[Problem]Unsupported 16-Bit Application !
    Hello ,,
    I have a problem , no words .. Here's a Picture
    I search for a solution for this problem ,, I found this:
    Enable 16 bit application support on Windows 8
    But I didn't find that application on my Windows 8 ,, So I need help from you Guys .
    Regards
    Capt.Jack Sparrow,
    windows 8.1
    you cant run 16bit programs on 64bit windows.
    also that fact that the folder seems a little piratey to me. and it shouldnt be discussed here.
    and vice city doesnt have an app called p.exe
    Quote Originally Posted by dskiller View Post
    Hello ,,
    You're right that there's no p.exe in Gta ,,But this will appear when you unRIP it .
    I hope that there's any other way to run it! I need full game not a half !
    Regards
    Capt.JackSparrow,
    Windows 10 Pro (x64)
    Yo you can get the game for $5 before July 22, 2013 on Steam
    Save 50% on Grand Theft Auto: Vice City on Steam
    So yeah like others said it seems either you bought the game from the wrong place or you should avoid shady sites.
    USA, Idaho
    Win 8, (VM win7, XP, Vista)
    Quote Originally Posted by jozef View Post
    Hello ,,
    Regards
    Capt.JackSparrow,
    VMWare, or Virtual Box. You can use either of these to setup a Virtual Machine then load up XP into a VM, and then you can run your 16 bit applications/programs. . .Good Luck
Hi, recently I installed latest Windows 8.1 update (Update 1/Spring update), and later latest Beta Nvidia driver. After that, an strange problem showed up, which is annoying and hard to explain (especially with my poor English :p). I recorded a video which represents it (look at the thumbnail...
here is a video of the problem with explanation https://www.youtube.com/watch?v=f72OJQtZans in summary, the window and cursor shifts position when the maximized window is demaximized then moved towards the left then right.This applies to the right then left aswell. Any suggestions?
i need help here because i'm planing to run old games on my windows 8 64 bit but it looks i can't even install i started with (prince of percia warrior within) but in the middle of installation o get the message (unsupported 16-bit application) so i think this will happen to the rest of the games i...
I recently downloaded a app from windows 8.1 store but got the error and the apps did not install. 31701
Read more at source: Microsoft to deliver fix for Surface RT users hit by application-update problems | ZDNet
Hello everyone and Happy New Year, I am here cause I want to ask you for any solutions for my problem. I am trying to install GTA EFLC in Windows 8 (Officially Activated) but I get the following message: Starting Installation via Autorun.exe: Unsupported 16-bit Application. The Program or...
Hello. I have a Lumia 710, and I want to connect my phone with my Windows 8 laptop via Windows Phone application. But the problem is that the mobile does not get recognized in the application. Is there any problems with the app or maybe my software problems? Thank you
