8.0 upgraded to 8.1 with system restore problems
    8.1 Pro with Media Center/ 7 Home Premium
    I installed 8.0 with the factory disk and for awhile the option to "refresh your pc" worked perfectly. However after the 8.1 update, I get a message stating to insert the 8.1 disk and it won't work with my regular 8.0 disk. I don't have an 8.1 disk. Is there a way to download an iso and use that to refresh the pc then use the original 8.0 key? I usually try to restore every 6 months because it's a habit I have had since 7. Usually my windows works fine but I run low on SSD space and it's easier to erase and restart everytime.
    ME, XP,Vista,Win7,Win8,Win8.1
    You will need to buy the DVD.
    Windows 7 Ultimate 64-bit Windows 8.1 Pro 64-bit with Media Center
    If your computer came with Windows 8.0 then the only way I know is you will have to buy the DVD.
    But if you installed Windows 8.0 your self then you can go here to see how to get the DVD ISO: Windows 8 and Windows 8.1 ISO - Download or Create
    Another unrelated question... I went back to windows 7 because of too many random driver problems and other stuff that pissed me off. I was trying to install 8 PRO with the serial I purchased from microsoft but it says this serial cant work when i try to activate. Any ideas? It takes my Media Center upgrade serial but it says i have to activate the pro version first. I'm using VMWare Workstation 10. With windows 7 there was a way to call in and re-activate. But i can't seem to find that option
System restore not creating restore point in Performance & Maintenance
I went into Task Scheduler and set System Restore to create a restore point every day at 12:01am. Under Conditions I cleared all the check boxes because I want SR to run regardless of whether computer is idle or not. I have been watching this for about 1 week and so far it's not created a single...
Hi everyone, I upgraded to 8.1 this past weekend and it went just fine, however now the the Backup and Restore Center and Create Recovery Disks options are busted. Both icons appear in my app list as generic grey document icons, and if I click either of them I'm brought to the desktop and...
Hello to all, A month back I accidentally deleted the wow6432 node from my registry under system_user. I believe this is the root of all my problems. Once I did that, my toshiba c885 D 64 bit would not boot. I forced the computer to shut down and pressed f12 to get to the system recovery...
Automatic Restore Points is not working in System Restore. Task Scheduler is empty during last 30 days.
I recently had to return my HP Pavilion g7 Windows 8 64- bit only laptop to the manufacturer for repair under warranty. Prior to this I created a system image as the Hard Disc was going to be replaced. Having now received the repaired laptop I have been trying to restore the saved image. I watched...
PLS HELP! Upgraded to windows 8 , system refresh and lost all my software, I need my emails folder!!Hey Everyone. Thanks for reading. Ok heres my details: 1) I upgraded from windows 7 to 8, everything went fine! All my files and programs upgraded fine!! 2)when I upgraded I was messing with...
I have a 15 month old Dell Optiplex 990 (Core i7 2600 @ 3.4GHZ; 16GB DDR3 Crucial RAM (4 x 4GB); 1TB WDD HDD; 2 x Radeon 6450 Graphics dribing 2 x HP LP3065 displays at 2560 x 1600). Ran fine in Win 7 HP. Upgraded two weeks ago to Win 8 Pro and I get (a) video driver crash/restart after about 20...
