Battery Pluged In, Not Charging
    India
    Windows 8.1, Windows 8, Windows 7, Windows XP (VirtualBox)
    Hello,
    I m using Windows 8. Everything goes smooth. The only issue is when my laptop is connected to AC Supply, it does not charges. As far as I remove AC supply, laptop dies out.
    I have tried disabling Battery driver from device management, with no luck!
    Any help would be appreciated
    How old is your laptop? One possibility is your battery died prematurely. It could also be an issue with your system board.
    India
    Hi, My laptop is 2.5 years old..
    win8.1.1 enterprise
    thats old enough to have a dead battery !
Alienware Not Charging in Drivers & Hardware
Hello All, I just bought an Aloenware 14 with the following specs: Windows 8.1 Pro 1 tb sata 256 GB ssd 16gb ram Intel integrated graphics NVIDIA gforce card
Hi, sorry for my bad english, I speak french. My problem is: One month ago, my battery was working good (2h+), and the day after, I decided to change room, so I unplugged the laptop (The battery was still in it) and... Everything shuts down :mad: The laptop wasn't working anymore if it was...
Solved Plugged in not charging in Drivers & Hardware
Ive tried to uninstall the ACPI compliant control driver, but that does not work. The problem comes over and over. Does anyone have a more permenant solution?
I just did a clean install of Windows 8 Pro on my 3 years old Asus Laptop. Everything seems to be working fine, except for the battery indicator and some Asus Fn keys.. The battery cannot be charged, it keeps showing 0% charging even after a few hours. I tried disabling and re-enabling the...
Battery Charging in Performance & Maintenance
:confused:In windows 7 I was able to maximize my battery life with 80% available not charging. I'd like to change this as it shortens my time when unplugged. How do I do this?
Hi anyone getting this? Any way to resolve? Thanks
