-11099.rs1-x64
    Why not replace the whole heatsink-fan-combo ? There are some not so expensive ones on the market.
    Do you mean whole cooler is doing NOTHING at all ????? You had it overclocked to 3.7GHz with a standard, factory cooler and complain about fan noise ???
    If it's so, its a wander it did not burn up by now. That needs to be fixed pronto !!!
    its not even the factory cooler it looks like it but has torned metal all this period and not touching the cpu
    for the noise i did not mean it totally but its useless all it do is make noise that what I meant
    yup pretty cool chip
    95%
    No If I had its stock cooler it would be much better I know this chip (easily 3.7GHZ) 56 Full load with the stock cooler ::
    Quote Originally Posted by TONSCHUH View Post
    I am in an area which the strongest cpu in it is Pentium 4 they are all junk so I need to go to the capital but I dont have time
    and I took +2 months to look for 4930k ;; looking for someone abroad look at i7 4930k vs Pentium 4
    Wynnum Australia
    Quote Originally Posted by Gamer11 View Post
    That's no fun then. Let's hope you get it fixed / replaced before it dies.
    I will Thanks I was not funny at this
    Wynnum Australia
    I believe you and it's for sure quite a pain in the butt.
    I have similar trouble here in Australia with certain things as well, but not only computer stuff.
    It was like stepping in a complete different world, when I moved in 2008 from Germany to Australia and I'm still trying to adjust.
    Jeez, and I thought it was tough in my country. What about mail order, can you get anything like that. I haven't seen inside of a computer store for 3 or 4 years. I get my stuff thru internet orders, new or second hand and all of it on local level.
Page 1 of 3 123 LastLast
I had to replace the thermal paste on my CPU recently and I did it myself to save cash. I would like to share a tip no one is talking about. It's something I discovered by trial and error. The Big Debate as some of you will know is - How much paste should you use and what is the best method...
Is it only me or do others experience a drastic slowdown of their PC after updating to 8.1? ever since I updated to 8.1 my laptop is slow and misbehaves in many and various ways. It seems that the new update soon to be released is aimed at the metro users and if this is true then it is nothing...
Hi everyone! This is my big problem (and not only mine): I really HATE Cleartype and Segoe. It makes fonts really blurred. So since I was using Windows 7 I used these methods Windows Aero (Tahoma Font) - Windows 7 Help Forums and Any ideas on how to replace Segoe UI 9pt with Tahoma 8? - Page...
Solved Can't totally uninstall... in Installation & Setup
Well after an unsucessful attempt to get adjusted to Windows 8 I finally decided to uninstall it and it's just won't go away!!! It totally messed up the booting process now when I restart my PC it tries to repair itself and when it can't it offers a screen to boot into a different OS(I have a...
Solved Office 365 totally broken in Chillout Room
When I logged on to my Windows 8 machine I received a prompt asking me to install an update for Office. I allowed it to run but now Office is totally broken: - I cannot run any office programs: I just get an error message when I try - I cannot uninstall or reinstall Office: I just get an...
Hi there I think others posted before about this issue on W8 CP but still not fixed in RP. The supplied Metro apps won't open on a lot of netbooks because the screen resolution apparently is TOO LOW so What's up !!!???. If I can run PHOTOSHOP without having to plug in an external monitor...
Geek.com reports about a new piece of art created by Kasey McMahon. Take this provocative piece of modern art created by Kasey McMahon. Called “Connected,” it is apparently a self-portrait sculpture of the artist using steel as the underlying frame, which is then wrapped with Cat 5 patch cables...
