Power Plan options not affecting performance
    Hello there! For the longest while I've had issues with my Windows 8.1 ignoring my selection of power options. By this I mean by CPU will stay clocked at 1.4GHz when it should be hitting around 2.3GHz when I set to high performance from power saving mode.
    In the past it's cleared up by itself or through reboots but I'm thoroughly pissed off and I want it fixed.
    Would anyone know what the cause of this could be? Thanks!
    Plans
    Hi Stryking,
    This is only a guess as you did not fill in your specs.
    If your running an OEM,(Dell,Asus,etc).
    They tend to include thier own power plans so you could have changed the MS one but not your OEM's.
    Roy
    Quote Originally Posted by hawkman View Post
    Not necessarily - they usually provide also dedicated software for power management. I find the one provided by Lenovo as very useful. Others, as "mine" Dell provide application aimed only to optimize your battery performance (though Dell support promises to develop additional functionalities).
    In most cases you will find also some power-related options in BIOS.
    But as the hawkman says - in most (all?) cases such settings will override Windows native power management.
    Oh I posted here... Wow I'm so sorry for not following up.
    I filled in my specs for you guys, sorry for not doing that before.
    After going into Samsung's Settings app I ensured that my computer was not in silent mode and that eco mode was disabled.
    When I restart my cpu speeds up and slows down fro a little but then levels out at 1.8Ghz no matter what I do.
    AMD has a C&Q (Cool and Quiet) utility, see if that is installed, it overrides all other settings as it works directly with BIOS.
    The C&Q utility is not on. All the catalyst control panel options appear to be in order as well.
    For some reason my computer either levels off at 1.8Ghz or 1.4Ghz... Not sure why it isn't consistent
    Bump?
    How about "AMC CCC" or "AMD Engine Vision Control Center" ? Do you have that installed ? There should be CPU Overdrive and Graphic Overdrive that have settings for clock settings in "Performance mode" that could be set to lower limits.
I went into my power options to change some of the advanced settings and most of them are missing? I am on windows 8.1 with a week old Surface Pro 3. I want to say I read somewhere that hyper-v can cause options to be missing, but I honestly don't even know what that is and I don't have it...
Power Plan Affecting WiFI? in Performance & Maintenance
I was on a balanced power plan on my laptop while streaming on Netflix from my xbox. I couldn't get on any site on the laptop but I was able to use my iphone. On a hunch I switched to high performance and it works. Not sure if there is a relationship between power and the wifi on my laptop.
Hiyo there. In the future I'm planning to build a new computer to replace this old hunk of junk and I'm curious as to one thing as I'm not entirely sure on this. Just how safe is using the High Performance Power Plan in Windows 8.1? You see, my current rig is running an old i5 661, normally...
Solved how to remove entry's in win 8.1 power plan in Performance & Maintenance
Hi so is there any way to remove old not needed advanced entries in the windows 8.1 power plan settings. here is a picture of what i'm talking about. highlighted in red is what i don't need anymore any way to remove it?. 51352
Hi, I am having an issue with 8.1 Pro I can't seem to find an answer for, so I'd thought I'd try for help here. After installing the 8.1 Pro update on a fresh install of 8 Pro, I only entered the Power options one time: to change the "high performance" plan to never turn off the display. (as I...
What Power Plan do you use? in Performance & Maintenance
As title suggests, what power plan do you normally use on Windows 8? Do you switch between power plans depending on the situation at hand? I run Balanced most of the time, since my AMD CPU has Cool'N'Quiet technology, then switch over to High Performance when gaming.
