System restore not working help ...
purplegoop80
Hi I have a windows 8.1 dell laptop ,for some reason system restore is not creating points manually or automatically, when I try to make a restore point manually the working bar just keeps moving at the sane time though I noticed in the device manger a generic volume shadow copy entry will show up with a yellow mark beside it ,I have tried maybe 10-15 times to uninstall this and try system restore again ,but this keeps repeating itself,
I have also went into safe mode but system restore points can't be made under safe mode, I did the repository thing where I rename that folder to old and reset repository in safe mode ,same result any ideas pls Thks
Make sure System Restore is enabled
In the elevated command prompt run sfc /scannow.
Also run chkdsk /f /r
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
The easy way just install a driver which makes restore point automatically
    Windows 8.1 Update 1
    Custom Made
    Intel i3 2100
    Intel DH661W
    4+2GB
    1 GB 6670 GDDR 3
    Samsung SyncMaster SA300 18.5''
    1366x768
    WD 1TB Sata
    Cooler Master 500w
    iBall
    Logitech K200
    Logitech
    256Kbps
    Antivirus Sucks
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
Thks for replies I did the scan twice and chk dsk also. The points are not being made even when a app is uninstalled or being installed for example in revo uninstaller I can't uninstall anything ,it just sits there making a restore point forever... Thks for the help
If Automatic Maintenance is turned off, put it back on.
How is your free disk space and are there any restore points in the system.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
Ok tried that and everytime I do that generic volume thing shows up in device manger with yello exclam beside it ,if I can get rid of that showing up in device manager the system restore will work..
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
Run a full virus scan and run Malwarebytes (Free) in the event that the system restore files have been infected. One hick here is that the infection, if there is one, may be to deeply embedded and can re-infect in the future.
If after all this and the computer does not return to normal, you will have to do a Clean Install of Windows. Back up your data first.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
Thks I was thinking it would come to that. I ran those tests yesterday ,nothing came up except cookies.
Just one question ,I hate the dell image on hard drive can I do a clean install of win 8.1, I made a dvd when i upgraded laptop just in case. If yes do I just format c partition or is there another partition I need to do? Thks
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
Possibly but you could fix that later.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
Open Services ( Win+X->Control Panel->Administrative Tools->Services) and double check if Volume Shadow Copy service is running.
If it is not running then try to start it. Also make sure the Remote Procedure Call(RPC) is also running.
If it still fails to create a restore point then It could be the hidden folder under C drive: System Volume Information is corrupted. This folder contains the System restore points. You can try to delete this folder and Windows will rebuild it upon reboot. However, this task cannot be done while Windows is running. In order to see the content of this folder and delete it, I have to use Linux Live CD.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
vsc drivers
Hi Purple,
in 1 of your earlier posts you said Yellow Exclamation mark, on VSC driver.
Update the driver it should then clear the error.
If that fails right click on events for that driver and post the results.
Note re clean install
Beware you said
I >> upgraded << the clean reinstall will take you back to the original factory settings, for your original OS.
Roy
    8.1 x64
    x55a asus
    bitdefender
    this laptop was/is still posted on asus website as W7
the ones i mean
not refering to services,
but the actual drivers, see attached,
should be as screenshot.
Roy
    8.1 x64
    x55a asus
    bitdefender
Thks guys for the help I had to do a clean install.I tried the driver update for the generic volume entry in device manger before the clean in stall and it said files are corrupt. So I said forget it clean install it is. Thks
