using my cpu without thermal paste totally no (Fan) too
  1. #11
    Win 10 Enterprise X64
    Quote Originally Posted by TONSCHUH View Post
    Quote Originally Posted by Gamer11 View Post
    That's no fun then. Let's hope you get it fixed / replaced before it dies.
    I will Thanks I was not funny at this
    I believe you and it's for sure quite a pain in the butt.
    I have similar trouble here in Australia with certain things as well, but not only computer stuff.
    It was like stepping in a complete different world, when I moved in 2008 from Germany to Australia and I'm still trying to adjust.
    Jeez, and I thought it was tough in my country. What about mail order, can you get anything like that. I haven't seen inside of a computer store for 3 or 4 years. I get my stuff thru internet orders, new or second hand and all of it on local level.
    hard thing I was asking about the i7 4930k with 2011 motherboard
    all people said you are wrong the cpu is 1755 socket
    I said what 1755 based motherboard ?? I never heard about this socket it even not exists
    and asked about the GTX 780 Ti he claimed that it has 4GB of memory
    all sorts of things is wrong because all people buy things like Core 2 duo or 1.8 dual cores (intergrated GPUS)
    he has no idea about GTX 660 To Titan
    so If I need any thing I must go and locate it and buy it
    I never tried ordering online before but thanks good idea
    he refused to buy the 4930k claiming that it needs 1755 socket /??
  2. #12
    Do you mean whole cooler is doing NOTHING at all ????? You had it overclocked to 3.7GHz with a standard, factory cooler and complain about fan noise ???
    If it's so, its a wander it did not burn up by now. That needs to be fixed pronto !!!
    its running in real time at 45C only at 1200mhz but no lag or something like that
    can still run HD videos well too
  3. #13
    It's still a risk, you never know when some power spike or something can get stuck. Luckily processors slow down or shut off when overheated. If it was an older 4462 Athlon you would be sending smoke signals by now.
  4. #14
    thanks I will get a cooler as soon as possible
    luckily It is a good chip it has excellent performance
    what is your opinion about people saying 4930k uses 1755 socket ;;
  5. #15
    As far as I remember socket 1755 is for certain Xeon processors and 4930K is 2011.
  6. #16
    so If I wanted something I need to go my self and buy it
    Thanks for all your help
  7. #17
    There is a sticker to convert 771 (Xeon) to 775 but for 1755 I haven't heard off.
  8. #18
    looks like these people have limited knowledge
    I told them that too but no scene (GTX 780 Ti 4GB )
  9. #19
    In my 25 years of build and repairing PC's, in the past 10 years or so, I have never seen a CPU "burn up" for any reason. The modern CPU's have a thermal overload built in so if the temps exceed the mas temp allowed, the CPU will simply shut down and not boot up again until it cools down. I don't recommend testing this on a CPU that you need because I don't know what the long term results of such "stress testing" on the CPU would be but CPU's do not simply "burn up" like they used to many years ago.... I hooked up a Q6600 CPU yesterday and forgot to plug in the cPU fan to the motherboard and it booted into the BIOS then ran for a minute or two then shut down. No harm done...
  10. #20
    Actually I can hear of very small number of processors dieing at all. Every now or then some gets burned by too high voltage during extreme OC or carelessness. With safeties built into them and MB they seem to be outlasting everything else in the computers. Most vulnerable are video cards, it seams. Nevertheless, I would not play with stuff like heat, some damage does occur every time it's safeties kick in, be it heat or voltage and that may cause problems in the whole machine down the line.
I had to replace the thermal paste on my CPU recently and I did it myself to save cash. I would like to share a tip no one is talking about. It's something I discovered by trial and error. The Big Debate as some of you will know is - How much paste should you use and what is the best method...
Is it only me or do others experience a drastic slowdown of their PC after updating to 8.1? ever since I updated to 8.1 my laptop is slow and misbehaves in many and various ways. It seems that the new update soon to be released is aimed at the metro users and if this is true then it is nothing...
Hi everyone! This is my big problem (and not only mine): I really HATE Cleartype and Segoe. It makes fonts really blurred. So since I was using Windows 7 I used these methods Windows Aero (Tahoma Font) - Windows 7 Help Forums and Any ideas on how to replace Segoe UI 9pt with Tahoma 8? - Page...
Solved Can't totally uninstall... in Installation & Setup
Well after an unsucessful attempt to get adjusted to Windows 8 I finally decided to uninstall it and it's just won't go away!!! It totally messed up the booting process now when I restart my PC it tries to repair itself and when it can't it offers a screen to boot into a different OS(I have a...
Solved Office 365 totally broken in Chillout Room
When I logged on to my Windows 8 machine I received a prompt asking me to install an update for Office. I allowed it to run but now Office is totally broken: - I cannot run any office programs: I just get an error message when I try - I cannot uninstall or reinstall Office: I just get an...
Hi there I think others posted before about this issue on W8 CP but still not fixed in RP. The supplied Metro apps won't open on a lot of netbooks because the screen resolution apparently is TOO LOW so What's up !!!???. If I can run PHOTOSHOP without having to plug in an external monitor...
Geek.com reports about a new piece of art created by Kasey McMahon. Take this provocative piece of modern art created by Kasey McMahon. Called Connected, it is apparently a self-portrait sculpture of the artist using steel as the underlying frame, which is then wrapped with Cat 5 patch cables...
