Power Options Problems
    windows 8 Release Preview
    Hi
    I get a lot of random freezing on Windows 8 Pro on my Acer aspire laptop that has i5 core and 8gb of ram.
    I was told to put my power option onto High Performance instead of balanced which is the recommended. I was also told that balance power and power saver both have bugs in them on Win 8 and this maybe the reason i am getting freezes. Has anyone else had this problem or is aware of it?
    Thank You for replying
    Andrew
    Maryland USA
    In my experience High Performance on a laptop generates alot of heat which can damage your processor, video card, and/or battery if left unchecked. If you have temperature monitors that can notify you of dangerous temperatures or even throttle down or shutdown your system then thats fine, its safe to leave in high performance.. There are viruses that consume 100% of your CPU to create such a problem.. You can tweak your High Performance settings to throttle down the processor when it starts getting too hot, and leave all the other benefits the same. The bottom line is if your system runs cool most of the time, then no worries. If your system runs a little warm like mine then balanced is the safe zone for me.. I dont notice the throttle down most of the time since I usually use low cpu intensive apps and pretty much only browse the web.. I did create a kind of a kill switch for when my laptop is running hot and im not there to catch it, it puts the computer to 50% processor speed, which cools it down pretty quickly and notifies me by lowering the screen brightness.. Thats my opinion, everyone has one.. Lets hear from others...
    What do you use your laptop for? Mainly internet or actual programs that require CPU.. What are your laptop specs? cores? speed?
    Right now im on high performance and my temps are only 150F with two youtube videos running, thats good for me.. But if i run programs as well, it will jump..
    High performance does not put your computer to sleep.. ever.. unless you tweak it to allow sleep..
I went into my power options to change some of the advanced settings and most of them are missing? I am on windows 8.1 with a week old Surface Pro 3. I want to say I read somewhere that hyper-v can cause options to be missing, but I honestly don't even know what that is and I don't have it...
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
Power options revert in Installation & Setup
Hi In Control Panel I have my Power options set to High Performance with "Turn off Display" set to Never, this has been the case since day however two days ago it reverted to "Turn off Display" After 20 Mins, I reset it to Never but it reverts again after rebooting. Any idea why and how I...
all power options are gone! in General Support
hey guys. does any driver relate to power settings? i recently installed some driver for intel devices and graphics does them probably cause problem?
Power Options Problems in Performance & Maintenance
Hi I get a lot of random freezing on Windows 8 on my Acer aspire laptop that has i5 core and 8gb of ram. I was told to put my power option onto High Performance instead of balanced which is the recommended. I was also told that balance power and power saver both have bugs in them on Win 8 and...
Solved Power options in Performance & Maintenance
A while back, Brink showed a way to setup so that you could right-click on the desktop for some power options one of which was “shutdown”. I had it working when I had the evaluation edition and liked it. I now have installed the update Pro. But, I forgot how to do it. Can anyone refresh my mind?...
