Maintenance in progress problem
Scramjet
Hi All,
Wondering if anyone had this problem recently?
I turned on my computer this morning and checked out a few sites and then started to do some chores. An hour later I came back to my computer and clicked on iexplorer to do more viewing and it didn't pop up ..only the hour glass just spinning around. I glanced at the taskbar and noticed the flag had a time on it. I moved the mouse to it and it said
" maintenance in progress" . I right-clicked to bring up the action center but nothing happened. I pressed the ctrl-alt-del but the task manager didn't come up either. My system was not responding to any keys I selected. This is the first time it ever happened to me.
Why does windows maintenance stop all action while it is doing this operation. I am thinking if it is defragging my drives it could take hrs :( This could ruin my day off and not be able to use my computer.
Holding the power button was the only way to stop this and restart my computer. not very pleased with how windows 8 is so controlling :)
cheers
    Windows
    Intel
    Intel Core 2 duo E8400
    Asus P5E3 Deluxe x38
    G.Skill F3-12000CL7D DDR3-1600 8GB
    HIS Radeon 6850 Turbo IceQ X 1GB GDDR5
Thank you for the reply, that link is very helpful, I saved for future use.
I was mostly wondering if anyone else had that same problem as I experienced this morning. I find it strange that windows 8 actually stopped all my actions.
    Windows
    Intel
It is quite possible for maintenance to slow down your response time. Especially if you have many processes running in the background and your processor power is not adequate to handle all those processes + maintenance functions at the same time (with extra power to spare). Hope this helps you. Good luck.
    Windows 8 Pro Windows 8.1 Preview
Very true but didn't think I had very much running. I thought my system was adequate. I have a P5E3 Deluxe Intel® X38 chipset
Intel®Core™2 Duo, E8400 3.0, and 8 gb of DDR3-1600 G.Skill ram F3-12800CL9D, HIS Radeon HD 6870 Iceq x 900 MHz 1gb.
I shall watch and see what happens on the next maintenance.
thanks again for the reply
    Windows
    Intel
,interesting ,i just checked mine and it ran just about 1 hr ago ,[even though its set to run a 3am ,my computer is rarely on at 3am ]
and i didn't even notice it
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
It might be a good idea for you to compare your maintenance settings with the OPs for starters to make sure you are both comparing apples-to-apples. Just a thought.
