Performance Problems after system running for two or more
    System is a Gateway with 4GB of memory running Win 8 Pro.
    System is placed in hibernation daily.
    After two days the system performance degrades to the point of making the system unusable. Applications will take 5 minutes to load, even Internet Explorer. Network performance degrades. Task Manager shows multiple instances of programs that were launched but not running, even Chrome. The only fix is to shutdown and restart the PC.
    Arnhem, The Netherlands
    Windows 8.1 Pro x64 Media Center Edition
    Wow..... that ain't funny . I've never experienced this since I quit using Windows 98SE.
    What kind of programs do you have running in the background? I'm sure it's not Windows that makes the pc turn slow. It must be a program or an app you've installed that is flushing your memory.
    Did you encouter this problem right after the installation of Windows? Or did it occur recently? Try to figure out what you've installed since then and try removing those programs/ apps to see if it upgrades the performance of your pc.
    Good luck with it!
    This problem is very recent, around 2 weeks ago. I have not install any NEW programs but have upgraded two or three of them. Other that the monthly Windows updates no other changes have been made.
    Webster NY US
    Win 7 / Win 8
    Have you done a virus/malware scan?
    fwiw
    Win8pro upgrade here would slowly use up more and more memory.
    I thought maybe it was most frequent prog cache building but it builds forever,
    until I reinstalled the Intel rapid storage driver. Which was shat was using all that memory.
    Quote Originally Posted by mbratch View Post
    Have you run a FULL virus/malware scan yet? Perhaps your pc is infected?
    Did you do a clean install of Windows 8 or an upgrade from a existing Windows 7/ Vista installation? In the latter case you might want to consider uninstalling ALL the DRIVERS and reinstalling them. By doing that the drivers are properly configured for Windows 8 usage only.
    In my case this did the trick for a semi-crappy videoperformance while playing Civilization V. Just uninstalled all the drivers and reinstalled them.
Howdy! , after fixing the BSOD error my computer doesn't seem to show an error... although its performance has decreased a lot and plus i am facing problems in connecting to internet through USB. The problems are: 1. slow performance ( its been acting much slower every since i fixed BSOD...
How to Generate and View a System Performance Report in Windows A System Performance Report details the status of local hardware resources, system response times, and processes on the local computer. You can use this information to identify possible causes of performance issues. This...
performance counter problems in Performance & Maintenance
Hi All Lately I seem to get a lot of those errors(Perflib) in the even viewer. See attached file. Is anyone able to help me with that? Thanks
I'll explain the story: Do not even been a week since this notebook was unfortunately "caught" in the update that results in "Boot Loop" system (search on Google and find many cases, but it seems that not all machines were affected) I was super whore and such, but as I had back up data on external...
I recently had to return my HP Pavilion g7 Windows 8 64- bit only laptop to the manufacturer for repair under warranty. Prior to this I created a system image as the Hard Disc was going to be replaced. Having now received the repaired laptop I have been trying to restore the saved image. I watched...
Problems running downloads in Software and Apps
I apologise if this has been raised in another thread - I'm sure it probably has but the nature of problem is such that it would be impossible to search the forums for it (because words like "download" and "installation" are so frequent!) I have a computer that came with Windows 8 installed. We...
Read more at source: Are SSDs the new RAM for boosting system performance? | ZDNet
