system restore problem
    i have windows 8 when trying to use system restore it gets to the screen that says
    system restore is restoring files, but that's as far as it gets, I let it run today for 4 hrs.
    what can i do?
    Harrisonburg, Va.
    Try running
    sfc /scannow
    in administrator command prompts.
    Reboot after dism & run sfc again.
    They take a while to finish so be patient.
    thank you!
    Harrisonburg, Va.
    Quote Originally Posted by bluzeboy View Post
    thank you!
    You are welcome.
    {If you think I deserve it, a rep would be greatly appreciated.}
System restore not creating restore point in Performance & Maintenance
I went into Task Scheduler and set System Restore to create a restore point every day at 12:01am. Under Conditions I cleared all the check boxes because I want SR to run regardless of whether computer is idle or not. I have been watching this for about 1 week and so far it's not created a single...
Hi, This is my first post on the forum. I am of Polish so I apologize in advance for my language errors. Translator, translate the text: p I have this system of seven months, and already appeared first troubling issues with which I tried to deal with, but unfortunately did not bring any positive...
Solved System Restore will not restore in Performance & Maintenance
I make manual System Restore points and when I try to use them to restore, it goes thru the motions but ends up saying System was not restored - returned to previous state. I make Macrium Reflect back-ups regularly and they work great - no problems. So, what I have done is turn off System...
Dumb question - if I panic and have to do a system restore or system reset using the install DVD for W8 what will happen to the W8.1 version I just downloaded and installed?
Hello to all, A month back I accidentally deleted the wow6432 node from my registry under system_user. I believe this is the root of all my problems. Once I did that, my toshiba c885 D 64 bit would not boot. I forced the computer to shut down and pressed f12 to get to the system recovery...
Automatic Restore Points is not working in System Restore. Task Scheduler is empty during last 30 days.
I recently had to return my HP Pavilion g7 Windows 8 64- bit only laptop to the manufacturer for repair under warranty. Prior to this I created a system image as the Hard Disc was going to be replaced. Having now received the repaired laptop I have been trying to restore the saved image. I watched...
