power settings
USA
What is the difference between balanced power setting versus performance power setting? I've been doing some googling about but there are only some references to laptops for actual performance gains. There was no clear answers as to what those settings are for each.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
When overclocking, you try to get the most out of your cpu, same with High Performance. Balanced Power Plan allows cpu throttling to 50% of the front side bus speed. The display and hardware power savings are also utilized, but not at the same level as Power Saver mode.
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
