Problem with checking for problem solutions Windows 8.1 PR
    When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later…
    The problem is that I am connected to the Internet while I receive this message and now I do not see any other way to check for solutions.
    Anybody can help?
    Harrisonburg, Va.
    I can't help with the problem but just want to comment that this is just another example of poor customer service by Microsoft.
    Quote Originally Posted by David Bailey View Post
    Nobody ever accused them of good service, them and almost all of big corporations, they just don't care about little guy but would gladly sell you some "extended service", "extended warranty" etc. Letting people die because they would not make a 15 cent change to ignition lock like GM did (even with thousands of complaints) is just part of it. What to expect from a SW company than.
    What about: Control Panel / Troubleshooting / Help and support ?
    I found the answer accidentally… I am in a metered Internet connection and somehow windows think that I am not connected at all!!!!
    If you right click your connection and set it as a non-metered connection then everything is alright!!!
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
So i'm trying to delete this file i have in my downloads folder, which is a normal .avi file. however, this file is really broken, it wont delete. I suspect this file makes my folder not showing thumbnails and acting slow and sometimes wont show anything at all, just a loading bar thing. i...
Hey, running Windows 8.1 64bit, Asrock Z87E-ITX mobo, Intel 4770K Problem 1: When i shot down my pc via windows Shot Down button pc doesn't go Off. I see Windows Off screen, screen goes black but pc still running. Solution? Problem 2: When my pc goes sleep or monitor goes sleep i can't...
I've used Keytweak in the past with Win7. Now I find it's not working as expected in Win8. Changes are not being adopted by the registry and at reboot the app does not reflect the key remap change. Is there a trick to get this utility behaving as expected? Change / Modify / Reassign the Keys or...
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
