PC not going to sleep after waking up for maintenance
    Windows 8.1 Pro w. Media Center
    I have set up scheduled maintenance on my laptop (on Windows 8.1) as:
    I have also set up my laptop to go to sleep after an hour of inactivity:
    So far, I have found my laptop not asleep everytime I wake up at around 7AM (two times in a row). Here are some "powercfg" outputs:
    What should I do?
    Hello, sabrefresco. Welcome to Windows EightForums.
    Did this machine come with 8.1 on it or did you upgrade?
    Is Samsung Magician.exe bloatware?
    Instead of via the Action Center setting you may want to refer to this tutorial: Windows Defender Scheduled Scan - Set Up in Windows 8
    Quote Originally Posted by HippsieGypsie View Post
    It came with Windows 7, I purchased the Windows 8 upgrade and now I am no 8.1 (free update for all 8 users). It was a clean install for Windows 8, then upgraded to 8.1. Samsung Magician is my SSD monitoring, diagnostics and optimization software and is not a bloatware. How exactly will be scheduling maintenance through Task Scheduler? I don't know which exe or syntax to use.
    My apology. I linked the wrong tutorial.
    Do you manually put the laptop to sleep when you are finished for the day? I'm assuming so since it awakes.
    OK. Not exactly "bloatware" in a sense, but a 3rd party program that may be conflicting with Windows maintenance so far as sleep is concerned anyway. Did this problem start to occur after you installed Samsung Magician or did you always have it? Not sure?
    After rethinking this, let’s put that on the back burner. Are you up to date with updates, especially the last ones last week? Many members were having sleep problems that a particular update fixed for many. It did for me. Windows 8.1 refuses to sleep
    Just for grins, you may want to look through this tutorial and please notice all the links to others pertaining to the subject at the end.
    Sleep States - Available on Your Windows 8 PC
    My laptop goes to sleep after closing the lid (so yes manually). To be honest, I started this scheduled maintenance recently, after I already had the Samsung Magician software installed. So can't tell if the Magician software is conflicting with either the Maintenance or sleep.
    I am up-to-date (including the updates released on the second Tuesday of this month). Here's a screenshot of "powercfg -a" output:
    Not sure what that means, I haven't fully gone throught the Sleep States page (reading it now).
    The “system firmware is the BIOS or UEFI, whichever one it is. I have an older Acer tower with BIOS. We have the same OS version. Here’s my report:
    I would reverse everything you did in the scheduled maintenance to see how that goes. Although theirs a timer set on mine, it never wakes for maintenance. Tasks are performed in the background while the PC is idle. I intentionally leave it to go do something if it's not too long (turning the monitor off) and find it busy virus scanning, defragging, and the likes when I return. 8/8.1 are pretty self-sufficient so far as that goes.
    From what I understand, Fast Startup and Hybrid Sleep are disabled because Windows is on my SSD. I disabled hibernate to save up space on the SSD. The thing is, I want it to do maintenance and then go back to sleep after midnight when I am not even using it. I do see the maintenance going on here and there when I leave the for a few minutes, but it would be nice to have an uninterrupted session of maintenance.
    Ok. Let me do some research. I'll be back in a bit.
    Continuing to look. You did everything correctly here? Just to be sure.
    Hibernate - Enable or Disable - Windows 7 Help Forums
    Yep.
Page 1 of 2 12 LastLast
BSOD Waking from Sleep in BSOD Crashes and Debugging
Hello everyone, I get a BSOD when waking my Laptop out of sleep. I believe this doesn't happen on Win 8 with no updates applied. So I think it may be a Windows update or driver that is causing my BSODs. I do not believe its hardware related like a failing HDD. Though I could be wrong.
Solved BSOD after waking up from sleep in BSOD Crashes and Debugging
So, I've been getting BSOD for over a month. It happens after my laptop wake up from sleep. I've tried to uninstall some programs i installed just before this happened (malware bytes, HP printer driver, etc) but this BSOD still happens. I hope someone can help to analyze and solve this problem.
After i put my computer to sleep and try to wake it up, i immidiately get a BSOD. The file that caused the BSOD recently was volmgrx.sys. The computer works perfectly, no problems whatsoever. I didn't do any overclocking.
Waking From Sleep ? ? ? in Drivers & Hardware
I had this same problem while running under Win 7, and now under Win 8.1 Pro my PC is doing the same thing. It seems to wake up all on its own from "Sleep". I went through the device manager and looked at everything, and nothing but my KB and mouse where set to "Allow this device to wake computer"....
Solved Keep waking up from sleep in Performance & Maintenance
When I put my computer to sleep, it keeps waking up all on it's own. Why won't it stay asleep? Is this a problem with my computer or Windows8?
Having a problem with the Regular Maintenance waking the computer (Windows 8 on a Lenovo Q-190) to do its scheduled task as it's supposed to do. Here are the symptoms: 1. If I change the time for Scheduled Maintenance in the Action Center (Change Maintenance Settings), it WILL be reflected...
Action on waking from sleep in Performance & Maintenance
When I first installed Windows 8 my system used to go to sleep after 30 minutes of inactivity and then resume on pressing any key. Recently, without any apparent changes to settings, it will not resume and the power button has to be actioned requiring a loggin. Can anyone tell me what setting...
