Maintenance in progress problem
    Windows
    Hi All,
    Wondering if anyone had this problem recently?
    I turned on my computer this morning and checked out a few sites and then started to do some chores. An hour later I came back to my computer and clicked on iexplorer to do more viewing and it didn't pop up ..only the hour glass just spinning around. I glanced at the taskbar and noticed the flag had a time on it. I moved the mouse to it and it said
    " maintenance in progress" . I right-clicked to bring up the action center but nothing happened. I pressed the ctrl-alt-del but the task manager didn't come up either. My system was not responding to any keys I selected. This is the first time it ever happened to me.
    Why does windows maintenance stop all action while it is doing this operation. I am thinking if it is defragging my drives it could take hrs This could ruin my day off and not be able to use my computer.
    Holding the power button was the only way to stop this and restart my computer. not very pleased with how windows 8 is so controlling
    cheers
    Windows 8 Pro Windows 8.1 Preview
    Windows
    Thank you for the reply, that link is very helpful, I saved for future use.
    I was mostly wondering if anyone else had that same problem as I experienced this morning. I find it strange that windows 8 actually stopped all my actions.
    It is quite possible for maintenance to slow down your response time. Especially if you have many processes running in the background and your processor power is not adequate to handle all those processes + maintenance functions at the same time (with extra power to spare). Hope this helps you. Good luck.
    Windows
    Very true but didn't think I had very much running. I thought my system was adequate. I have a P5E3 Deluxe Intel® X38 chipset
    Intel®Core™2 Duo, E8400 3.0, and 8 gb of DDR3-1600 G.Skill ram F3-12800CL9D, HIS Radeon HD 6870 Iceq x 900 MHz 1gb.
    I shall watch and see what happens on the next maintenance.
    thanks again for the reply
    win8.1.1 enterprise
    ,interesting ,i just checked mine and it ran just about 1 hr ago ,[even though its set to run a 3am ,my computer is rarely on at 3am ]
    and i didn't even notice it
    Quote Originally Posted by caperjack View Post
    It might be a good idea for you to compare your maintenance settings with the OPs for starters to make sure you are both comparing apples-to-apples. Just a thought.
How to Change "Automatic Maintenance" Settings in Windows 8 and 8.1 Windows depends on execution of inbox and third party maintenance activity for much of its value-add, including Windows Update, and automatic disk defragmentation, as well as antivirus updates and scans. Additionally,...
Starting 2 or 3 weeks ago, I can't restart. It will give the blue screen with the spinning circle and say "operations are in progress, please wait". I've waited as long as 50 minutes and it never gets past that point. I have to power down. And the first time I hold down the power button, it...
When my 8.1 laptop lost time and I didn't understand why I looked in Control Panel/System Security/Action Centre and altho the Automatic Maintenance says No action needed the last run date is unknown and Windows was unable to determine the last date maintenance was run. If I try to Start...
Hi there One minor irritant with the consumer preview is that 3 times I've had a Maintenance in Progress panel come up Disk light on computer halts or is slow until activity finishes I can't find out what its doing or how to turn this off --on a small Netbook this KILLS what is...
changing progress bar color in Customization
hi, has anybody figured a way a out to change the progress bar color? i am talking about the bar that pops up when installing software. i hate that green color MS forces on us every version of windows!!! :mad:
Man oh man! I love pinball! The last time I ever played pinball on a Windows PC was 2002!! :eek: I love the new pinball game in Windows 8, I'm addicted. But theoretically, I should be able to advance to new and different tables from what I've found about the game on Xbox. Does anyone know how to?
Can We Put A Windows 8 Progress Bar on This Forum?, i think this would be a good way to keep track the development of Windows 8.:D
