appearance problem with won 8
    Hello All;
    Recently i installed windows 8 for my laptop (HP DV6)
    Realy it's very nice and quick, But
    I faced small problem related of appearance of start menu as shown
    (unpin,Uninstall, smaller.....etc) icon !!!
    image clarify what i;m taking about
    I try to repair that with windows 8 DVD but no solution
    Your help is highly appreciated
    unfortunately it doesn't solve my problem
    Download the attachment i posted, extract it, right click on the file, then click install.
    Click yes if asked to replace font.
    appearance problem with won 8 Attached Files
    Quote Originally Posted by MrShowdown View Post
    Thank you very very much
    its OK now
    Your welcome.
    I had a similar issue except my entire windows 8 desktop, control panel, and website urls changed to symbols. I used the attachment you posted and it fixed my problem but only temporarily. I restarted my computer after downloading the attachment and my text switched back to symbols again. Any suggestions?
    Win 8.1 Pro
    Does anyone know WHY this happens?
    Fixed the text on Windows 8
    Thank you so much! This solved the issue on my PC when I tried to make a new User Account. Just by installing the font, the text reverted back. Just make sure you hit the right button when you install the font haha.
    It still didn't help me.. Text is still partially shown in symbols.
    Dialog boxes in software also lack buttonsClick image for larger version
    Attached Thumbnails Attached Thumbnails Screenshot (15).png   Screenshot (16).png
Page 1 of 2 12 LastLast
Appearance issue with windows 8.1 in Performance & Maintenance
Hello, I first encountered this problem in Intel graphics control panel.As you can see in the screenshots Intel Graphics control panel doesn't show the scaling options in different windows of Intel thoroughly. 57347 57348 57349 There's another similar issue in my windows 8.1.Look at the...
I have alot of my current sites and programs accessible via icons on my screen. With Windows8, they say this cannot be done since it is a "tab-based" screen (I use a mouse, not my fingers). I disagree, I am certain when I do get my new PC set up with Windows8, I ought to be able to configure my...
Inactive Window Appearance. in General Support
I was just wondering if anyone had found a way to alter the border of inactive windows yet. I'm still finding it really annoying and awkward. All windows are merging into one. I was hoping 8.1 might have solved the issue, but I can't find it. I thought it worth stating a new thread just to...
Solved slow mouse appearance in General Support
Since an update a few days ago my mouse is taking about 2/3 minutes to appear after going back to my PC after it has been left for a while. I have checked all USB ports, used another mouse but it still has this problem, Once it gets itself going it is fine. Can anyone help. Thanks.
color appearance in Customization
Where is the color appearance? just like windows 7?
Solved performance & and appearance in Performance & Maintenance
In XP on my desktop, I could go into Control Panel >> Display and under the Appearance and Advanced buttons, I could modify the way my screen looked with great ease. On my laptop running Win 8, I can't find the route to do this. Can anyone help me please? Michael.
The First Taste of Windows 8 in Early January 2011 - Softpedia
