Laptop automatically switches to Power saver mode
    I'm currently experiencing this issue and it's really annoying. I just bought this laptop for 2 months and it's been working fine. Then suddenly this problem started yesterday. Generally every time I open up a game my laptop will automatically switch to Power saver mode and it causes some lags in the game. At this point I would Alt+Tab to desktop and switch it to "High Performance". Here's the annoying part, even though I have set it back to "High Performance", the laptop still works as it in "Power saver" mode, I can tell because the game is still laggy and slow. I tried to restart the laptop and experienced the same issue. I ran a Full scan by using Avast Internet Security 2014 and didn't detect any problem at all. What should I do? Thank you.
    By the way my OS is windows 8.1
    Hello Frankie, and welcome to Eight Forums.
    It sounds like some sort of power management software that came preinstalled by the OEM on the laptop. Check to see if such software is on there, and what it is set to.
    Hope this helps some,
    Thanks for responding. But, um... can you go more detailed? Like, how do I check it? Sorry I'm new to this thing
    What brand and model number is the laptop? I'll see if I can find more info about it.
    It's a Samsung 470R5E-K01
    Windows 8 64 bit
    CPU: Intel Core i53230M
    Well, I couldn't find anything specific. If you look on your Apps screen, it will list all of your installed programs. Look through them to see if any are from Samsung or look like a power management type program, then open it to see if so, and to make any needed settings changes.
    I checked and didn't see anything specifically related to the issue I'm having. I'm thinking about restoring my system because I did back it up after I bought my laptop for a few days. I just hesitate in doing so because I might be losing a lot of data. Will restoring help?
    Since you didn't have this issue originally, it should help. However, you should back up anything that you do not want to lose to a separate location so you don't lose it.
    Before doing a factory reset (if that's what you meant), see if you may be able to just do a system restore using a restore point dated before this issue started to hopefully undo it without risk to anything in your user folders.
    I'll try that now. Thanks alot! Really appreciate it
Hi, The way I know my desktop PC has gone to sleep is that the blue light around the power button flashes (instead of being on all the time). I'm playing around with some settings right now to find out exactly what is pulling it out of its sleep. I realized that if I go to Power Options and...
How can I get my webcam to take a pic when the computer is unlocked. I live in a frat house and someone has been using my computer. I want to know who. I know the task scheduler has a trigger of "when computer is unlocked" how can I make use of that? Or is there a fancy script someone knows...
Multiple "Power Saver" Entries in Performance & Maintenance
Hi all, I was going in today to tweak something in my power plan, when I noticed that I have a lot - and I mean a LOT -of the "Power Saver" plans stored in the Power Options page. I could go in there and manually delete all the extras... but it would take me far too long. Does anyone know a...
When ever i turn on or wake up my computer i have to go to "Networks" chose my perferred network and connect. And there are 3 other networks listed and for everyone the connect automatically box is checked and when i uncheck it i rechecks itself. the network that i always use has this box too but...
Solved Power Saver Setting Option Windows 8 in Performance & Maintenance
I don't know if this may have been posted previously, but just in case it helps someone, I'll go ahead and post it. Use of the Power Saver Setting in Windows 8 lowers my pc temperature (at idle) by at least 6 degrees. Using this setting, my pc now idles at 27 degrees C. When I use High...
OK so I always watch video and movies with my ASUS computer attached to my HDTV. I have never had a problem then one day the audio stopped switching to my tv automatically. I also use surround sound headphones sometimes which require a USB connection and the audio no longer switches to them...
