Solved [HELP] Constant Lag Spikes
Ouchey
Hello Dan Here!
I've been dealing with this for days and still have it happening as im typing this. Ever since a few weeks back, my PC has been really messed up. When i start up my PC i sign in as normal and all is fine...untill about 10-20secs later, when my PC has CONSTANT lag spikes causing sound to distort and make awful sounds! I have used DPC Latency Checker and i have LOTS of Red bars all the way up to the top of the chart. It says i have misbehaving drivers but i have gone through all the devices (Well most of them...there are alot) in my device manager that i know isnt that important and disabled, then re-enabled them, and i have had no success. I tried a program called "Speed up my PC" which checks for registry errors, and it said there were alot! I was happy then because i thought i found the problem...but then i used the program to fix them and still...SO MANY LAG SPIKES! I then used the free trial version of drivermax, a program that checks for outdated drivers, but still no success (Btw dont use drivermax, it gives you the wrong drivers causing you to have to re-install them all over again). I've checked LOADS of forums over the web but no success either. Ive never posted a thread on a forum before because normally someone else has the same problem and i can fix it how they did, but this time im not so lucky. Thanks for listening to me ramble on for ages, but i really need to fix this as im a heavy PC gamer and need it to get the stress off from all the school work!
Image of DPC latency:
Thanks in advance for the help i REALLY appreciate it!
Oh nearly forgot my specs xD:
Intel Q6600 2.40Ghz
4.00GB RAM
NVidia Geforce GTX 550Ti
Windows 8 Pro 32bit
Byeeee!
-Dan
    Windows 8 Pro 32bit
    intel Core 2 Quad CPU Q6600 @ 2.40Ghz
    Nvidia nForce 680i SLI
    4.00GB
    Geforce GTX 550 Ti
    1440x900
    Logitech G510
    Roccat kone XTD
    Chrome
I have done a virus test with Malware Bytes and Windows defender, and they have both found nothing. When i start my PC now i can do things for about 20mins now before everything fu... messes up :sarc:.
    Windows 8 Pro 32bit
    4.00GB
    Geforce GTX 550 Ti
    1440x900
    Logitech G510
    Roccat kone XTD
    Chrome
Windows 8 Compatibility: The DPC latency utility runs on Windows 8 but does not show correct values. The output suggests that the Windows 8 kernel performs badly and introduces a constant latency of one millisecond which is not the case in practice. DPCs in the Windows 8 kernel behave identical to Windows 7. The utility produces incorrect results because the implementation of kernel timers has changed in Windows 8 which causes a side effect with the measuring algorithm used by the utility. Thesycon is working on a new version of the DPC latency utility and will make it available on this site as soon as it is finished.
DPC Latency Checker for Windows 7, Windows 7 x64, Windows Vista, Windows Vista x64, Windows Server 2003, Windows Server 2003 x64, Windows XP, Windows XP x64, Windows 2000
Beside that, I get normal values:
Uploaded with ImageShack.us
I use Driver Genius Professional to check my drivers, if I'm too lazy to do it manually.
Looks like a fresh Windows-Install should be the fastest option to see if it's driver related, as your system should run without any issues with standart drivers.
Then you should just check your latency again, after every driver-update. If you get after a fresh-install of Windows straight trouble, then it could be maybe Hardware related.
    Windows-10-Pro-Build-11099.rs1-x64
    Custom-Build
    Intel Core i7 3770k @4800MHz
    Asus P8Z77-V
    G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
    2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
    OnBoard Realtek® ALC892 8-Channel High Definition Audio
    Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
    - Samsung 840 EVO SATA3 500GB
    - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
    - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
    Corsair AX1200i
    Thermaltake Level-10 GT LCS
    EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
    Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
    ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    - Logitech Extreme 3D Pro Joystick
    - Plantronics GameCom Commander Headset
    - Logitech X-210 Speakers
    - Roccat Taito Mid-Size 5mm
    - PC-Master-Race MousePad (yellow)
Just completely re-installed windows 8 and have had no problems so far :D . I have just checked DPC latency checker and its much better!
DPC Latency:
Now i only have one problem...I have to install Battlefield 3 (20GB!) AND all the DLC (About 25GB!) ALL OVER AGAIN!
Thanks for the help i really appreciate it! I will mark this as solved in about an hour when i know its definitely working!
-Dan
    Windows 8 Pro 32bit
    4.00GB
    Geforce GTX 550 Ti
    1440x900
    Logitech G510
    Roccat kone XTD
    Chrome
Spoke to soon... Just about a minute after i posted the previous post, the lag spikes returned:
I have a theory though... Maybe its Windows 8?
When i was re installing Windows 8, i had to install Windows XP because i have got the download version of windows 8 which requires an operating system to install it. while i was in XP everything worked perfectly! I was in XP for along time because i had to somehow get the drivers for my network adapter without internet connection, and there were no problems!
This makes me wonder...
Are some parts of my computer (Network adapter etc.) not compatible with Windows 8, but are with Windows XP?
...or...
Is there just a general problem with windows 8, that i may have been unlucky to run into?
Hope i can get a reply to this quick so i can get this fixed!
Thanks
-Dan
EDIT: The Lag spikes are no longer constant, they will ocasionaly start but will then stop after a while. for the last 5mins or so i have had (once again) no problems, but im sure the spikes will strike again soon.
    Windows 8 Pro 32bit
    4.00GB
    Geforce GTX 550 Ti
    1440x900
    Logitech G510
    Roccat kone XTD
    Chrome
I am not sure what is causing it however i disabled windows search index service and my lag spikes are not so constant either. But it does not seem to be hardware related because i am running windows 8 64x i7 3630QM with a 650m 2gb vram 8gb ram dual HDD 1tb +500gb and i get the huge lag spikes as well. Many theories floating around but disabling the windows search helped me out alot. Also make sure you have no external hard drives attached.
    windows 8 Pro x64
There is no need to re-download BF3 if you backed-up the Origin-Folder.
Maybe it's normal to get the spikes sometimes.
Have a look at my System and see how many hardware I have connected.
My System never freezes.
Edit:
I let the Latency Checker run for a longer period of time and had no spikes at all.
    Custom-Build
    Asus P8Z77-V
    Corsair AX1200i
What programs do you have running tonschuh? startup and such A/V anti-spyware or malwayre? Super Anti-Spyware and malwayre bytes as well as eset and bit defender (installed the bit defender and eset on separate clean installs) and all would spike even when not scanning or updating at the same time as system would causing severe lag lol. So at one point it would be eset and system or bit defender and system or malwayre bytes and system etc
    windows 8 Pro x64
I use only Windows Defender.
My Start-Up:
Beside this I run Windows-Live! Mail and Chrome with 45 open Pages and this here:
(click-able)
Main-Desktop:
    Custom-Build
    Asus P8Z77-V
    Corsair AX1200i
What application is that that shows your CPU usage gpu etc? I would love that. Ahh so my speculation may be correct in assuming the spikes have something to do with the combination of malwayre spyware and anti viurs software. Since mine usually spiked with 2 or more installed.
    windows 8 Pro x64
You can find them here.
    Custom-Build
    Asus P8Z77-V
    Corsair AX1200i
I've fixed the lag spikes! I cant tell you exactly what i did to fix these but ill tell you what i did...
First i replugged all my gpu, cpu and hard drive cables as some may have been loose
Then i went through device manager again and this time found 2 mice and 3 keyboards in there, i found the ones i was using and disabled the other ones.
One of the things above fixed this problem and i think it may have been the duplicate mice and keyboards doing something.
So give these a try and hopefully one will fix yours!:thumbsup:
    Windows 8 Pro 32bit
    4.00GB
    Geforce GTX 550 Ti
    1440x900
    Logitech G510
    Roccat kone XTD
    Chrome
