Solved Shortcut for System Restore?
Odos270
I was able to do it in XP. I created a shortcut to system restore and put it on the Start Menu. So much easier than the way Win8 works. Wondering if there's a way to do the same in 8.1?
Thanks
    Windows 8.1 64bit
    HP h8 envy 1534
    AMD FX-6200 (3.8GHz)
    M3970AM-HP (Angelica2) (Gigabyte)
    10GB DDR3
    Eyefinity Radeon HD 7570
    Kaskersky Internet Security 2016
Restore Shortcut
You might try on desktop---
Create new shortcut---
rstrui.exe
Pictures to come...
Pictures---
More---
I put it on the Taskbar too---
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
That works, but........ it just brings up System Restore so you can restore to an earlier time. What I want to do is to be able to use the shortcut to create a restore point. Actually, in XP with that shortcut you could create a restore point or use a restore point.
    Windows 8.1 64bit
    HP h8 envy 1534
    10GB DDR3
I'll work on it. :)
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
This shortcut----
%windir%\System32\SystemPropertiesAdvanced.exe
will give you this---
I worked on it some.
This one is, I think, what you want----
%windir%\System32\SystemPropertiesProtection.exe
It gives you this---
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
Thanks! #6 worked like I want it to. :dinesh:
    Windows 8.1 64bit
    HP h8 envy 1534
    10GB DDR3
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
Thats what i call,coming late to the party,this one ,used to create a restore point at once.,created by our admin,Shawn Brink
  • Instant_Restore_Point.vbs
    W8 Pro 64bit
    Home...made ®
    Intel i7 2600k
    GA-Z68X-UD3P-B3
    Corsair Vengeance 4x4Gb 1600 Mhz
    ASUS GTX 680 DirectCU II SLI
    onboard
    LG Flatron W2240S PN
    SanDisk Ultra Plus SATA 3 128GB X2
    Western Digital Caviar Blue 2x1TB + WD Caviar Black 1TB
    Corsair RM 850 X
    Chieftec Dragon
    Thermalright Macho HR-02
    Ivation mechanical backlit
    MS Optical 6000
    24 Mbps
    Chrome
    ESET NOD32 8.0.312.0
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
