Surface pro 2 wont boot after reset. PLEASE HELP
    windows 8.1
    Hi all,
    I really need some help, I bought a surface pro from a friend yesterday, it had been turned on before I got it so I thought I would reset to factory settings, all was fine until the reset was around 90%, then a box appeared saying "the computer has restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install windows, click OK to restart the installation".
    But when it restarts the same message pops up.
    Any help welcome as I really don't have a clue what to do now.
    Many thanks
    Mark B
    Hafnarfjörður IS
    Hi there
    I think you'll need to re-install Windows -- in the BIOS you can disable protected boot so you should be able to boot a new recovery USB for a Windows re-installation. There's tutorials on this site about making a recovery USB.
    Cheers
    jimbo
    windows 8.1
    Thanks for the info Jimbo, unfortunately I don't have a boot USB, am I able to get the relevant data from another surface pro 2 tab?? As my wife also has one with the exact same hardware.
    Once again thanks for ant info in advance as I'm really useless with this kind of thing.
    Many thanks
    Mark B
Im running Windows 8.1 and yesterday my PC decided to stop initializing any USB devices I plug in after the system is booted. If the device is plugged in prior to the system booting it is recognized fine (unless i unplug it and plug it back in, then it wont initialize). My BIOS always shows my...
Hello, I just reset my surface pro 2 back to its factory settings. It is back to the original Windows 8.1 Pro installation. I'm looking for some advice on how to set it up properly. I know there will be alot of updates to be installed, but is there any particular order they should be...
Hi i have a serius problem with my computer i got a virus that deselected my grapics card and wouldnt allow me to go in bios so i thought that a factory restore would do it, unfortunetly i was wrong. It turned off the computer and when i try to start it it just goes to a black screen for about an...
Last night I updated windows 8.1 from windows 8. It got to the stage where it needs to restart so it done that started the configarations and once it reached 100% it restarted. Since then what happens is when i press power on the samsung logo comes on the screen then the black screen with the...
Last night I installed windows 8.1 preview through the windows store. It all worked fine and it seemed like there was nothing wrong. When I woke up this morning my pc gets past the windows loading screen (The new fish thing looks just plain stupid) but then my screen just goes black. The screen is...
Solved Surface Pro Factory Reset Issues in Installation & Setup
So I recently installed linux on my Surface Pro, but decided to go back to Windows 8 since wifi doesn't work properly yet. I thought, restoring shouldn't be a big deal, just insert the recovery USB you made and factory reset it. Boy, was I wrong. Any time I try a factory reset, it fails around...
My PC wont Boot! :( in General Support
Hey guys im very sad because my pc wont boot. Iv got a custom PC running 2500K CPU It loads the ASUS Mobo screen then a black screen with a white Dash appears on the top left side of the screen which keeps flashing and thats it. What do you think it could be? plz id appreciate any help...
