Solved 8.0 upgraded to 8.1 with system restore problems
kingturbofox
I installed 8.0 with the factory disk and for awhile the option to "refresh your pc" worked perfectly. However after the 8.1 update, I get a message stating to insert the 8.1 disk and it won't work with my regular 8.0 disk. I don't have an 8.1 disk. Is there a way to download an iso and use that to refresh the pc then use the original 8.0 key? I usually try to restore every 6 months because it's a habit I have had since 7. Usually my windows works fine but I run low on SSD space and it's easier to erase and restart everytime.
    8.1 Pro with Media Center/ 7 Home Premium
    Self Built - Republic Of Gamers
    i7 3770k
    Maximus V Formula
    16 GB
    Asus Radeon HD 7870
    ROG SupremeFX
    Sony 46" 3D LED
    2x Seagate 2 TB
    1x Seagate 4 TB
    Samsung EVO 256GB SSD
    Corsair AX860i
    Zalman Z11
    Corsair H80i
    Logitech Illuminated Keyboard K800
    Logitech Wireless Trackball M570
    Bell Fibe 50/10
    Torch
You will need to buy the DVD.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
Another unrelated question... I went back to windows 7 because of too many random driver problems and other stuff that pissed me off. I was trying to install 8 PRO with the serial I purchased from microsoft but it says this serial cant work when i try to activate. Any ideas? It takes my Media Center upgrade serial but it says i have to activate the pro version first. I'm using VMWare Workstation 10. With windows 7 there was a way to call in and re-activate. But i can't seem to find that option
    i7 3770k
    Maximus V Formula
    16 GB
    Asus Radeon HD 7870
    ROG SupremeFX
    Sony 46" 3D LED
    2x Seagate 2 TB
    1x Seagate 4 TB
    Corsair AX860i
    Zalman Z11
    Corsair H80i
    Bell Fibe 50/10
    Torch
