System restore not working help ...
  1. #11
    Oh sorry I have no restore points .
  2. #12
    Canada
    Run a full virus scan and run Malwarebytes (Free) in the event that the system restore files have been infected. One hick here is that the infection, if there is one, may be to deeply embedded and can re-infect in the future.
    If after all this and the computer does not return to normal, you will have to do a Clean Install of Windows. Back up your data first.
  3. #13
    Thks I was thinking it would come to that. I ran those tests yesterday ,nothing came up except cookies.
    Just one question ,I hate the dell image on hard drive can I do a clean install of win 8.1, I made a dvd when i upgraded laptop just in case. If yes do I just format c partition or is there another partition I need to do? Thks
  4. #14
    Canada
    Follow this tutorial How to do a Clean Install. It will handle everything.
    Clean Install - Windows 8
  5. #15
    Ok Thks , would I have any problems with the dvd way for drivers for the dell stuff?
  6. #16
    Canada
    Possibly but you could fix that later.
  7. #17
    San Jose - California
    Open Services ( Win+X->Control Panel->Administrative Tools->Services) and double check if Volume Shadow Copy service is running.
    If it is not running then try to start it. Also make sure the Remote Procedure Call(RPC) is also running.
    If it still fails to create a restore point then It could be the hidden folder under C drive: System Volume Information is corrupted. This folder contains the System restore points. You can try to delete this folder and Windows will rebuild it upon reboot. However, this task cannot be done while Windows is running. In order to see the content of this folder and delete it, I have to use Linux Live CD.
  8. #18
    vsc drivers
    Hi Purple,
    in 1 of your earlier posts you said Yellow Exclamation mark, on VSC driver.
    Update the driver it should then clear the error.
    If that fails right click on events for that driver and post the results.
    Note re clean install
    Beware you said
    I >> upgraded << the clean reinstall will take you back to the original factory settings, for your original OS.
    Roy
  9. #19
    the ones i mean
    not refering to services,
    but the actual drivers, see attached,
    should be as screenshot.
    Roy
  10. #20
    Thks guys for the help I had to do a clean install.I tried the driver update for the generic volume entry in device manger before the clean in stall and it said files are corrupt. So I said forget it clean install it is. Thks
Page 2 of 2 FirstFirst 12
Solved system restore not working on Win 8.1 in Performance & Maintenance
Came with Win 8.1 64bit I have tried 2 times to do a system restore with 2 different points. Once started system gets to screen saying system restore initializing, and it just stays at that point with circle spinning. I have to hold down power button to turn off and than restart back to desktop...
System restore not working in General Support
I was just booting up my laptop but it went into automatic repair and that didn't work and neither did system refresh and I tried system restore but when I tried to select c drive it said "you must enable system protection". I visited various threads about this but none of them worked. Ples. Halp...
Hi, I have modified the inbuilt System Restore task by adding a Daily trigger to it to run around an hour after I turn on (around 8:00am) the computer each morning. I have set all conditions Off so it should run no matter what the PC is doing. The Task list shows "Last run at 11/3/2014 at...
My main problem is that I accidentally uninstalled MS Office earlier today from my Dell Inspiron which I bought in 2012; the second problem is that I can't do a system restore to get it back to the point before the accidental un-installation. I'm on Windows 8. It keeps telling me there's something...
Dear All, My laptop (Dell Inspiron 2013 64-bit) was playing up today and instead of restarting it, I foolishly clicked on the option to "refresh the pc". Little did I know that this would remove all my current programs.... I decided then to do a System Restore. Now, all my programs are back,...
Hello to all, A month back I accidentally deleted the wow6432 node from my registry under system_user. I believe this is the root of all my problems. Once I did that, my toshiba c885 D 64 bit would not boot. I forced the computer to shut down and pressed f12 to get to the system recovery...
Automatic Restore Points is not working in System Restore. Task Scheduler is empty during last 30 days.
