Power Save problem?
    Power Save problem?
    I installed Windows 8.1 a month or two ago. I can't say I like the general look of it but it seems reliable enough. However....
    About 4 times each day, my hard drive will 'stall' very briefly (as if the power's been removed) and then immediately start up again a fraction of a second later. When this happens I don't see any disturbance on my screen but it's almost as if a power save feature was about to kick in but then changed its mind. I tried disabling all power save functionality but that didn't make a difference. In any case, it usually happens when I'm using the computer so I wouldn't have thought it was a power save issue.
    I can multi-boot my PC with both Windows 7 and Windows XP. Neither of them exhibits this problem. It only happens with my newly installed Win8.1.
    Has anyone else experienced anything like this?
    Windows 8.1 32-Bit
    Did you check the hard disc spin down time in the power plan you are actually using? It's inside the energy options. Set HD spin down time to 0 in all power plans and the HD lags should disappear.
    Thanks. I've just reset that option to "never" and I'll report back in a few days if it works!
Power Save problem?
Hello, Every time I start and restart my Windows 8.1 laptop it goes automatic in Power Save mode. How do I turn this off and late it every moment in High Performance? Thanks in advance!
Why, when my netbook is on power save mode (CPU clocks down to 0.97GHz from 1.67GHz), its CPU usage won't go past 59% when doing something intensive? Is Windows 8.1 limiting the CPU usage besides underclocking it? Is it measuring the CPU usage with respect to a full clocked CPU? Am I missing...
This morning Windows did an automatic update and when it restarted my tertiary Dell monitor will not work. It works fine on another laptop, just not on my Toshiba. When un and replugging the Dell monitor I get a message saying the monitor is in power save mode and to move my mouse or press a...
After waking my computer from power save (monitor turns off after inactivity) all I get is a blank screen. Monitor turns back on but only shows black. System is still responsive (numlock/capslock still work and I can sometimes make it make sounds by pressing random keys). After this happens,...
Hello I have many games that are working with this: like bioshock 2, GTA 4 EFLC, Section 8, to name a few and many others. When I start these games, the game says no profile is signed in, and there is no where for me to sign in... and it won't save progress. However Games for windows...
Power Save when screensaver is running in Performance & Maintenance
I have set up power save for 20 minutes. If I don't have a screensaver running then both PC and Screen go into power save mode after that time. But if I have the screen saver running then it does not go into power save at all, ever. If I stop screensaver (by moving the mouse) and go to the...
