Small boxes problem
    Small boxes problem
    In my start menu or internet explorer there are weird [] boxes and it's been there for like a month and I don't know how they got there and how to remove them.. also when I do check marks in internet explorer or any where on my computer it has the small boxes
    San Jose - California
    Have you ever changed your system font ?
    Unzip the attachement and right click->Install
    Small boxes problem Attached Files
    Searched for seguisym.ttf and found this thread which explains why you want to do what topgundcp described:
    It should be in C:\Windows\Fonts.
    thanks topgundcp it worked
Small boxes problem
Ok so I tried to use small icons but the "Show hidden icons" Arrow is a bit lower than usual here is a screenshot http://i62.tinypic.com/2ijgt3n.png
Win 8.1 Pro Update Firefox 28.0 Win 8 Desktop Mode Example attached is a screen clip from Google Map - the + and - (zoom ) not shown in the box. User error is most likely the cause; but Personalization changes have not corrected the issue. The Win 7 box does not have this problem. 42136
Annoying boxes in General Support
Does anyone know how to stop/remove the annoying text boxes offering advice on swiping on Win 8.1? I suddenly got one today on the left side of the screen - "Switching between applications........swipe from side of screen, etc....." I can't get rid of it, and it's driving me mad. I could...
Metro apps black boxes in Software and Apps
Hello I recently came across a problem with some of the metro apps, black boxes would start appearing whenever an animation was needed in the app, or the areas would be blank. I looked this up, and some have suggested that it was a problem with AA settings on nvidia cards. However, I have an...
For some reason they kind of pop-under when i want them to be on top . if for example i am coping a file in a location where it already exists I dont realize that its telling me its there. i never notice there is info or something else to do i assumed the file transfered only to find out later...
I am using Windows 8 Pro 64-bit. In previous versions of windows, dialog boxes used to pop-up as required on top of other screens to indicate if there were problems or if action was needed (e.g. if you were copying a file from one location to another and if that file already existed there,...
I am looking for an easy way to sync 4 computers and 2 NAS's in realtime. is anyone running any software that will do this. I have used goodsync but everytime I format or upgrade my computer I have to get in touch with goodsync to sort out the codes as they wont work anymore Any help is very...
