Shutdown Hang and WiFi problem
    Windows 8 Pro x64
    I'm not sure if this is the right place to post this but it seemed like the best choice.
    I recently upgraded from Windows 7 to Windows 8 Pro from Microsoft Dreamspark. The installation went well and my Laptop was working fine for a few days. After a few days I got a hang at shutdown and had to force shutdown the laptop. It never happened again until a few shutdowns later. Again, after this occurrence it was fine until 2-3 shutdowns later. I booted up my laptop to my second problem which I have only had twice to date. The booting was fine and I logged in. I noticed that the wifi was not connected to anything so I clicked on the icon hoping it would come up with the 'connect to' window. The 'connect to' window never appeared so I decided to disable the adapter and re-enable it. Trying to disable the adapter failed (although it never said anything) and the device still said it was enabled. I then restarted the laptop only to have it hang on the restart screen. After the restart everything was fine and the cycle of 2-3 good shutdowns to a bad shutdown started again. After having the wifi problem again and the laptop hanging at restart I have decided that I need some help with this. I believe the two problems might be connected with something to do with the wifi service not turning off? I am hoping someone here will know how to fix this and can give me the instructions on how to do so.
    Thanks in advance.
    Try uninstalling your WiFi and reinstalling it, then update your driver.
    Also go here:Blue Screen of Death (BSOD) Posting Instructions - Windows 7 Forums, download and follow the steps, then upload your logs.
    It might give clues to what is going on with your machine.
    Windows 8 Pro x64
    The shutdown problem solved itself when I updated my WiFi drivers (Windows Update decided to give me really old ones) but the WiFi problem remains. The only time it has happenned is today since the times above and appears to have something to do with the fast shutdown feature. It would show the 'Connect to' window but it said there were no networks (my phone was connected to it so the router is fine).
Every time I restart or shutdown my laptop, running Win 8.1 pro, the wifi is disabled (missing from Device Manager) and the light on the keyboard that indicates wifi on/off turns orange = off. When I boot from a shutdown I am able to press the button to turn it on light shows white. However, when I...
So explorer.exe has been crashing once in a while after I reboot my PC from a sleep state. I tried troubleshooting it myself but to no avail. There is also a windows error in event viewer. Problems: Explorer.exe Freeze/hangs indefinitely, cannot restart/end task via task manager via...
I just bought a sony laptop with windows 8. The side panel power options(shutdown and restart) and alt+f4 are not working to shutdown the laptop. Only holding the hardware power button for 4 seconds is working to shutdown the laptop. Please help and thank you in advance.
Hi! This is my first post so please bear with my question :) I have a big problem with my laptop. It is running on windows 8.1. The 'shutting down' and 'shut down anyway' screens somewhat turned like windows 2000 shutdown style. :cry: It has windows that have 'end now' and 'cancel' options. I...
Hi All, Win8: I have two wifi APs in the home and I have it all set up so that one is the Internet by cell phone tether and the other is the cabled network via the router wifi. Works just fine - except. On wifi 1, Internet I have it set for "Connect automatically" which at boot up it...
Shutdown Problem in General Support
Hello, Just recently my laptop didn't shutdown properly. I have to force off it by pressing the Power button. I wonder what could cause this problem. I'm afraid if this keeps happening it could harm my computer in a way. When I shutdown my laptop, it is in a shutting down process, the screen...
windows 8 shutdown/restart problem in Performance & Maintenance
hi i have recently bought a samsung series 5 laptop with windows 8 installed on it. after a week or so, my laptop would not shut down or restart. i have read previous forms and i have tried everything. when i click on shutdown, or restart, nothing happens. there is no error, nothing. i have tried...
