System Restore will not restore
    I make manual System Restore points and when I try to use them to restore, it goes thru the motions but ends up saying System was not restored - returned to previous state. I make Macrium Reflect back-ups regularly and they work great - no problems. So, what I have done is turn off System Restore, and rely on Macruim Reflect images. SFC Scannow indicates NO corruption and completes fine.
    My question is, should I worry about the fact that SR is not working - or, since I really don't need it, leave it disabled and not worry about it. System seems to be running ok.
    Windows 8.0 x64
    Did you try turning off all anto-virus programs? It's fine to have Macrium backup images. I use it. But I think it's also good to have Restore Points for quickie Registry restore. If it is a big hassle to get it working you can use ERUNT to back up the Registry.
    The only anti-virus on it is Windows Defender, but thanks for post - based on it, I went in registry and looked for old fragments of old av's used when I had Windows 7 on the pc - deleting them. Then I turned Windows Restore completely off and restarted the pc. I then made a restore point and used it to restore and it worked fine, so I guess it's solved. Thanks for your help.
    I use AVG 2014 FREE, and with it on I'm well protected, but.....I can't do a system restore till I temporarily disable AVG.
    I just right click on the AVG icon in the system tray and then click on "Temporarily Disable AVG Protection".
    Then I can go ahead and do a system restore and it works every time.
    Cheers Mates!
    TechnoMage
    Windows 8.0 x64
    Glad you resolved it. Thanks for posting the method you used.
System restore not creating restore point in Performance & Maintenance
I went into Task Scheduler and set System Restore to create a restore point every day at 12:01am. Under Conditions I cleared all the check boxes because I want SR to run regardless of whether computer is idle or not. I have been watching this for about 1 week and so far it's not created a single...
I have a Lenovo G585 laptop that I installed with Linux (tried dual boot) and accidentally wiped out the Windows 8.1 restore partition. Now I want to restore it to Windows. I also have a Dell desktop W8.1 that I can use to to create a USB restore image, can I use a restore image from a desktop to...
Dumb question - if I panic and have to do a system restore or system reset using the install DVD for W8 what will happen to the W8.1 version I just downloaded and installed?
Hello to all, A month back I accidentally deleted the wow6432 node from my registry under system_user. I believe this is the root of all my problems. Once I did that, my toshiba c885 D 64 bit would not boot. I forced the computer to shut down and pressed f12 to get to the system recovery...
Automatic Restore Points is not working in System Restore. Task Scheduler is empty during last 30 days.
I recently had to return my HP Pavilion g7 Windows 8 64- bit only laptop to the manufacturer for repair under warranty. Prior to this I created a system image as the Hard Disc was going to be replaced. Having now received the repaired laptop I have been trying to restore the saved image. I watched...
System restore in Performance & Maintenance
Hi everyone,,im trying to Restore my new laptop to a date that i choose but the system restore module chooses for me and it will not let me enter a date that want,,,grrrrrrr its beginning to annoy the hell outa me,,im on a samsung laptop running windows 8,just want to restore it back to the 1st of...
