Recovery Partition Problem.Partition Does Not Exist.
    I have a Samsung Ultrabook series 5 laptop..some couple of month usage i completely remove my hard drive and change the windows 8 to windows 7..when i use windows 7 i realize windows 8 is much better then windows 7 so again i clean install of windows 8. i boot drive in PXE UEFI Only Mode.​Some reserved partition created also 300MB Healthy Recovery Partition is Created.when i install a Samsung Recovery Solution Software it Says "Recovery Partition Does Not Exist"..What do i do.also when i refresh Pc it gives me Error "The Drive is Locked Where the Windows Installed"​ I want to make my Laptop like 1st time it was...
    Can any one Please Help me...
    If you did not make the factory recovery discs during the initial setup of you laptop, your only recourse at this time is to order them from the manufacturer. You have no other options available at this time to recover your laptop to "factory status."
    Good luck,
    my2cents
    As i Expected this type of Ans...
    do u know how Manufacturer can do this task..Which Certification hold ..How they do it.????
    Quote Originally Posted by akbar ali View Post
    You would order the OEM discs from the manufacturer and you would do the installation yourself.
    ME, XP,Vista,Win7,Win8,Win8.1
    How to make Recovery disc:
    Support - Laptops NP700Z7CH | Samsung PCs
    You can order the Microsoft official OEM Recovery disks from your OEM manufacturer's website.
    How to Order Recovery disc.
    Samsung
    http://downloadcenter.samsung.com/co...Manual_eng.pdf
Problem with recovery partition in Installation & Setup
Hi All, I just bought an open box asus N550JV but it seems to have some problem with recovery partition. I'm trying to figure it out before sending it back since I got a good deal on it. I can't get into the recovery by pressing F9. I can get to bios by pressing F2. I try to use the recovery...
Well I finished my project - the program script allows me to create MBR and GPT hard drive partitions with a recovery image partition. The script also allows me to install 3 different versions of windows. and lastly it allows me to capture a recovery (push button reset) image. which can then be...
If you have a recovery drive - that includes the recovery partition - made on one computer, but have a toshiba laptop with a bad drive (but the recovery partition is ok), can you replace/copy the partition on the recovery drive with the recovery partition from the bad laptop HD? My friend's...
New Laptop - I successfully resized, partition 600gb to 500gb --- 100gb unallocated space as i thought i will dual boot (8 MONTHS Ago) Decided dont want to - Want to know EXTEND unallocated space - But CANT :( :mad: I easily shrinked it but cant extend it When right clicking the...
Hello I have Dell XPS 8300 and made a set of dvds when I got the machine. I don't remember if I made them before or after a Dell tech deleted my recovery partition. I have since made a Win 8 dvd from the downloaded iso file and using the library, moved to Win 8.1. I am asking if there is a way...
Recovery Partition in General Support
On the OEM laptop I got came with it own recovery partition I would like to make something like this for the desktop I made so that I can restore my desktop to newly installed pulse with office and drivers installed and a few other programs, without having to use my windows DVD or recovery disk.
Hello everyone, I'm a technician at TigerDirect, and for one of our services we create recovery media for newly purchased machines. For Windows 8 machines (As I'm sure you know) we cannot create recovery disks, and have to create a recovery drive using a flash drive. On multiple occasions...
