Best Tools for Fully Cleaning System?
  1. #11
    Quote Originally Posted by CeejayMode View Post
    Quote Originally Posted by totfit View Post
    I have never had an issue with CCleaner and default settings. That being said just don't mess with regedit or check advanced settings and there is really nothing that should mess with anything that will "break" things. I use it regularly and have for years.
    Awesome! Thanks for the opinion, because I'm kind of nervous to use it after last time...
    Problem is, I think I edit things in the registry too much, even one wrong character can screw up the whol registry.
    Here is how to fix the registry if CCleaner messes it up. If you search on "ccleaner problems," then you will see that a variety of users claim a variety of problem related to CCleaner--besides registry issues.
  2. #12
    Strathpine, Queensland
    Windows 8 Pro 64 Bit
    Quote Originally Posted by jimbo45 View Post
    Hi there
    You don't really need ANYTHING these days -- Windows 8 has decent collection garbage routines.
    If you MUST - don't bother with some rubbish 3rd party apps like CCleaner.
    Simply backup the drive (Disk mode back up rather than Partition Image mode ) to another partition / external disk - re-format the original and restore from the backup you've just taken. -- Job done simply, quickly and easily -- and you've got a backup into the bargain too.
    Ensure that the restore isn't done sector by sector as you'll just be restoring a mirror image of the original disk, The standard restore will restore the files with as little as possible waste of cluster space and minimize the use of long cluster chains.
    Things like Acronis should work perfectly in these situations. Much better than Windows Defrag or whatever.
    For Uninstalling programs -- use the Programs and Features in the control panel -- it really does work far better than W7.
    Windows 8 isn't Windows 7 so a lot of what one used in W7 isn't applicable any more or is just a waste of time -- as per any "Pro" versions of 3rd party "Un-installers". Totally a waste of money on W8.
    Cheers
    jimbo
    Hey there.
    Thanks for the advice, I'll give that a go in the morning. Hopefully it fixes the system wide lag.
    Ceejay.
  3. #13
    I never ask, but what have you done in trying to deal with your lag issue besides maybe some cleaning. Your optons are not as attractive since doing a repair install is not available anymore--at least in general. You could aways try an automatic repair or running sfc /scannow--trying to find some low-hanging fruit.
  4. #14
    Quote Originally Posted by znod View Post
    I'll give it a try. I did do a defrag earlier and it fixes most lag, and I'm tossing up whether or not to upgrade to 8GB RAM or an SSD...
  5. #15
    Was the lag there originally--whatever you consider originally to be? If, yes, then, your posited upgrades could help.
  6. #16
    Alrighty. I heard an SSD might help, so I'll upgrade both the memory and storage.
Page 2 of 2 FirstFirst 12
1 is there any way of completely making a computer 100 percent clean of virusses etc before backing it or making restore points ?? 2 is there any way to make backups of windows 8 after the pc was cleaned and burn it to a dvd ?? i dont want to make backups to usb or portable hard drives...
Hello, I have uninstalled my synaptics mouse pad driver and wanted to boot pc in safe mode but then Bit Defender rescue scan menu pops up and gives me option to Reboot and Shutdown. I tried both options but all of them give me same result and bring me back to the Rescue Scan. I then tried to scan...
Solved Computer Cleaning software in Software and Apps
To fix or not to fix, that is the question. How do we know which computer cleaning software is telling the truth and not just throwing false positives on the screen? I just tried CCleaner and it told me it had cleaned up the Reg; deleted 522mb junk and a couple of other bits Then ran...
Solved Cleaning up. in Performance & Maintenance
Can anyone help me with this problem?A couple of times,I've got the message "Cleaning up,do not turn off your computer".The first time it happened,I had closed the lid on my laptop which put it to sleep,and on opening the lid,I got the message.I left it for half an hour and then decided to force...
Hi, Since NVIDIA chose to remove fan settings out of the driver, they have moved all those settings to System Tools. So I was wondering if someone has tried OC System Tools 6.08 in Windows 8 64-bit? Thanks!
Hi, I am new to this forum, your advice is requested. Recently I just upgraded to Windows 8 Pro over my Windows 7 Pro on my really old machine 1.6G Centrino, the hard drive is only 40G, the overall installation went through without any problems. I found Windows 8 Pro provides better memory...
