Low Memory Problem
    Low Memory Problem
    Hi,
    So the problem is i was playing CounterStrike And this popped up:Click image for larger version
    Any help please
    win8.1.1 enterprise
    seems your harddrive is getting full,and the programs needs more virtual memory to run and or you need to add more ram to the computer
    Virtual Memory Paging File - Change
    That game is very stingy on memory, it runs just fine on much lesser systems . I suspect there's something wrong with game itself, specially if it's the only one with problems like that. Just in case, check memory usage at the time and maybe even run memory diagnostic test.
    Reinstalling the game would be my first response.
    Quote Originally Posted by caperjack View Post
    The above recommendation is too vague to be useful in a specific sense. With that said, I would recommend you seek a more specific solution for your specific problem. So, if you ask a specific question, I will try to provide a specific answer. Let's start off by checking your RAM allocation at idle. Here's mine:
    win8.1.1 enterprise
    vague is my middle name ,lol
    Just throwing in my2cents as you usually do whenever I make a suggestion.
    win8.1.1 enterprise
    there is a word right on the tip of my tong, it just won't come out
    I don't see where I did anything wrong that might provoke you. You are simply critiquing my responses and now I am starting to critique yours.
    win8.1.1 enterprise
    Quote Originally Posted by my2cents View Post
    sorry won't happen again ,wasn't conscious I was even doing it ,I never intentionally followed anyone around
    Thank you kindly.
Low Memory Problem
'Computer Memory Low' Problem in Performance & Maintenance
Hi All. I have Windows 8 and keep getting a 'low memory' problem. I am dreadful on computers so haven't a clue what to do! It is an Acer Aspire laptop which I have had about 18 months and apparently has '8 GB DDR3 Memory'. I have attached all the screenshots which i can think of that may...
WIndows 8 Excessive Modified Memory Problem in Performance & Maintenance
Hi folks, I've been out of the Windows world for a while--I run Ubuntu on my main machine--but I've been setting up a new Samsung laptop running Windows 8 and have started banging my head against the wall. Within a few weeks of using the machine, I started getting out-of-memory warnings....
Please help! Just upgraded to Win 8.1 Pro from Win 8 on a Dell Latitude E6530. Everything was working fine; post upgrade, system does not recognize any of my SD cards upon insertion. All other peripheral storage devices are fine. Has anyone run into this problem; if so, know a fix? Thanks.
Windows 8 pro memory dump problem in BSOD Crashes and Debugging
Hi,there I've installed win8 pro in my Netbook it was good but the due to the low resolution(1024*600) the apps are not opening. So i made some registry changes(Display1-downscale support)by changing binary value 0 to 1 and got the required resolution to run the apps. But when the app is opened the...
Memory Management problem in Drivers & Hardware
Hello, I would be grateful if someone can tell how to resolve this problem. OS: Microsoft Windows 8 Pro CPU: AMD Phenom(tm) II X4 965 Processor, 3400 Mhz (RAM): 16,0 Gt Graphics card: GeForce GTS 450 SSD: Intel SSDSA2M080G2GC Motherboard: 770-C45
After my new build froze up during boot up into Windows 8, I tried to run Windows 8's built-in Windows Memory Diagnostic, extended setting, but it got stuck at 21% of 1st pass (10% overall) after running it overnight (at least 12 hours). I had 4x4GB memory modules, and re-ran this test with only...
So, shutdown problems... We meet again. I have an "internal! Memory card reader in my computer connected to the mainboard's USB slot. The reader works correctly, but every time I shut down my computer Windows realises to start complaining about Empty drives. I press the shutdown button. ...
