Power Options Problems
    windows 8 Release Preview
    Hi
    I get a lot of random freezing on Windows 8 on my Acer aspire laptop that has i5 core and 8gb of ram.
    I was told to put my power option onto High Performance instead of balanced which is the recommended. I was also told that balance power and power saver both have bugs in them on Win 8 and this maybe the reason i am getting freezes. Has anyone else had this problem or is aware of it?
    Thank You for replying
    Andrew
    Viewing through Windows 7, me like-a-discuss 8 though
    What you're describing is a poor workaround made for not having updated drivers AND/OR having poor 3rd party junk drivers.
    Choose the power plan you would like as they are all fine and well, while paying attention to my previous sentence.
    Keep drivers updated and don't install junky software. Research on Google if any software is in question.
    Windows 8.1 Professional 64-bit
    There is no "massive" difference between those options. If you look closely, only the settings are different. For example, the screen-saver and turning off the hard-drive when not in use are enabled in the Balanced option. I'm not aware of any bugs with these options.
    Also, you have Windows 8 "Release Preview" listed under your "OS". Perhaps you should consider upgrading to the official Windows 8 and get the latest patches. That will likely remedy any issues you're facing.
    Maryland USA
    Check your system for unwanted programs that attached themselves with normal programs.
    Run Spybot Search and Destroy v1.62 (not 2.0)
    It will flush those annoying ads, web redirectors, hijackers, toolbars and other malicious programs that overload your system..
    Also do a chkdsk /f from the command prompt, for errors on the drive that cause the system to stutter and pause when reading data..
    And check with your normal virus scanner as well..
    The power settings will not cause problems unless they are tweaked to the point where the user forgets what theyve done and are unable to restore the original settings..
    Lastly, if youve done allot of installing and uninstalling of programs and also moving files on and off your computer, you should defrag the harddrive. Ive only had this OS on a month and I was already 15% fragmented, from the constant modifications and testing..
I went into my power options to change some of the advanced settings and most of them are missing? I am on windows 8.1 with a week old Surface Pro 3. I want to say I read somewhere that hyper-v can cause options to be missing, but I honestly don't even know what that is and I don't have it...
How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8 What is a link A USB connection between two USB ports. For example, between your PC and a USB 3.0 device. The downstream port (DS port) of a host or a hub. The upstream port (US port) of an attached device...
Power options revert in Installation & Setup
Hi In Control Panel I have my Power options set to High Performance with "Turn off Display" set to Never, this has been the case since day however two days ago it reverted to "Turn off Display" After 20 Mins, I reset it to Never but it reverts again after rebooting. Any idea why and how I...
all power options are gone! in General Support
hey guys. does any driver relate to power settings? i recently installed some driver for intel devices and graphics does them probably cause problem?
Power Options Problems in Performance & Maintenance
Hi I get a lot of random freezing on Windows 8 Pro on my Acer aspire laptop that has i5 core and 8gb of ram. I was told to put my power option onto High Performance instead of balanced which is the recommended. I was also told that balance power and power saver both have bugs in them on Win 8...
Solved Power options in Performance & Maintenance
A while back, Brink showed a way to setup so that you could right-click on the desktop for some power options one of which was “shutdown”. I had it working when I had the evaluation edition and liked it. I now have installed the update Pro. But, I forgot how to do it. Can anyone refresh my mind?...
