Power Options not working
    Kent UK
    Hi can anyone out there help me. The power options on my computer have stopped working. The screen does not dim or turn off automatically and the computer does not sleep automatically.
    I bought my HP Pavilion 20 all in one desktop two weeks ago and then power options stopped working a week ago everything else seems OK. I looked in the console and "balance" is checked, going further, all the times are set (display dimmed 5 mins, turn off display 10 mins, put computer to sleep 30 mins). A day or so before this happened I replaced the standard (rather cheap and cheerful) wired keyboard and mouse with a Logitech k360 Keyboard and m326 mouse (both wireless). I can put the computer to sleep using the keyboards sleep button. I also temporarily changed the "Put Computer to Sleep" section in Power Options console to "never" when "Windows Photo Gallery" needed to update the face recondition on my photos transferred from my old computer (it took over 24 hours). After "Windows Photo Gallery" had finished I changed it back to 30 mins and since then no power options.
    I am a novice at going into the settings of the computer. Thanks in advance for any ideas.
    Peter
    Maryland USA
    Power Plan Reset/Restore
    Download this batch file and execute, it will reset your power plan to its original settings
    PowerPlanReset.bat
    Kent UK
    Thanks
    Thanks for your help and advice but regrettably this did not work.
    Maryland USA
    I am sorry, i forgot to say to run this as administrator..
    right click it and run as administartor
    Kent UK
    Thanks - Brooklyn567
    Thanks now all working. I am very grateful
    Peter
I went into my power options to change some of the advanced settings and most of them are missing? I am on windows 8.1 with a week old Surface Pro 3. I want to say I read somewhere that hyper-v can cause options to be missing, but I honestly don't even know what that is and I don't have it...
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
all power options are gone! in General Support
hey guys. does any driver relate to power settings? i recently installed some driver for intel devices and graphics does them probably cause problem?
I installed windows 8 on a desktop computer that had windows 7 before. Screensaver was working perfectly on windows 7. Since windows 8, the screensaver won't start, the display won't turn off after 15 minutes like I set it up in power options. Just to test, I removed all USB devices that could...
Solved Power options not working when set? in Performance & Maintenance
I've been having this horrible problem lately where my power options aren't working. Its stuck on my first settings. If I change it, it saves and says I changed it, but then it doesn't work. I have been trying to change my power button for awhile now and it just won't change. Its stuck on hibernate...
Solved Power options in Performance & Maintenance
A while back, Brink showed a way to setup so that you could right-click on the desktop for some power options one of which was “shutdown”. I had it working when I had the evaluation edition and liked it. I now have installed the update Pro. But, I forgot how to do it. Can anyone refresh my mind?...
