power settings
    power settings
    What is the difference between balanced power setting versus performance power setting? I've been doing some googling about but there are only some references to laptops for actual performance gains. There was no clear answers as to what those settings are for each.
    When overclocking, you try to get the most out of your cpu, same with High Performance. Balanced Power Plan allows cpu throttling to 50% of the front side bus speed. The display and hardware power savings are also utilized, but not at the same level as Power Saver mode.
power settings
Windows 8.1 Power settings automated in Performance & Maintenance
hey guys, I build out tons of machines of all makes and models for demo scenarios. One of the things that is the same on all devices is our custom power settings. Is there a way to copy the power settings and apply them to any new laptop we build out? Example: Laptop 1: Power...
I have a Surface Pro 3 and am unable to independently set the ‘Turn Off Display After’ and the ‘Put The Computer to Sleep’ settings different from each other when plugged in to power. When I change them and save them to different settings, they both revert back to the same setting the next time I...
Hi everyone, My screensaver and power setting to turn off the display has stopped working, and these were working the other day. The only thing I have changed is I updated iTunes. I have tried a system restore to before this and this did not fix this. Among other things I have tried a clean...
Best Power Settings - Win 8 Server in Performance & Maintenance
Hi all, Please could someone advise, direct me to some advice on what the best settings are if I am using Windows 8 as a server. I was it to be as eco as possible shutting off when not in use but quickly booting when necessary. I have heard of software's that do this but don't know; 1)...
Power Settings Not Maintained in Performance & Maintenance
Hi, I have made a cutomised power configuration for my laptop, which prevents it from shutting down etc, when it's on main power.. It works OK, but keeps resetting itself to the Balanced (default) configuration after a couple of days. Any advice please?:think:
Solved Can't switch power settings in Performance & Maintenance
Hi, My little sister just got a new Asus X201E Laptop with Windows 8. The problem is that it is not possible to switch between a "power saving" and "performance" profiles. Every time I try to select the "power saving" mode, it jumps back to the "performance" :( The screenshot is in Czech but...
