Internet connectivity problems [need your help]
sdkkds
I currently have huge difficulties and would like to seek your advices.
I've been all day trying to find out whats wrong with my internet.
The problem that im facing is that while my internet works perfectly fine (eg. youtube, online games), my computer can't seem to download particular files. For eg. I can download google chrome installation file. However, once i try to install it, it can't finish downloading and stops at 99%. For better understanding, i've attached some pictures.
It's making me so mad that i probably am not organized so let me summarize below:
1. Internet works fine. (streaming, youtube, preinstalled and updated mmorpg games)
2. when updating games (downloading update files) or installing new browsing platform (chrome, firefox) i can download the actual installation file, but when you open the file, and download begins, it won't work. (refer to images)
Sry that it is in korean but it's on download stage which is never ending.
You expert's advices will be very appreciated.
Best regards,
Pat.
    windows 8.1 64x
More pictures from steam. The images end up breaking like this for some of them.
And on my task manager, the wifi connectivity is sort of on and off. As a newb, i don't know if it's normally supposed to do that or not.
Sry that it is in Korean.
Any advices will be very appreciated.
Best regards,
Pat.
    windows 8.1 64x
Steam download is just like my wifi signal too.. on and off...no idea why...
Really frustrating..
    windows 8.1 64x
Welcome to the forum. What is your internet speed do you have an limits on how much you can download? Is it the same if you use network cable. What antivirus do you use
    win 8 pro
Thank you for your kind words Samuria.
First i thought it was internet problem. So i checked it with another device (wife's laptop) and it worked perfectly fine.
So this led me to believe that it might be the wifi device on my desktop (the one with problems).
So then i moved it to our living room to connect it to the ethernet cable.
Still same problem.
This rules out internet service provider, or wifi device (IPTIME).
This brings me to think that the problem lies with the computer itself.
The weird thing is that, when i restart my desktop multiple times (sometimes 4+ tries, sometimes half a day of restarting), it works with full download speed. don't know the exact speed but when it works, it will download 7Gb in ~10 minutes.
Plus, i bought the computer couple months ago...it's a new computer.
I can't really pick out whats wrong with it.
just yesterday, i've tried to update all drivers, and they are already updated.
Any help will be very appreciated.
Pat.
    windows 8.1 64x
Please download and save FRST 64bit or FRST 32 bit to your Desktop see if this tells us anything.
http://download.bleepingcomputer.com/farbar/FRST.exe
http://download.bleepingcomputer.com/farbar/FRST64.exe
Right click to run as administrator (XP users click run after receipt of Windows Security Warning - Open File). When the tool opens click Yes to disclaimer.
Make sure that Addition option is checked.
Press Scan button.
It will produce a log called FRST.txt in the same directory the tool is run from.
Please copy and paste log back .
The first time the tool is run it generates another log (Addition.txt - also located in the same directory as FRST.exe/FRST64.exe).
    win 8 pro
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 02-07-2017
Ran by admin (03-07-2017 22:27:28)
Running from C:\Users\admin\Downloads
Windows 8.1 (Update) (X64) (2017-01-02 03:14:09)
Boot Mode: Normal
==================== Accounts: =============================
admin (S-1-5-21-3449503849-2698387126-3059338809-1001 - Administrator - Enabled) => C:\Users\admin
Administrator (S-1-5-21-3449503849-2698387126-3059338809-500 - Administrator - Disabled)
Guest (S-1-5-21-3449503849-2698387126-3059338809-501 - Limited - Disabled)
==================== Security Center ========================
(If an entry is included in the fixlist, it will be removed.)
AV: Windows Defender (Disabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
AV: Panda Protection (Enabled - Up to date) {46AEFD02-ACA3-E038-1FA5-4A15EFD361E0}
AS: Windows Defender (Disabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
AS: Panda Protection (Enabled - Up to date) {FDCF1CE6-8A99-EFB6-2515-716794542B5D}
FW: Panda Firewall (Disabled) {7E957C27-E6CC-E160-34FA-E3201100269B}
==================== Installed Programs ======================
(Only the adware programs with "Hidden" flag could be added to the fixlist to unhide them. The adware programs should be uninstalled manually.)
Adobe Acrobat Reader DC - Korean (HKLM-x32\...\{AC76BA86-7AD7-1042-7B44-AC0F074E4100}) (Version: 17.009.20044 - Adobe Systems Incorporated)
Adobe Flash Player 26 PPAPI (HKLM-x32\...\Adobe Flash Player PPAPI) (Version: 26.0.0.131 - Adobe Systems Incorporated)
AhnLab Safe Transaction (HKLM\...\{19DD1D8D-927F-45DF-ADF4-75D38267848D}) (Version: 1.3.19.873 - AhnLab, Inc.)
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 382.05 - NVIDIA Corporation) Hidden
AnySign4PC 1.1.0.5 (HKLM-x32\...\AnySign4PC) (Version: 1.1.0.5 - SoftForum Co., Ltd.)
Apple Mobile Device Support (HKLM\...\{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}) (Version: 10.0.1.3 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
Apple 응용 프로그램 지원(32비트) (HKLM-x32\...\{9BA1A894-B42F-4805-BC8C-349C905A3930}) (Version: 5.3.1 - Apple Inc.)
Apple 응용 프로그램 지원(64비트) (HKLM\...\{7EAC8A42-9FAC-4F6B-AABF-C08C9F2E0F13}) (Version: 5.3.1 - Apple Inc.)
Battle.net (HKLM-x32\...\Battle.net) (Version: - Blizzard Entertainment)
Bonjour (HKLM\...\{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.)
Chrome (HKLM-x32\...\Google Chrome) (Version: 59.0.3071.115 - Google Inc.)
Daum게임 스타터 (HKLM\...\Daum게임 스타터_is1) (Version: 1.0.0.1 - Kakao Games Corp.)
Daum게임 컨트롤러 (HKLM\...\Daum게임 컨트롤러_is1) (Version: 1.0.0.1 - Kakao Games Corp.)
Delfino G3 (x86) 버전 3.3.2.7 (HKLM-x32\...\{1CBD185A-9CB3-4f30-B7E4-75CC551455F9}_is1) (Version: 3.3.2.7 - Wizvera)
Dota 2 (HKLM\...\Steam App 570) (Version: - Valve)
eISP 1.0 (HKLM-x32\...\eISP) (Version: 1.0 - )
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
iniLINE CrossEX Service (HKU\S-1-5-21-3449503849-2698387126-3059338809-1001\...\iniLINE_CrossEX) (Version: 1.0.2.2 - iniLINE Co., Ltd.)
INISAFE Cert Client v1 (HKLM-x32\...\INISAFE Cert Client v1) (Version: 1.1.0.17 - initech, Inc.)
INISAFE Mail v4 (HKLM-x32\...\INISAFE Mail v4) (Version: 4.4.0.60 - initech, Inc.)
INISafe SFilter v7.2 (HKLM-x32\...\UnINISafeWeb7) (Version: 7.2.0.16 - (c)INITECH)
Intel(R) Management Engine Components (HKLM\...\{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 11.0.0.1162 - Intel Corporation)
Intel(R) Rapid Storage Technology (HKLM\...\{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 14.8.0.1042 - Intel Corporation)
Intel(R) USB 3.0 Host Controller Adaptation Driver (HKLM\...\{9472AEE5-5D4D-4329-8BD8-B282FD33B8E0}) (Version: 1.0.1.45 - Intel Corporation)
IPinside LWS Agent (HKLM-x32\...\IPinside LWS Agent) (Version: 3.0.0.3 - interezen)
iTunes (HKLM\...\{9D0D2A8B-7E7B-4D88-8D50-24286ED6A5EB}) (Version: 12.5.5.5 - Apple Inc.)
Malwarebytes 버전 3.1.2.1733 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.1.2.1733 - Malwarebytes)
Microsoft ASP.NET MVC 4 Runtime (HKLM-x32\...\{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
Microsoft Office 2007 Service Pack 3 (SP3) (HKLM-x32\...\{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{6E107EB7-8B55-48BF-ACCB-199F86A2CD93}) (Version: - Microsoft)
Microsoft Office Enterprise 2007 (HKLM-x32\...\ENTERPRISE) (Version: 12.0.6612.1000 - Microsoft Corporation)
Microsoft Office Excel 2007 Help 업데이트 (KB963678) (HKLM-x32\...\{90120000-0016-0412-0000-0000000FF1CE}_ENTERPRISE_{DEA3DED2-5CB8-4FD3-BE1B-7C0412D4117F}) (Version: - Microsoft)
Microsoft Office File Validation Add-In (HKLM-x32\...\{90140000-2005-0000-0000-0000000FF1CE}) (Version: 14.0.5130.5003 - Microsoft Corporation)
Microsoft Office Powerpoint 2007 Help 업데이트 (KB963669) (HKLM-x32\...\{90120000-0018-0412-0000-0000000FF1CE}_ENTERPRISE_{98189FA0-E081-4DBD-84DE-8FB66BF4AC6C}) (Version: - Microsoft)
Microsoft Office Word 2007 Help 업데이트 (KB963665) (HKLM-x32\...\{90120000-001B-0412-0000-0000000FF1CE}_ENTERPRISE_{15B9412E-6769-4CEA-8A83-39FEDB1F3499}) (Version: - Microsoft)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729 (HKLM-x32\...\{887868A2-D6DE-3255-AA92-AA0B5A59B874}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 (HKLM-x32\...\{9A25302D-30C0-39D9-BD6F-21E6EC160475}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 (HKLM-x32\...\{9BE518E6-ECC6-35A9-88E4-87755C07200F}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 (HKLM\...\{1D8E6291-B0D5-35EC-8441-6616F567A0F7}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 (HKLM-x32\...\{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 (HKLM-x32\...\{050d4fc8-5d48-4b8f-8972-47c82c46020f}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501 (HKLM-x32\...\{f65db027-aff3-4070-886a-0d87064aabb1}) (Version: 12.0.30501.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24215 (HKLM-x32\...\{d992c12e-cab2-426f-bde3-fb8c53950b0d}) (Version: 14.0.24215.1 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32\...\{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
MPEG2코덱(libmpeg2/mad) (HKLM-x32\...\MPEG2코덱(libmpeg2/mad)) (Version: - )
nProtect KeyCrypt V6.5 (HKLM-x32\...\npkfx) (Version: 6.5 - INCA Internet Co., Ltd.)
nProtect Netizen v5.5 (HKLM-x32\...\nProtect Netizen v5.5) (Version: 2016.5.9.1 - INCA Internet Co., Ltd.)
NTSMagicLineMBX (HKLM-x32\...\NTSMagicLineMBX) (Version: 1.0.10.12 - Dreamsecurity Inc.)
NVIDIA 3D Vision 드라이버 382.05 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 382.05 - NVIDIA Corporation)
NVIDIA 3D Vision 컨트롤러 드라이버 369.04 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 369.04 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.2.2.49 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.2.2.49 - NVIDIA Corporation)
NVIDIA Miracast 가상 오디오 376.33 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Miracast.VirtualAudio) (Version: 376.33 - NVIDIA Corporation)
NVIDIA PhysX 시스템 소프트웨어 9.16.0318 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
NVIDIA 그래픽 드라이버 382.05 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 382.05 - NVIDIA Corporation)
NvNodejs (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.2.2.49 - NVIDIA Corporation) Hidden
NvTelemetry (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 2.0.2.1 - NVIDIA Corporation) Hidden
NvvHci (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvvHci) (Version: 2.02.0.2 - NVIDIA Corporation) Hidden
Panda Devices Agent (HKLM-x32\...\{3F9548B2-0B34-4453-A92E-35056B053F19}) (Version: 1.08.00 - Panda Security) Hidden
Panda Devices Agent (HKLM-x32\...\Panda Devices Agent) (Version: 1.03.08 - Panda Security) Hidden
Panda Protection (HKLM\...\{52F9D0C3-E6CF-4553-9013-8F2E834BD0B1}) (Version: 8.91.00 - Panda Security) Hidden
Panda Protection (HKLM-x32\...\Panda Universal Agent Endpoint) (Version: 18.1.0 - Panda Security)
Panda Safe Web (HKLM-x32\...\pandasecuritytb) (Version: 4.3.1.23 - Panda Security and Visicom Media Inc.)
PLAYERUNKNOWN'S BATTLEGROUNDS (HKLM\...\Steam App 578080) (Version: - Bluehole, Inc.)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 8.43.1001.2015 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7727 - Realtek Semiconductor Corp.)
Secure KeyStroke 4.0 (HKLM-x32\...\SoftcampSCSK) (Version: - )
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0351 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 3.2.2.49 - NVIDIA Corporation) Hidden
Steam (HKLM-x32\...\Steam) (Version: 2.10.91.91 - Valve Corporation)
TouchEn nxKey with E2E for 32bit (HKLM-x32\...\TouchEn nxKey) (Version: 1.0.0.51 - RaonSecure Co., Ltd.)
Update for 2007 Microsoft Office System (KB967642) (HKLM-x32\...\{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{C444285D-5E4F-48A4-91DD-47AAAA68E92D}) (Version: - Microsoft)
Update for Korean Microsoft IME Standard Dictionary (HKLM\...\{75A54180-CA5E-47B8-AFBB-29337B976B21}) (Version: 16.0.662.1 - Microsoft Corporation)
Veraport(보안모듈 관리 프로그램) G3 - 3,7,0,1 (HKLM-x32\...\{2D992E01-604B-472C-A883-1DDA105A24D5}_is1) (Version: 3,7,0,1 - Wizvera)
Vulkan Run Time Libraries 1.0.42.1 (HKLM\...\VulkanRT1.0.42.1) (Version: 1.0.42.1 - LunarG, Inc.)
WIZVERA Process Manager 1,0,2,7 (HKLM-x32\...\{8941A397-4065-4F41-92CE-0EB610846EED}_is1) (Version: 1,0,2,7 - WIZVERA)
XecureWeb Control (HKLM-x32\...\XecureWeb Control) (Version: 7, 2, 8, 6 - SoftForum Co., Ltd.)
μTorrent (HKU\S-1-5-21-3449503849-2698387126-3059338809-1001\...\uTorrent) (Version: 3.4.9.43388 - BitTorrent Inc.)
검은사막 클라이언트 (HKLM-x32\...\검은사막_is1) (Version: - Kakao Games Corp)
곰TV 플러그인 (HKLM-x32\...\GomTV Launcher Plugin) (Version: 1.0.0.3 - Gretech Corporation)
곰플레이어 (HKLM-x32\...\GOM Player) (Version: 2.3.10.5266 - Gretech Corporation)
꿀뷰 (HKLM\...\Honeyview) (Version: 5.19 - 반디소프트)
민원24 민원발급프로그램 5.0 (HKLM-x32\...\{00DB3E20-1C01-4CAC-BA7E-9C5B5C287BC9}_is1) (Version: 5.0.0.1 - SGA Solutions Co.,Ltd.)
알집 10.6 (HKLM-x32\...\ALZip_is1) (Version: v10.6 - ESTsoft Corp.)
알툴즈 업데이트 (HKLM-x32\...\ALUpdate_is1) (Version: v16.10 - ESTsoft Corp.)
인텔® 칩셋 장치 소프트웨어 (HKLM-x32\...\{c7f54569-0018-439c-809a-48046a4d4ebc}) (Version: 10.1.1.9 - Intel(R) Corporation) Hidden
카카오톡 (HKLM-x32\...\KakaoTalk) (Version: 2.5.6.1545 - Kakao Corp.)
==================== Custom CLSID (Whitelisted): ==========================
(If an entry is included in the fixlist, it will be removed from the registry. The file will not be moved unless listed separately.)
CustomCLSID: HKU\S-1-5-21-3449503849-2698387126-3059338809-1001_Classes\CLSID\{9B6D38F3-8EF4-48A5-AD30-FFFFFFFFFFFF}\InprocServer32 -> C:\Program Files\Honeyview\HVShell64.dll (Bandisoft.com)
ContextMenuHandlers01: [0HVContext] -> {9B6D38F3-8EF4-48A5-AD30-FFFFFFFFFFFF} => C:\Program Files\Honeyview\HVShell64.dll [2017-02-26] (Bandisoft.com)
ContextMenuHandlers01: [ALZip] -> {4EB37360-49E8-11D3-95B5-004033382980} => C:\Program Files (x86)\ESTsoft\ALZip\AZCTM64.dll [2016-12-14] (ESTsoft Corp.)
ContextMenuHandlers01: [UAContextMenu] -> {A9B8E64D-3F7E-4D32-8FC9-E391DEE67D75} => C:\Program Files (x86)\Panda Security\Panda Security Protection\PSUAShell.dll [2017-02-23] (Panda Security, S.L.)
ContextMenuHandlers01: [XXX Groove GFS Context Menu Handler XXX] -> {6C467336-8281-4E60-8204-430CED96822D} => -> No File
ContextMenuHandlers02: [ALZip] -> {4EB37360-49E8-11D3-95B5-004033382980} => C:\Program Files (x86)\ESTsoft\ALZip\AZCTM64.dll [2016-12-14] (ESTsoft Corp.)
ContextMenuHandlers03: [XXX Groove GFS Context Menu Handler XXX] -> {6C467336-8281-4E60-8204-430CED96822D} => -> No File
ContextMenuHandlers04: [0HVContext] -> {9B6D38F3-8EF4-48A5-AD30-FFFFFFFFFFFF} => C:\Program Files\Honeyview\HVShell64.dll [2017-02-26] (Bandisoft.com)
ContextMenuHandlers04: [ALZip] -> {4EB37360-49E8-11D3-95B5-004033382980} => C:\Program Files (x86)\ESTsoft\ALZip\AZCTM64.dll [2016-12-14] (ESTsoft Corp.)
ContextMenuHandlers04: [XXX Groove GFS Context Menu Handler XXX] -> {6C467336-8281-4E60-8204-430CED96822D} => -> No File
ContextMenuHandlers05: [ALZip] -> {4EB37360-49E8-11D3-95B5-004033382980} => C:\Program Files (x86)\ESTsoft\ALZip\AZCTM64.dll [2016-12-14] (ESTsoft Corp.)
ContextMenuHandlers05: [NvCplDesktopContext] -> {3D1975AF-48C6-4f8e-A182-BE0E08FA86A9} => C:\Windows\system32\nvshext.dll [2017-05-02] (NVIDIA Corporation)
ContextMenuHandlers05: [UAContextMenu] -> {A9B8E64D-3F7E-4D32-8FC9-E391DEE67D75} => C:\Program Files (x86)\Panda Security\Panda Security Protection\PSUAShell.dll [2017-02-23] (Panda Security, S.L.)
ContextMenuHandlers05: [XXX Groove GFS Context Menu Handler XXX] -> {6C467336-8281-4E60-8204-430CED96822D} => -> No File
ContextMenuHandlers06: [ALZip] -> {4EB37360-49E8-11D3-95B5-004033382980} => C:\Program Files (x86)\ESTsoft\ALZip\AZCTM64.dll [2016-12-14] (ESTsoft Corp.)
ContextMenuHandlers06: [UAContextMenu] -> {A9B8E64D-3F7E-4D32-8FC9-E391DEE67D75} => C:\Program Files (x86)\Panda Security\Panda Security Protection\PSUAShell.dll [2017-02-23] (Panda Security, S.L.)
ContextMenuHandlers06: [XXX Groove GFS Context Menu Handler XXX] -> {6C467336-8281-4E60-8204-430CED96822D} => -> No File
ContextMenuHandlers1_S-1-5-21-3449503849-2698387126-3059338809-1001: [0HVContext] -> {9B6D38F3-8EF4-48A5-AD30-FFFFFFFFFFFF} => C:\Program Files\Honeyview\HVShell64.dll [2017-02-26] (Bandisoft.com)
ContextMenuHandlers4_S-1-5-21-3449503849-2698387126-3059338809-1001: [0HVContext] -> {9B6D38F3-8EF4-48A5-AD30-FFFFFFFFFFFF} => C:\Program Files\Honeyview\HVShell64.dll [2017-02-26] (Bandisoft.com)
==================== Scheduled Tasks (Whitelisted) =============
Task: {2028DF0C-6EFC-4AD3-AA80-937B08866BC6} - System32\Tasks\NvDriverUpdateCheckDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [2017-01-06] (NVIDIA Corporation)
Task: {262135E1-90F3-42FA-95C4-76841DA4A787} - System32\Tasks\NvTmRep_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [2017-01-06] (NVIDIA Corporation)
Task: {27EBA839-CBF2-4E8B-B441-1C6739B2D88D} - System32\Tasks\NvTmMon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmMon.exe [2017-01-06] (NVIDIA Corporation)
Task: {2D9B43B7-6EE9-46DD-BD20-E607B301E707} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2017-04-25] (Adobe Systems Incorporated)
Task: {33A7B0A1-DCAA-4987-8385-97386B80A624} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2017-07-02] (Google Inc)
Task: {36A2E8FF-C526-4AA0-B13D-70C415A098D4} - System32\Tasks\NvProfileUpdaterOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2017-01-06] (NVIDIA Corporation)
Task: {4AFB5FDA-4135-479D-A695-17FA8410018A} - System32\Tasks\Adobe Flash Player PPAPI Notifier => C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_131_pepper.exe [2017-06-27] (Adobe Systems Incorporated)
Task: {67704A44-BDB7-4280-9810-03113A290638} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2017-07-02] (Google Inc)
Task: {A26AC79A-1BB8-4947-BDD4-9CA2F602D508} - System32\Tasks\shutdown => C:\Windows\System32\shutdown.exe [2014-11-21] (Microsoft Corporation)
Task: {A271E92C-6E47-4311-8CC8-064B14EC178F} - System32\Tasks\NvNodeLauncher_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\NvNode\nvnodejslauncher.exe [2017-01-06] (NVIDIA Corporation)
Task: {B3E82439-FFDD-442F-80E3-D217A7020310} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2016-02-23] (Apple Inc.)
Task: {BBC41E47-0D9D-4E84-B25F-1C0973CB15EC} - System32\Tasks\NvTmRepOnLogon_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvTmRep.exe [2017-01-06] (NVIDIA Corporation)
Task: {C376FE1C-91BC-4775-A006-0D89B5404E9D} - System32\Tasks\NvProfileUpdaterDaily_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} => C:\Program Files\NVIDIA Corporation\Update Core\NvProfileUpdater64.exe [2017-01-06] (NVIDIA Corporation)
Task: {D7B95CAB-1A83-4EC7-B45F-66E270DBC1EF} - System32\Tasks\Adobe Flash Player Updater => C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2017-06-27] (Adobe Systems Incorporated)
(If an entry is included in the fixlist, the task (.job) file will be moved. The file which is running by the task will not be moved.)
==================== Shortcuts & WMI ========================
(The entries could be listed to be restored or removed.)
==================== Loaded Modules (Whitelisted) ==============
2017-01-13 13:56 - 2017-01-13 13:56 - 00092472 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
2017-01-13 13:56 - 2017-01-13 13:56 - 01353528 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
2017-01-29 22:53 - 2017-01-06 10:12 - 04490808 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\Poco.dll
2017-01-29 22:53 - 2017-01-06 10:12 - 01148984 _____ () C:\Program Files\NVIDIA Corporation\NvContainer\libprotobuf.dll
2017-03-31 23:00 - 2017-03-31 23:00 - 00376952 _____ () C:\Program Files (x86)\VP\VPWalletService\VPWalletService.exe
2017-06-18 21:33 - 2015-10-30 14:07 - 01108755 _____ () C:\Program Files\AhnLab\Safe Transaction\RunTmp\klib.dll
2017-07-02 17:09 - 2017-06-23 12:21 - 03807064 _____ () C:\Program Files (x86)\Google\Chrome\Application\59.0.3071.115\libglesv2.dll
2017-07-02 17:09 - 2017-06-23 12:21 - 00100184 _____ () C:\Program Files (x86)\Google\Chrome\Application\59.0.3071.115\libegl.dll
2016-04-06 16:36 - 2016-04-06 16:36 - 00120840 _____ () C:\Program Files (x86)\SoftForum\XecureWeb\AnySign\dll\xwm_smartcard.dll
2015-12-03 14:11 - 2015-12-03 14:11 - 00014336 _____ () C:\Program Files (x86)\SoftForum\XecureWeb\AnySign\dll\KEBSFSC_WR.dll
2015-12-03 14:13 - 2015-12-03 14:13 - 00143360 _____ () C:\Program Files (x86)\SoftForum\XecureWeb\AnySign\dll\NSLDAP32V50.dll
2015-12-16 02:17 - 2015-12-16 02:17 - 00618544 _____ () C:\Program Files (x86)\Panda Security\Panda Security Protection\SQLite3.dll
2017-01-29 22:53 - 2017-01-06 10:11 - 00020536 _____ () C:\Program Files (x86)\NVIDIA Corporation\Update Core\detoured.dll
2017-01-29 22:53 - 2017-01-06 10:12 - 03776056 _____ () C:\Program Files (x86)\NVIDIA Corporation\NvContainer\Poco.dll
2017-01-29 22:53 - 2017-01-06 10:12 - 00901688 _____ () C:\Program Files (x86)\NVIDIA Corporation\NvContainer\libprotobuf.dll
2017-01-29 23:39 - 2017-05-17 10:54 - 00678176 _____ () C:\Program Files (x86)\Steam\SDL2.dll
2017-01-29 23:39 - 2016-09-01 10:02 - 04969248 _____ () C:\Program Files (x86)\Steam\v8.dll
2017-01-29 23:39 - 2017-06-08 14:42 - 02485536 _____ () C:\Program Files (x86)\Steam\video.dll
2017-01-29 23:39 - 2016-09-01 10:02 - 01563936 _____ () C:\Program Files (x86)\Steam\icui18n.dll
2017-01-29 23:39 - 2016-09-01 10:02 - 01195296 _____ () C:\Program Files (x86)\Steam\icuuc.dll
2017-01-29 23:39 - 2016-01-27 16:49 - 02549760 _____ () C:\Program Files (x86)\Steam\libavcodec-56.dll
2017-01-29 23:39 - 2016-01-27 16:49 - 00491008 _____ () C:\Program Files (x86)\Steam\libavformat-56.dll
2017-01-29 23:39 - 2016-01-27 16:49 - 00332800 _____ () C:\Program Files (x86)\Steam\libavresample-2.dll
2017-01-29 23:39 - 2016-01-27 16:49 - 00442880 _____ () C:\Program Files (x86)\Steam\libavutil-54.dll
2017-01-29 23:39 - 2016-01-27 16:49 - 00485888 _____ () C:\Program Files (x86)\Steam\libswscale-3.dll
2017-01-29 23:39 - 2017-06-08 14:42 - 00877856 _____ () C:\Program Files (x86)\Steam\bin\chromehtml.DLL
2017-01-29 23:39 - 2016-07-05 07:17 - 00266560 _____ () C:\Program Files (x86)\Steam\openvr_api.dll
2017-01-29 23:41 - 2017-05-09 04:45 - 69516064 _____ () C:\Program Files (x86)\Steam\bin\cef\cef.win7\libcef.dll
2017-06-09 11:25 - 2017-05-17 10:54 - 00678176 _____ () C:\Program Files (x86)\Steam\bin\cef\cef.win7\SDL2.dll
2017-01-29 23:39 - 2017-06-08 14:42 - 00385312 _____ () C:\Program Files (x86)\Steam\steam.dll
2017-01-29 23:39 - 2015-09-25 08:52 - 00119208 _____ () C:\Program Files (x86)\Steam\winh264.dll
2014-11-30 18:49 - 2014-11-30 18:49 - 00884736 _____ () D:\Black Desert\bin64\host\libglesv2.dll
2014-11-30 18:49 - 2014-11-30 18:49 - 00104448 _____ () D:\Black Desert\bin64\host\libegl.dll
2014-11-30 18:49 - 2014-11-30 18:49 - 00862208 _____ () D:\Black Desert\bin64\host\ffmpegsumo.dll
==================== Alternate Data Streams (Whitelisted) =========
(If an entry is included in the fixlist, only the ADS will be removed.)
==================== Safe Mode (Whitelisted) ===================
(If an entry is included in the fixlist, it will be removed from the registry. The "AlternateShell" will be restored.)
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\NanoServiceMain => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\PSUAService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\NanoServiceMain => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\PSUAService => ""="Service"
==================== Association (Whitelisted) ===============
(If an entry is included in the fixlist, the registry item will be restored to default or removed.)
==================== Internet Explorer trusted/restricted ===============
(If an entry is included in the fixlist, it will be removed from the registry.)
==================== Hosts content: ===============================
(If needed Hosts: directive could be included in the fixlist to reset Hosts.)
2013-08-22 22:25 - 2013-08-22 22:25 - 00000824 _____ C:\Windows\system32\Drivers\etc\hosts
==================== Other Areas ============================
(Currently there is no automatic fix for this section.)
HKU\S-1-5-21-3449503849-2698387126-3059338809-1001\Control Panel\Desktop\\Wallpaper -> D:\Downloads\사진\Pictures\green_not_harrassing_you_the_person_that_thinks_they_desktop_1920x1200_wallpaper-366921.png
DNS Servers: 168.126.63.1 - 168.126.63.2
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System => (ConsentPromptBehaviorAdmin: 5) (ConsentPromptBehaviorUser: 3) (EnableLUA: 1)
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer => (SmartScreenEnabled: RequireAdmin)
Windows Firewall is enabled.
==================== MSCONFIG/TASK MANAGER disabled items ==
==================== FirewallRules (Whitelisted) ===============
FirewallRules: [TCP Query User{D0BF5D4E-3D37-45CF-B674-E2418EBEAE94}C:\program files (x86)\ipinside_lws\i3gproc.exe] => (Allow) C:\program files (x86)\ipinside_lws\i3gproc.exe
FirewallRules: [UDP Query User{7A4958FC-761A-4FC1-BA8F-4C097FA7124D}C:\program files (x86)\ipinside_lws\i3gproc.exe] => (Allow) C:\program files (x86)\ipinside_lws\i3gproc.exe
FirewallRules: [{BD48FDA5-88E1-4EDA-88E9-969BE93EB380}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{B41EB265-EBA7-495A-A8C4-1C1330FDCE90}] => (Allow) C:\Program Files (x86)\Steam\Steam.exe
FirewallRules: [{BBC6678C-513F-4C9E-9C51-823F8579C622}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe
FirewallRules: [{181243E6-BB0A-4E18-8B3D-4E23006B71A8}] => (Allow) C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe
FirewallRules: [{0982A645-C6B2-47B5-A554-C9F420884011}] => (Allow) C:\Program Files\AhnLab\Safe Transaction\StSess.exe
FirewallRules: [TCP Query User{1D4F2192-D606-4DE2-B27D-873F9B734AED}C:\program files (x86)\google\chrome\application\chrome.exe] => (Allow) C:\program files (x86)\google\chrome\application\chrome.exe
FirewallRules: [UDP Query User{2C125D10-1371-4ECF-9FCB-03F623B20CDF}C:\program files (x86)\google\chrome\application\chrome.exe] => (Allow) C:\program files (x86)\google\chrome\application\chrome.exe
FirewallRules: [TCP Query User{C68F3EE3-B31D-4E2E-9A0F-AAC1BC2CD0AA}C:\program files (x86)\steam\steamapps\common\pubg\tslgame\binaries\win64\tslgame.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\pubg\tslgame\binaries\win64\tslgame.exe
FirewallRules: [UDP Query User{7E07A26B-F75A-4604-B4E6-BB088E0CA115}C:\program files (x86)\steam\steamapps\common\pubg\tslgame\binaries\win64\tslgame.exe] => (Allow) C:\program files (x86)\steam\steamapps\common\pubg\tslgame\binaries\win64\tslgame.exe
FirewallRules: [TCP Query User{E953FB85-3F4C-40C5-AEA2-E8AAB8A6D318}C:\program files (x86)\ipinside_lws\i3gproc.exe] => (Allow) C:\program files (x86)\ipinside_lws\i3gproc.exe
FirewallRules: [UDP Query User{892F9CBB-EBBA-49C6-9DB1-A1DC8846DCF5}C:\program files (x86)\ipinside_lws\i3gproc.exe] => (Allow) C:\program files (x86)\ipinside_lws\i3gproc.exe
FirewallRules: [TCP Query User{3BF6FB56-DB8C-43AA-8579-5C7AE7F8C2AC}C:\users\admin\appdata\roaming\utorrent\utorrent.exe] => (Allow) C:\users\admin\appdata\roaming\utorrent\utorrent.exe
FirewallRules: [UDP Query User{5D1EDFBB-D76D-4038-9897-173ECB473E3B}C:\users\admin\appdata\roaming\utorrent\utorrent.exe] => (Allow) C:\users\admin\appdata\roaming\utorrent\utorrent.exe
FirewallRules: [{DBBB34D5-D4F7-4D59-9C0F-32CBEB3DFEB1}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\dota 2 beta\game\bin\win64\dota2.exe
FirewallRules: [{AC4077AC-0D98-487E-9A83-1BC22750B114}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\dota 2 beta\game\bin\win64\dota2.exe
FirewallRules: [{57FE4F78-E790-480F-AEC2-2E1DF2B9ED8A}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\dota 2 beta\game\bin\win64\dota2cfg.exe
FirewallRules: [{AA5917FE-079B-4078-9127-D3D0F7FE4360}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\dota 2 beta\game\bin\win64\dota2cfg.exe
FirewallRules: [{784F90FD-3A7B-405D-A5EF-47D64EEF3FEB}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\dota 2 beta\game\bin\win64\dota2.exe
FirewallRules: [{E7C32BAF-E83D-47AE-8191-099416261A71}] => (Allow) C:\Program Files (x86)\Steam\steamapps\common\dota 2 beta\game\bin\win64\dota2.exe
==================== Restore Points =========================
16-06-2017 22:00:08 Windows 업데이트
24-06-2017 10:11:23 Windows 업데이트
27-06-2017 21:14:29 Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501
02-07-2017 16:20:13 복원 작업
02-07-2017 17:12:20 Windows 모듈 설치 관리자
02-07-2017 17:55:56 Windows 모듈 설치 관리자
==================== Faulty Device Manager Devices =============
==================== Event log errors: =========================
Application errors:
Error: (07/03/2017 10:24:49 PM) (Source: SideBySide) (EventID: 59) (User: )
Description: "C:\Users\admin\Downloads\FRST64.exe"에 대한 활성화 컨텍스트를 생성하지 못했습니다. manifest 또는 정책 파일 "C:\Users\admin\Downloads\FRST64.exe"의 0줄에서 오류가 발생했습니다.
잘못된 Xml 구문입니다.
Error: (07/03/2017 10:24:23 PM) (Source: SideBySide) (EventID: 59) (User: )
잘못된 Xml 구문입니다.
Error: (07/03/2017 10:23:57 PM) (Source: SideBySide) (EventID: 59) (User: )
잘못된 Xml 구문입니다.
Error: (07/03/2017 10:01:14 PM) (Source: Application Error) (EventID: 1000) (User: )
Description: 오류 있는 응용 프로그램 이름: NVIDIA Share.exe, 버전: 55.2883.1519.2, 타임스탬프: 0x586ee888
오류 있는 모듈 이름: libcef.dll, 버전: 3.2883.1519.0, 타임스탬프: 0x584eef70
예외 코드: 0x80000003
오류 오프셋: 0x00e44459
오류 있는 프로세스 ID: 0x1a30
오류 있는 응용 프로그램 시작 시간: 0x01d2f3fc7380973b
오류 있는 응용 프로그램 경로: C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
오류 있는 모듈 경로: C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\libcef.dll
보고서 ID: b13e4903-5fef-11e7-829e-1c1b0d4aab7f
오류 있는 패키지 전체 이름:
오류 있는 패키지에 상대적인 응용 프로그램 ID:
Error: (07/03/2017 10:01:07 PM) (Source: Application Error) (EventID: 1000) (User: )
예외 코드: 0x80000003
오류 오프셋: 0x00e44459
오류 있는 프로세스 ID: 0x1954
오류 있는 응용 프로그램 시작 시간: 0x01d2f3fc6f57e123
보고서 ID: ad1c1578-5fef-11e7-829e-1c1b0d4aab7f
오류 있는 패키지 전체 이름:
Error: (07/03/2017 10:01:02 PM) (Source: Application Error) (EventID: 1000) (User: )
예외 코드: 0x80000003
오류 오프셋: 0x00e44459
오류 있는 프로세스 ID: 0x1250
오류 있는 응용 프로그램 시작 시간: 0x01d2f3fc6c2bbc15
보고서 ID: a9f0202a-5fef-11e7-829e-1c1b0d4aab7f
오류 있는 패키지 전체 이름:
Error: (07/03/2017 10:00:57 PM) (Source: Application Error) (EventID: 1000) (User: )
예외 코드: 0x80000003
오류 오프셋: 0x00e44459
오류 있는 프로세스 ID: 0x1960
오류 있는 응용 프로그램 시작 시간: 0x01d2f3fc697ba995
보고서 ID: a7427016-5fef-11e7-829e-1c1b0d4aab7f
오류 있는 패키지 전체 이름:
Error: (07/03/2017 10:00:54 PM) (Source: Application Error) (EventID: 1000) (User: )
예외 코드: 0x80000003
오류 오프셋: 0x00e44459
오류 있는 프로세스 ID: 0x1118
오류 있는 응용 프로그램 시작 시간: 0x01d2f3fc6778a070
보고서 ID: a5384003-5fef-11e7-829e-1c1b0d4aab7f
오류 있는 패키지 전체 이름:
Error: (07/03/2017 10:00:51 PM) (Source: Application Error) (EventID: 1000) (User: )
예외 코드: 0x80000003
오류 오프셋: 0x00e44459
오류 있는 프로세스 ID: 0x1624
오류 있는 응용 프로그램 시작 시간: 0x01d2f3fc65c75fa9
보고서 ID: a3d81109-5fef-11e7-829e-1c1b0d4aab7f
오류 있는 패키지 전체 이름:
Error: (07/02/2017 09:15:59 PM) (Source: Application Error) (EventID: 1000) (User: )
Description: 오류 있는 응용 프로그램 이름: NVIDIA GeForce Experience.exe, 버전: 55.2883.1519.2, 타임스탬프: 0x586ee89b
예외 코드: 0x80000003
오류 오프셋: 0x00e44459
오류 있는 프로세스 ID: 0x790
오류 있는 응용 프로그램 시작 시간: 0x01d2f32cf6f82658
오류 있는 응용 프로그램 경로: C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA GeForce Experience.exe
보고서 ID: 34d5f3a9-5f20-11e7-829d-1c1b0d4aab7f
오류 있는 패키지 전체 이름:
System errors:
Error: (07/03/2017 10:14:45 PM) (Source: DCOM) (EventID: 10010) (User: user)
Description: {BF6C1E47-86EC-4194-9CE5-13C15DCB2001} 서버가 요구된 초과 시간 안에 DCOM으로 등록하지 않았습니다.
Error: (07/03/2017 10:14:15 PM) (Source: DCOM) (EventID: 10010) (User: user)
Description: {1B1F472E-3221-4826-97DB-2C2324D389AE} 서버가 요구된 초과 시간 안에 DCOM으로 등록하지 않았습니다.
Error: (07/03/2017 10:00:34 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (EventID: 10000) (User: NT AUTHORITY)
Description: WLAN 확장성 모듈을 시작하지 못했습니다.
모듈 경로: C:\Windows\system32\Rtlihvs.dll
오류 코드: 126
Error: (07/03/2017 10:00:27 PM) (Source: Microsoft-Windows-Kernel-Boot) (EventID: 29) (User: NT AUTHORITY)
Description: 32212256844642516050673176
Error: (07/03/2017 10:00:33 PM) (Source: EventLog) (EventID: 6008) (User: )
Description: ‎2017-‎07-‎02의 오후 11:33:44에서 이전에 예기치 않은 시스템 종료가 있었습니다.
Error: (07/02/2017 08:13:45 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (EventID: 10000) (User: NT AUTHORITY)
오류 코드: 126
Error: (07/02/2017 07:34:42 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (EventID: 10000) (User: NT AUTHORITY)
오류 코드: 126
Error: (07/02/2017 07:15:23 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (EventID: 10000) (User: NT AUTHORITY)
오류 코드: 126
Error: (07/02/2017 06:56:21 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (EventID: 10000) (User: NT AUTHORITY)
오류 코드: 126
Error: (07/02/2017 06:44:21 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (EventID: 10000) (User: NT AUTHORITY)
오류 코드: 126
==================== Memory info ===========================
Processor: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
Percentage of memory in use: 65%
Total physical RAM: 8144.43 MB
Available physical RAM: 2770.86 MB
Total Virtual: 10320.43 MB
Available Virtual: 3244.22 MB
==================== Drives ================================
Drive c: () (Fixed) (Total:232.54 GB) (Free:102.96 GB) NTFS
Drive d: () (Fixed) (Total:931.51 GB) (Free:513.9 GB) NTFS
==================== MBR & Partition Table ==================
Disk: 0 (MBR Code: Windows 7 or 8) (Size: 232.9 GB) (Disk ID: 8AADAFE3)
Partition 1: (Active) - (Size=350 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=232.5 GB) - (Type=07 NTFS)
Disk: 1 (MBR Code: Windows 7 or 8) (Size: 931.5 GB) (Disk ID: 8AADAF9E)
Partition 1: (Not Active) - (Size=931.5 GB) - (Type=07 NTFS)
==================== End of Addition.txt ============================
    windows 8.1 64x
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 02-07-2017
Ran by admin (administrator) on USER (03-07-2017 22:27:10)
Loaded Profiles: admin (Available Profiles: admin)오후 10:38 2017-07-03
Platform: Windows 8.1 (Update) (X64) Language: 한국어(대한민국)
Internet Explorer Version 11 (Default browser: Chrome)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: FRST Tutorial - How to use Farbar Recovery Scan Tool - Malware Removal Guides and Tutorials
==================== Processes (Whitelisted) =================
(If an entry is included in the fixlist, the process will be closed. The file will not be moved.)
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
(Interezen. Co., Ltd.) C:\Program Files (x86)\IPinside_LWS\I3GMainSvc.exe
(Microsoft Corporation) C:\Windows\System32\InputMethod\KOR\KorIME.exe
(ESTsoft Corp.) C:\Program Files (x86)\ESTsoft\ALUpdate\eausvc.exe
(SOFTFORUM) C:\Program Files (x86)\SoftForum\XecureWeb\AnySign\dll\AnySign4PCLauncher.exe
(Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
(Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
(SGA Solutions) C:\Program Files (x86)\SGA\ezCertForClient\Service\G4CWSLocalServer.exe
(Panda Security, S.L.) C:\Program Files (x86)\Panda Security\Panda Security Protection\PSANHost.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
(Panda Security, S.L.) C:\Program Files (x86)\Panda Security\Panda Devices Agent\AgentSvc.exe
(Visicom Media Inc.) C:\Program Files\Panda Security URL Filtering\Panda_URL_Filteringb.exe
(Panda Security, S.L.) C:\Program Files (x86)\Panda Security\Panda Security Protection\PSUAService.exe
(AhnLab, Inc.) C:\Program Files\AhnLab\Safe Transaction\ASDSvc.exe
(WIZVERA) C:\Program Files (x86)\Wizvera\Common\wpmsvc\wpmsvc.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
(Google Inc.) C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler.exe
(Google Inc.) C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler64.exe
(Wizvera) C:\Program Files (x86)\Wizvera\Delfino-G3\delfino.exe
(Interezen. Co., Ltd.) C:\Program Files (x86)\IPinside_LWS\I3GProc.exe
(WIZVERA) C:\Program Files (x86)\Wizvera\Veraport20\veraport.exe
(Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
(Apple Inc.) C:\Program Files\iTunes\iTunesHelper.exe
(AhnLab, Inc.) C:\Program Files\AhnLab\Safe Transaction\StSess.exe
(Valve Corporation) C:\Program Files (x86)\Steam\Steam.exe
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\ShadowPlay\nvspcaps64.exe
(Valve Corporation) C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe
(AhnLab, Inc.) C:\Program Files\AhnLab\Safe Transaction\Nz32\StSess32.exe
(Apple Inc.) C:\Program Files\iPod\bin\iPodService.exe
(Valve Corporation) C:\Program Files (x86)\Common Files\Steam\SteamService.exe
(iniLINE Co., Ltd.) C:\Program Files (x86)\iniLINE\CrossEX\crossex\CrossEXService.exe
(Kakao Corp. ) C:\Program Files (x86)\Kakao\KakaoTalk\KakaoTalk.exe
(SOFTFORUM) C:\Program Files (x86)\SoftForum\XecureWeb\AnySign\dll\AnySign4PC.exe
(Panda Security, S.L.) C:\Program Files (x86)\Panda Security\Panda Security Protection\PSUAMain.exe
(Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
(Intel Corporation) C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
(Google Inc.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
() D:\Black Desert\bin64\BlackDesert64.exe
(Wellbia.com Co., Ltd.) D:\Black Desert\bin64\xc\kr\2\xcoronahost.xem
(Wellbia.com) D:\Black Desert\bin64\xc\kr\2\xxd-0.xem
(Coherent Labs) D:\Black Desert\bin64\host\CoherentUI_Host.exe
(Farbar) C:\Users\admin\Downloads\FRST64 (1).exe
==================== Registry (Whitelisted) ====================
(If an entry is included in the fixlist, the registry item will be restored to default or removed. The file will not be moved.)
HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe [8844032 2016-01-27] (Realtek Semiconductor)
HKLM\...\Run: [IAStorIcon] => C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe [323056 2015-11-04] (Intel Corporation)
HKLM\...\Run: [ShadowPlay] => "C:\Windows\system32\rundll32.exe" C:\Windows\system32\nvspcap64.dll,ShadowPlayOnSystemStart
HKLM\...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [176440 2017-01-19] (Apple Inc.)
HKLM\...\Run: [AhnLab Safe Transaction Application] => C:\Program Files\AhnLab\Safe Transaction\stsess.exe [4743880 2017-04-14] (AhnLab, Inc.)
HKLM\...\Run: [Malwarebytes TrayApp] => C:\PROGRAM FILES/MALWAREBYTES/ANTI-MALWARE\mbamtray.exe
HKLM-x32\...\Run: [GrooveMonitor] => C:\Program Files (x86)\Microsoft Office\Office12\GrooveMonitor.exe [30040 2009-02-26] (Microsoft Corporation)
HKLM-x32\...\Run: [AnySign4PC] => C:\Program Files (x86)\SoftForum\XecureWeb\AnySign\dll\AnySign4PC.exe [2406408 2016-04-06] (SOFTFORUM)
HKLM-x32\...\Run: [PSUAMain] => C:\Program Files (x86)\Panda Security\Panda Security Protection\PSUAMain.exe [141760 2017-02-23] (Panda Security, S.L.)
HKLM-x32\...\Run: [wizvera-veraport] => C:\Program Files (x86)\Wizvera\Veraport20\veraport.exe [1721008 2016-11-28] (WIZVERA)
HKLM-x32\...\Run: [wizvera-delfino-pc] => C:\Program Files (x86)\Wizvera\Delfino-G3\delfino.exe [2126544 2017-05-08] (Wizvera)
HKLM-x32\...\Run: [ipinside-lws] => C:\Program Files (x86)\IPinside_LWS\I3GProc.exe [269088 2017-06-18] (Interezen. Co., Ltd.)
HKLM\...\Winlogon: [Userinit] C:\Windows\SysWOW64\userinit.exe,
HKU\S-1-5-21-3449503849-2698387126-3059338809-1001\...\Run: [Steam] => C:\Program Files (x86)\Steam\steam.exe [3042592 2017-06-08] (Valve Corporation)
HKU\S-1-5-21-3449503849-2698387126-3059338809-1001\...\Run: [CrossEXService] => C:\Program Files (x86)\iniLINE\CrossEX\crossex\CrossEXService.exe [1414168 2016-07-14] (iniLINE Co., Ltd.)
HKU\S-1-5-21-3449503849-2698387126-3059338809-1001\...\Run: [KakaoTalk] => C:\Program Files (x86)\Kakao\KakaoTalk\KakaoTalk.exe [8315200 2017-06-20] (Kakao Corp. )
HKU\S-1-5-18\...\RunOnce: [panda] => reg.exe delete "HKCU\Software\AppDataLow\Software\panda" /f
HKU\S-1-5-18\...\RunOnce: [panda_XP] => reg.exe delete "HKCU\Software\panda" /f
GroupPolicyScripts: Restriction <==== ATTENTION
GroupPolicyScripts-x32: Restriction <==== ATTENTION
==================== Internet (Whitelisted) ====================
(If an item is included in the fixlist, if it is a registry item it will be removed or restored to default.)
Tcpip\Parameters: [DhcpNameServer] 168.126.63.1 168.126.63.2
Tcpip\..\Interfaces\{00493025-1894-4F20-BBAB-FD54BDAE3DF6}: [DhcpNameServer] 168.126.63.1 168.126.63.2
Tcpip\..\Interfaces\{B79F85F7-F0BD-4FEF-B799-B73C19EF287A}: [DhcpNameServer] 168.126.63.1 168.126.63.2
Internet Explorer:
HKU\S-1-5-21-3449503849-2698387126-3059338809-1001\Software\Microsoft\Internet Explorer\Main,Start Page = hxxp://naver.com/
HKU\S-1-5-21-3449503849-2698387126-3059338809-1001\Software\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = hxxp://www.msn.com/ko-kr/?ocid=iehp
BHO: Panda Safe Web -> {B821BF60-5C2D-41EB-92DC-3E4CCD3A22E4} -> C:\Program Files (x86)\pandasecuritytb\pandasecurityDx64.dll [2016-11-22] ()
BHO-x32: Groove GFS Browser Helper -> {72853161-30C5-4D22-B7F9-0BBC1D38A37E} -> C:\Program Files (x86)\Microsoft Office\Office12\GrooveShellExtensions.dll [2009-02-26] (Microsoft Corporation)
BHO-x32: Panda Safe Web -> {B821BF60-5C2D-41EB-92DC-3E4CCD3A22E4} -> C:\Program Files (x86)\pandasecuritytb\pandasecurityDx.dll [2016-11-22] ()
Toolbar: HKLM - Panda Safe Web - {B821BF60-5C2D-41EB-92DC-3E4CCD3A22E4} - C:\Program Files (x86)\pandasecuritytb\pandasecurityDx64.dll [2016-11-22] ()
Toolbar: HKLM-x32 - Panda Safe Web - {B821BF60-5C2D-41EB-92DC-3E4CCD3A22E4} - C:\Program Files (x86)\pandasecuritytb\pandasecurityDx.dll [2016-11-22] ()
DPF: HKLM-x32 {063F7D71-5E0B-48F2-87D5-F63C5917947E} hxxp://ahnlabdownload.nefficient.co.kr/aos/plugin/aosmgr.cab
DPF: HKLM-x32 {1CBDCD5A-18EE-4CCA-9AEA-93D5D27E310B} hxxp://update.nprotect.net/keycrypt/kfb/cab/npkfxx_1512171.cab
DPF: HKLM-x32 {477D5B9A-6479-44F8-9718-9340119B0308} hxxp://banking.shinhan.com/wizvera/veraport/down/veraport20.cab
DPF: HKLM-x32 {7E9FDB80-5316-11D4-B02C-00C04F0CD404} hxxp://download.softforum.com/Published/XecureWeb/v7.2.8.6/xw_install.cab
DPF: HKLM-x32 {976A7D6C-B14C-4E50-A5C3-B43D8C49D8C8} hxxp://nmail.greencross.com/Mail/Webmail/DHTMLEd_Inc/Editor/TagFree/tweditor.cab
DPF: HKLM-x32 {9EF096ED-EBB5-44F1-9657-D6732B745E78} hxxp://nmail.greencross.com/Mail/Webmail/DHTMLEd_Inc/CoviUpload/CoviFileTrans.cab
DPF: HKLM-x32 {AC2CE4A7-75CE-4B11-B245-CE697861C3C1} hxxp://www.citibank.co.kr/mailplugin/INISAFEMailv4.cab
DPF: HKLM-x32 {B1D16D27-B5AC-434D-85D2-9D1CD4C0E018} hxxps://pay.kcp.co.kr/plugin_new/file/KCPPayUX.cab
DPF: HKLM-x32 {B70EA6F1-4C66-4F85-AB4D-CB3B1EB1A341} hxxp://img.shinhan.com/shttp/sphone/11017/INISAFECertClientv1.cab
DPF: HKLM-x32 {C945E31A-102E-4A0D-8854-D599D7AED5FA} hxxp://www9.hakwonsarang.co.kr/mmsc/activex/vsflex8.cab
DPF: HKLM-x32 {F939FEB8-9518-4A4A-BE60-D10FFB9557F2} hxxp://update.nprotect.net/netizenv55/bank/kfb/81/dev/npenkIEInstall5.cab
Handler-x32: s-http - {D37E6C5F-1C0F-47C0-A3B6-403EEC555402} - C:\Program Files (x86)\Initech\SHTTP\InitechSHTTPInterface.11018.dll [2017-01-23] ((c) INITECH)
Handler-x32: touchenex - {4a20e600-8604-11e6-a5d1-005056c00008} - C:\Program Files (x86)\RaonSecure\bridge\CrossEX\touchenex\1.0.1.981\CrossEXProtocol.dll [2016-09-29] (iniLINE Co., Ltd.)
FireFox:
FF Plugin: @Microsoft.com/NpCtrl,version=1.0 -> C:\Program Files\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
FF Plugin-x32: @ahnlab.com/asp/npaosmgr.1 -> C:\Program Files (x86)\AhnLab\ASP\Components\aosmgr\npaosmgr.dll [2015-08-26] (AhnLab, Inc.)
FF Plugin-x32: @daum.net/npDaumGameStarter -> C:\Users\Default\AppData\Roaming\DaumGame\npDaumGameStarter.dll [2016-11-09] (Kakao Games Corp.)
FF Plugin-x32: @gomtv.com/gomtvx-plugin -> C:\Program Files (x86)\Common Files\GRETECH\npgomtvx_nie.dll [2013-05-28] (Gretech Corporation)
FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 -> C:\Program Files (x86)\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
FF Plugin-x32: @nprotect.com/keycrypt -> C:\Windows\SysWOW64\npkfxmp.dll [2015-11-27] (INCA Internet Co., Ltd.)
FF Plugin-x32: @nprotect.com/nProtect Netizen v5.5 -> C:\Program Files (x86)\INCAInternet\nProtect Netizen v5.5\npenkOBInstall5.dll [2016-05-04] (INCA Internet Co., Ltd)
FF Plugin-x32: @nvidia.com/3DVision -> C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dv.dll [2017-05-02] (NVIDIA Corporation)
FF Plugin-x32: @nvidia.com/3DVisionStreaming -> C:\Program Files (x86)\NVIDIA Corporation\3D Vision\npnv3dvstreaming.dll [2017-05-02] (NVIDIA Corporation)
FF Plugin-x32: @softforum.com/npxwebplugins -> C:\Program Files (x86)\SoftForum\XecureWeb\ActiveX\npxwebplugin.dll [2016-01-27] (SoftForum Co., Ltd.)
FF Plugin-x32: @softforum.com/npxwebplugins_file -> C:\Program Files (x86)\SoftForum\XecureWeb\ActiveX\npxwebplugin_file.dll [2016-01-27] (SoftForum Co., Ltd.)
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-07-02] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-07-02] (Google Inc.)
FF Plugin-x32: @wizvera.com/npVeraport20 -> C:\Program Files (x86)\Wizvera\Veraport20\npveraport20.dll [2016-11-28] ()
FF Plugin-x32: Adobe Reader -> C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2017-04-05] (Adobe Systems Inc.)
FF Plugin-x32: touchenex@raon.com/npCrossEXPlugin -> C:\Program Files (x86)\RaonSecure\bridge\CrossEX\touchenex\1.0.1.981\npraontouchenex.dll [2016-09-29] (iniLINE Co., Ltd.)
FF Plugin HKU\S-1-5-21-3449503849-2698387126-3059338809-1001: @iniline.com/npCrossMail -> C:\Users\admin\AppData\Roaming\Mozilla\Extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\{90E3C402-A319-4429-AD5C-E7B30B7240B3}\plugins\npCrossMail.dll [2014-10-28] (INITECH Co., Ltd.)
FF Plugin HKU\S-1-5-21-3449503849-2698387126-3059338809-1001: @softforum.com/npxwebplugins -> C:\Program Files (x86)\SoftForum\XecureWeb\ActiveX\npxwebplugin.dll [2016-01-27] (SoftForum Co., Ltd.)
FF Plugin HKU\S-1-5-21-3449503849-2698387126-3059338809-1001: @softforum.com/npxwebplugins_file -> C:\Program Files (x86)\SoftForum\XecureWeb\ActiveX\npxwebplugin_file.dll [2016-01-27] (SoftForum Co., Ltd.)
Chrome:
CHR DefaultSearchKeyword: Default -> google.co.kr_
CHR Profile: C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default [2017-07-03]
CHR Extension: (Google 슬라이드) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2017-07-02]
CHR Extension: (Google 문서도구) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake [2017-07-02]
CHR Extension: (Google 드라이브) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf [2017-07-02]
CHR Extension: (YouTube) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2017-07-02]
CHR Extension: (TouchEn PC보안 확장) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\dncepekefegjiljlfbihljgogephdhph [2017-07-02]
CHR Extension: (Adobe Acrobat) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2017-07-02]
CHR Extension: (Panda Safe Web) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\fagakgcelolinfnkfgekcnedpaklfcok [2017-07-02]
CHR Extension: (Google 시트) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2017-07-02]
CHR Extension: (Google 문서 오프라인) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2017-07-02]
CHR Extension: (AdBlock) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\gighmmpiobklfepjocnamgkkbiglidom [2017-07-02]
CHR Extension: (Video DownloadHelper) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\lmjnegcaeklhafolokijcfjliaokphfk [2017-07-02]
CHR Extension: (Chrome 웹 스토어 결제) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2017-07-02]
CHR Extension: (Browsec VPN - Free and Unlimited VPN) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\omghfjlpggmjjaagoclmmobgdodcjboh [2017-07-02]
CHR Extension: (Gmail) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2017-07-02]
CHR Extension: (Chrome Media Router) - C:\Users\admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2017-07-02]
CHR HKLM\...\Chrome\Extension: [fagakgcelolinfnkfgekcnedpaklfcok] - hxxps://clients2.google.com/service/update2/crx
CHR HKU\S-1-5-21-3449503849-2698387126-3059338809-1001\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [fagakgcelolinfnkfgekcnedpaklfcok] - hxxps://clients2.google.com/service/update2/crx
==================== Services (Whitelisted) ====================
R2 ALUpdateService; C:\Program Files (x86)\ESTsoft\ALUpdate\eausvc.exe [381384 2017-03-22] (ESTsoft Corp.)
R2 AnySign4PC Launcher; C:\Program Files (x86)\SoftForum\XecureWeb\AnySign\dll\AnySign4PCLauncher.exe [2275336 2016-04-06] (SOFTFORUM)
R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2016-09-22] (Apple Inc.)
S3 BEService; C:\Program Files (x86)\Common Files\BattlEye\BEService.exe [1522184 2017-06-27] ()
R2 G4CSSWSCSVC; C:\Program Files (x86)\SGA\ezCertForClient\Service\G4CWSLocalServer.exe [859288 2016-11-09] (SGA Solutions)
R2 I3GMainSvc; C:\Program Files (x86)\IPinside_LWS\I3GMainSvc.exe [240440 2017-06-18] (Interezen. Co., Ltd.)
R2 IAStorDataMgrSvc; C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe [19440 2015-11-04] (Intel Corporation)
R2 NanoServiceMain; C:\Program Files (x86)\Panda Security\Panda Security Protection\PSANHost.exe [110384 2017-02-15] (Panda Security, S.L.)
S2 npkfxsvc; C:\Windows\SysWOW64\npkfxsvc.exe [205088 2017-01-14] (INCA Internet Co., Ltd.)
R2 NvContainerLocalSystem; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [464440 2017-01-06] (NVIDIA Corporation)
S3 NvContainerNetworkService; C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe [464440 2017-01-06] (NVIDIA Corporation)
R2 NVDisplay.ContainerLocalSystem; C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe [462968 2017-05-02] (NVIDIA Corporation)
R2 NvTelemetryContainer; C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe [427064 2017-01-06] (NVIDIA Corporation)
R2 PandaAgent; C:\Program Files (x86)\Panda Security\Panda Devices Agent\AgentSvc.exe [86104 2016-07-19] (Panda Security, S.L.)
R2 panda_url_filtering; C:\Program Files\Panda Security URL Filtering\Panda_URL_Filteringb.exe [246256 2016-11-22] (Visicom Media Inc.)
R2 PSUAService; C:\Program Files (x86)\Panda Security\Panda Security Protection\PSUAService.exe [47096 2017-04-26] (Panda Security, S.L.)
R2 SafeTransactionSVC; C:\Program Files\AhnLab\Safe Transaction\ASDSvc.exe [690864 2017-04-07] (AhnLab, Inc.)
R2 VPWalletService; C:\Program Files (x86)\VP\VPWalletService\VPWalletService.exe [376952 2017-03-31] ()
S3 WdNisSvc; C:\Program Files\Windows Defender\NisSrv.exe [361824 2017-01-13] (Microsoft Corporation)
S3 WinDefend; C:\Program Files\Windows Defender\MsMpEng.exe [119872 2017-01-13] (Microsoft Corporation)
R2 WizveraPMSvc; C:\Program Files (x86)\Wizvera\Common\wpmsvc\wpmsvc.exe [1003248 2017-05-08] (WIZVERA)
===================== Drivers (Whitelisted) ======================
S3 AhnFlt2K; C:\Windows\system32\drivers\AhnFlt2K.sys [84048 2015-09-03] (AhnLab, Inc.)
S3 AhnRec2K; C:\Windows\system32\drivers\AhnRec2K.sys [36280 2015-09-03] (AhnLab, Inc.)
R3 AhnRghNt; C:\Windows\system32\drivers\AhnRghNt.sys [83944 2017-03-28] (AhnLab, Inc.)
R2 AMonCDW8; C:\Windows\system32\Drivers\AMonCDW8.sys [205576 2017-02-15] (AhnLab, Inc.)
R3 AntiStealth_SafeTransaction; C:\Program Files\AhnLab\Safe Transaction\AHAWKENT.sys [63248 2017-03-13] (AhnLab, Inc.)
R3 AntiStealth_SafeTransactionF; C:\Program Files\AhnLab\Safe Transaction\TfFRegNt.sys [200848 2017-03-13] (AhnLab, Inc.)
S3 ascrts_SafeTransaction; C:\Program Files\AhnLab\Safe Transaction\asc\ascrts.sys [3316320 2017-06-22] (AhnLab, Inc.)
R3 ATamptNt_SafeTransaction; C:\Program Files\AhnLab\Safe Transaction\ATamptNt.sys [359400 2017-04-06] (AhnLab, Inc.)
R3 Cdm2DrNt; C:\Windows\system32\Drivers\Cdm2DrNt.sys [108496 2016-08-25] (AhnLab, Inc.)
S3 dcCtrlDrv; C:\Windows\system32\drivers\dcCtrlDrv.sys [76344 2011-02-14] (Redgate Co,. Ltd.)
S3 dcMiniDrv; C:\Windows\System32\DRIVERS\dcMiniDrv.sys [34360 2011-08-03] (Redgate Co,. Ltd.)
S3 dg_ssudbus; C:\Windows\system32\DRIVERS\ssudbus.sys [131712 2016-09-05] (Samsung Electronics Co., Ltd.)
R3 HSBDrv64; C:\Windows\System32\drivers\HSBDrv64.sys [140096 2017-04-04] (AhnLab, Inc.)
R3 iusb3adp; C:\Windows\System32\drivers\iusb3adp.sys [37672 2015-07-31] (Intel)
S3 JRSUKD25; C:\Windows\system32\JRSUKD25.SYS [40232 2017-02-21] (RaonSecure Co., Ltd.)
S3 MeDCoreD_SafeTransaction; C:\Program Files\AhnLab\Safe Transaction\MeDCoreD.sys [1022224 2017-05-22] (AhnLab, Inc.)
S3 MeDVpDrv_SafeTransaction; C:\Program Files\AhnLab\Safe Transaction\MeDVpDrv.sys [618256 2017-05-22] (AhnLab, Inc.)
S3 Mkd2Bthf; C:\Windows\System32\drivers\Mkd2Bthf.sys [119832 2017-02-01] (AhnLab, Inc.)
R3 Mkd2Nadr; C:\Windows\System32\drivers\Mkd2Nadr.sys [160824 2017-04-03] (AhnLab, Inc.)
R3 Mkd3kfNt; C:\Windows\System32\drivers\Mkd3kfNt.sys [203016 2017-04-03] (AhnLab, Inc.)
R1 NNSALPC; C:\Windows\System32\DRIVERS\NNSAlpc.sys [105984 2017-02-08] (Panda Security, S.L.)
R1 NNSHTTP; C:\Windows\System32\DRIVERS\NNSHttp.sys [209168 2016-06-29] (Panda Security, S.L.)
R1 NNSHTTPS; C:\Windows\System32\DRIVERS\NNSHttps.sys [119880 2017-02-08] (Panda Security, S.L.)
R1 NNSIDS; C:\Windows\System32\DRIVERS\NNSIds.sys [123664 2016-06-29] (Panda Security, S.L.)
R1 NNSNAHSL; C:\Windows\system32\DRIVERS\NNSNAHSL.sys [80152 2016-07-06] (Panda Security, S.L.)
R1 NNSPICC; C:\Windows\System32\DRIVERS\NNSPicc.sys [114448 2016-06-29] (Panda Security, S.L.)
R1 NNSPIHSW; C:\Windows\System32\DRIVERS\NNSPihsw.sys [88400 2016-06-29] (Panda Security, S.L.)
R1 NNSPOP3; C:\Windows\System32\DRIVERS\NNSPop3.sys [132880 2016-06-29] (Panda Security, S.L.)
R1 NNSPROT; C:\Windows\System32\DRIVERS\NNSProt.sys [333584 2016-06-29] (Panda Security, S.L.)
R1 NNSPRV; C:\Windows\System32\DRIVERS\NNSPrv.sys [196600 2017-02-08] (Panda Security, S.L.)
R1 NNSSMTP; C:\Windows\System32\DRIVERS\NNSSmtp.sys [121104 2016-06-29] (Panda Security, S.L.)
R1 NNSSTRM; C:\Windows\System32\DRIVERS\NNSStrm.sys [278432 2016-07-01] (Panda Security, S.L.)
R1 NNSTLSC; C:\Windows\System32\DRIVERS\NNSTlsc.sys [123152 2016-06-29] (Panda Security, S.L.)
S3 NPFW; C:\Windows\system32\NPFWVT64.sys [154312 2014-04-02] (INCA Internet Co.,Ltd.)
S3 NPFW; C:\Windows\SysWOW64\NPFWVT64.sys [154312 2014-04-02] (INCA Internet Co.,Ltd.)
S3 NPIDS; C:\Windows\system32\NpIdsVt64.sys [89352 2013-09-09] (INCA Internet Co.,Ltd.)
S3 NPIDS; C:\Windows\SysWOW64\NpIdsVt64.sys [89352 2013-09-09] (INCA Internet Co.,Ltd.)
S3 npkfxp; c:\windows\syswow64\npkfxp.sys [28640 2017-01-14] (INCA Internet Co.,Ltd.)
S3 npkfxu; c:\windows\syswow64\npkfxu.sys [37416 2017-01-14] (INCA Internet Co.,Ltd.)
S3 np_ck64s; c:\windows\syswow64\np_ck64s.sys [75680 2017-01-14] (INCA Internet Co.,Ltd.)
S3 NvStreamKms; C:\Program Files\NVIDIA Corporation\NvStreamSrv\NvStreamKms.sys [29240 2017-01-06] (NVIDIA Corporation)
R3 nvvad_WaveExtensible; C:\Windows\system32\drivers\nvvad64v.sys [47672 2017-01-06] (NVIDIA Corporation)
R3 nvvhci; C:\Windows\System32\drivers\nvvhci.sys [59448 2017-01-06] (NVIDIA Corporation)
R3 panda_url_filteringd; C:\Program Files\Panda Security URL Filtering\panda_url_filteringd.sys [51288 2014-03-20] (Visicom Media Inc.)
R2 PSINAflt; C:\Windows\System32\DRIVERS\PSINAflt.sys [177424 2017-02-12] (Panda Security, S.L.)
R2 PSINFile; C:\Windows\System32\DRIVERS\PSINFile.sys [131856 2017-02-12] (Panda Security, S.L.)
R1 PSINKNC; C:\Windows\System32\DRIVERS\psinknc.sys [205584 2017-02-20] (Panda Security, S.L.)
R2 PSINProc; C:\Windows\System32\DRIVERS\PSINProc.sys [131344 2017-02-12] (Panda Security, S.L.)
R2 PSINProt; C:\Windows\System32\DRIVERS\PSINProt.sys [144656 2017-02-12] (Panda Security, S.L.)
R2 PSINReg; C:\Windows\System32\DRIVERS\PSINReg.sys [114960 2017-02-12] (Panda Security, S.L.)
R3 PSKMAD; C:\Windows\System32\DRIVERS\PSKMAD.sys [70360 2016-08-08] (Panda Security, S.L.)
R3 RtlWlanu; C:\Windows\system32\DRIVERS\rtwlanu.sys [3860224 2015-08-05] (Realtek Semiconductor Corporation )
S3 scskusbf; C:\Windows\SysWow64\drivers\scskusbf.sys [21872 2017-03-31] (SoftCamp)
S3 scskusbs; C:\Windows\SysWow64\drivers\scskusbs.sys [100720 2017-03-31] (SoftCamp)
S3 ssudmdm; C:\Windows\system32\DRIVERS\ssudmdm.sys [165504 2016-09-05] (Samsung Electronics Co., Ltd.)
S3 TNFwNt_SafeTransaction; C:\Program Files\AhnLab\Safe Transaction\TNFwNt.sys [172816 2016-10-07] (AhnLab, Inc.)
S3 TNNipsNt_SafeTransaction; C:\Program Files\AhnLab\Safe Transaction\TNNipsNt.sys [213360 2016-10-07] (AhnLab, Inc.)
S3 TSFLTDRV_SafeTransaction; C:\Program Files\AhnLab\Safe Transaction\TSFLTDRV.sys [332816 2017-02-15] (AhnLab, Inc.)
S3 V3ElamDr; C:\Windows\System32\drivers\V3ElamDr.sys [24648 2014-09-23] (AhnLab, Inc.)
S3 WdBoot; C:\Windows\system32\drivers\WdBoot.sys [46600 2017-02-10] (Microsoft Corporation)
S3 WdFilter; C:\Windows\system32\drivers\WdFilter.sys [274776 2017-01-13] (Microsoft Corporation)
S3 WdNisDrv; C:\Windows\System32\Drivers\WdNisDrv.sys [117592 2017-01-13] (Microsoft Corporation)
S3 gdrv; \??\C:\Windows\gdrv.sys [X]
S3 JRSKD24; \??\C:\Windows\system32\JRSKD24.SYS [X]
S3 MBAMWebProtection; \??\C:\Windows\system32\drivers\mwac.sys [X]
R3 xhunter1; \??\C:\Windows\xhunter1.sys [X]
==================== NetSvcs (Whitelisted) ===================
==================== One Month Created files and folders ========
(If an entry is included in the fixlist, the file/folder will be moved.)
2017-07-03 22:27 - 2017-07-03 22:27 - 00026691 _____ C:\Users\admin\Downloads\FRST.txt
2017-07-03 22:26 - 2017-07-03 22:27 - 00000000 ____D C:\FRST
2017-07-03 22:26 - 2017-07-03 22:26 - 02435584 _____ (Farbar) C:\Users\admin\Downloads\FRST64 (1).exe
2017-07-03 22:22 - 2017-07-03 22:23 - 02432664 _____ C:\Users\admin\Downloads\FRST64.exe
2017-07-03 22:00 - 2017-07-03 22:00 - 00000000 ____D C:\Windows\LastGood
2017-07-02 21:18 - 2017-07-02 21:18 - 00000000 ____D C:\Program Files (x86)\VulkanRT
2017-07-02 21:18 - 2017-05-02 05:14 - 00134592 _____ (NVIDIA Corporation) C:\Windows\SysWOW64\nvStreaming.exe
2017-07-02 21:18 - 2017-03-11 06:17 - 00536864 _____ C:\Windows\system32\vulkan-1.dll
2017-07-02 21:18 - 2017-03-11 06:17 - 00525600 _____ C:\Windows\SysWOW64\vulkan-1.dll
2017-07-02 21:18 - 2017-03-11 06:17 - 00254240 _____ C:\Windows\system32\vulkaninfo.exe
2017-07-02 21:18 - 2017-03-11 06:17 - 00233760 _____ C:\Windows\SysWOW64\vulkaninfo.exe
2017-07-02 21:17 - 2017-07-02 21:17 - 00000000 ____D C:\Windows\LastGood.Tmp
2017-07-02 20:13 - 2016-08-08 18:00 - 00070360 _____ (Panda Security, S.L.) C:\Windows\system32\Drivers\PSKMAD.sys
2017-07-02 19:31 - 2017-07-02 19:31 - 00031510 _____ C:\Users\admin\Downloads\onejav.com_ebod590.torrent
2017-07-02 19:31 - 2017-07-02 19:31 - 00000000 ____D C:\Users\admin\AppData\LocalLow\uTorrent
2017-07-02 18:49 - 2017-07-02 18:49 - 00031896 _____ C:\Users\admin\Downloads\MTB.txt
2017-07-02 18:48 - 2017-07-02 18:48 - 00892416 _____ (Farbar) C:\Users\admin\Downloads\MiniToolBox.exe
2017-07-02 17:09 - 2017-07-02 17:09 - 00002265 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chrome.lnk
2017-07-02 17:09 - 2017-07-02 17:09 - 00002253 _____ C:\Users\Public\Desktop\Chrome.lnk
2017-07-02 16:46 - 2017-07-02 16:46 - 01130328 _____ (Google Inc.) C:\Users\admin\Downloads\ChromeSetup.exe
2017-07-02 16:46 - 2017-07-02 16:46 - 00003116 _____ C:\Windows\System32\Tasks\GoogleUpdateTaskMachineUA
2017-07-02 16:46 - 2017-07-02 16:46 - 00002988 _____ C:\Windows\System32\Tasks\GoogleUpdateTaskMachineCore
2017-07-02 11:50 - 2017-07-02 11:50 - 00000141 _____ C:\Users\admin\Documents\The Paper Wall.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000071 _____ C:\Users\admin\Documents\HelloJAV.COM Free Download the Japan and Asian Adult Video & Porn Torrent.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000071 _____ C:\Users\admin\Documents\FC2 동영상 성인-부라리넷-서양님의 정보-.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000071 _____ C:\Users\admin\Documents\FC2 동영상 성인-EER299.com님의 정보-.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000068 _____ C:\Users\admin\Documents\Free Masturbate Porn Videos from Thumbzilla.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000055 _____ C:\Users\admin\Documents\Photo - Fedor Shmidt Official Site.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000053 _____ C:\Users\admin\Documents\야플티비(@yapletv) 님 - 트위터 sssszzzz.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000053 _____ C:\Users\admin\Documents\나루토 매니아 -- 보루토 8화 애니.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000052 _____ C:\Users\admin\Documents\MARUMARU - 마루마루.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000048 _____ C:\Users\admin\Documents\New - OneJAV.com - Free JAV Torrents.url
2017-07-02 11:50 - 2017-07-02 11:50 - 00000046 _____ C:\Users\admin\Documents\ZANGSISI.url
2017-07-02 11:49 - 2017-07-02 11:49 - 00000068 _____ C:\Users\admin\Documents\강남건마[빠글원정대](@gananamgunma11) 님 - 트위터.url
2017-07-02 11:49 - 2017-07-02 11:49 - 00000058 _____ C:\Users\admin\Documents\랭킹 - FC2 동영상- 성인.url
2017-07-02 11:49 - 2017-07-02 11:49 - 00000057 _____ C:\Users\admin\Documents\[유해차단] 유해차단사이트 해제하는 방법 -- blueluna.url
2017-07-02 11:49 - 2017-07-02 11:49 - 00000050 _____ C:\Users\admin\Documents\NT - Browse.url
2017-07-02 11:49 - 2017-07-02 11:49 - 00000044 _____ C:\Users\admin\Documents\JavPOP.url
2017-07-02 11:36 - 2017-07-02 11:37 - 00000000 ___HD C:\Windows\AxInstSV
2017-07-02 10:23 - 2017-07-02 10:23 - 00041893 _____ C:\Users\admin\Downloads\A2000UA,A2000U.repair.zip
2017-07-02 10:21 - 2017-07-02 10:22 - 02891956 _____ C:\Users\admin\Downloads\A2000UA,A2000U.zip
2017-06-30 23:30 - 2017-07-02 17:22 - 00000000 ____D C:\Users\admin\AppData\Local\ElevatedDiagnostics
2017-06-27 21:15 - 2017-07-02 17:12 - 00000000 ____D C:\Users\admin\AppData\Local\UnrealEngine
2017-06-27 21:15 - 2017-06-27 21:15 - 00000000 ____D C:\Users\admin\AppData\Local\TslGame
2017-06-25 01:08 - 2017-06-25 01:08 - 00000017 _____ C:\Users\admin\AppData\Local\resmon.resmoncfg
2017-06-24 10:12 - 2017-04-22 06:53 - 00029376 _____ (Microsoft Corporation) C:\Windows\SysWOW64\aspnet_counters.dll
2017-06-24 10:12 - 2017-04-22 06:53 - 00018600 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msvcr100_clr0400.dll
2017-06-24 10:12 - 2017-04-22 06:50 - 00030912 _____ (Microsoft Corporation) C:\Windows\system32\aspnet_counters.dll
2017-06-24 10:12 - 2017-04-22 06:50 - 00018592 _____ (Microsoft Corporation) C:\Windows\system32\msvcr100_clr0400.dll
2017-06-24 10:12 - 2017-04-12 03:27 - 00485576 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msvcp120_clr0400.dll
2017-06-24 10:12 - 2017-03-16 03:15 - 00690008 _____ (Microsoft Corporation) C:\Windows\system32\msvcp120_clr0400.dll
2017-06-24 10:11 - 2017-04-12 03:27 - 00987840 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msvcr120_clr0400.dll
2017-06-24 10:11 - 2017-03-16 03:15 - 00993632 _____ (Microsoft Corporation) C:\Windows\system32\msvcr120_clr0400.dll
2017-06-23 19:46 - 2017-07-02 16:22 - 00113592 _____ (Malwarebytes) C:\Windows\system32\Drivers\farflt.sys
2017-06-23 19:46 - 2017-07-02 16:21 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes
2017-06-23 19:46 - 2017-05-25 11:58 - 00077376 _____ C:\Windows\system32\Drivers\mbae64.sys
2017-06-23 19:45 - 2017-06-23 19:45 - 64232976 _____ (Malwarebytes ) C:\Users\admin\Downloads\mb3-setup-consumer-3.1.2.1733-1.0.141-1.0.2092.exe
2017-06-22 23:58 - 2017-06-22 23:58 - 00003456 _____ C:\Windows\System32\Tasks\shutdown
2017-06-18 23:43 - 2017-07-03 22:01 - 00000000 ____D C:\Users\admin\AppData\LocalLow\IPinside
2017-06-18 21:33 - 2017-06-18 21:33 - 00000666 ___RH C:\Windows\hipiw.dll
2017-06-18 21:33 - 2017-06-18 21:33 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AhnLab
2017-06-18 21:33 - 2017-06-18 21:33 - 00000000 ____D C:\Program Files (x86)\IPinside_LWS
2017-06-18 21:33 - 2017-04-04 12:21 - 00140096 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\HSBDrv64.sys
2017-06-18 21:33 - 2017-04-03 21:48 - 00203016 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\mkd3kfnt.sys
2017-06-18 21:33 - 2017-04-03 21:48 - 00160824 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\mkd2nadr.sys
2017-06-18 21:33 - 2017-02-01 22:29 - 00119832 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\mkd2bthf.sys
2017-06-18 21:33 - 2015-06-11 10:11 - 00176784 _____ (Copyright (C) Korea University C.I.S.T) C:\Windows\system32\Drivers\klb64mkd.sys
2017-06-18 21:33 - 2015-06-11 10:11 - 00000147 _____ C:\Windows\system32\Drivers\klb64mkd.sig
2017-06-18 21:32 - 2017-07-03 22:00 - 00000017 _____ C:\Users\admin\AppData\LocalLow\.delfino.conf
2017-06-18 21:32 - 2017-06-18 21:32 - 00000000 ____D C:\Program Files\AhnLab
2017-06-18 21:32 - 2017-03-28 06:50 - 00083944 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\AhnRghNt.sys
2017-06-18 21:32 - 2017-02-15 00:02 - 00205576 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\AMonCDw8.sys
2017-06-18 21:32 - 2017-02-14 10:24 - 00181216 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\AMonCDw7.sys
2017-06-18 21:32 - 2017-02-02 17:52 - 00085616 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\AMonHKnt.sys
2017-06-18 21:32 - 2016-08-25 23:34 - 00108496 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\Cdm2DrNt.sys
2017-06-18 21:32 - 2016-06-23 10:04 - 00169800 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\AMonTDnt.sys
2017-06-18 21:32 - 2016-06-23 10:04 - 00155224 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\AMonTDLH.sys
2017-06-18 21:32 - 2015-09-03 16:13 - 00084048 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\AhnFlt2k.sys
2017-06-18 21:32 - 2015-09-03 16:13 - 00036280 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\AhnRec2k.sys
2017-06-18 21:32 - 2015-03-12 14:39 - 00061112 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\AMonLWLH.sys
2017-06-18 21:32 - 2014-09-23 11:20 - 00024648 _____ (AhnLab, Inc.) C:\Windows\system32\Drivers\V3ElamDr.sys
2017-06-18 21:32 - 2014-09-23 11:20 - 00009809 _____ C:\Windows\system32\Drivers\V3ElamDr.cat
2017-06-15 17:59 - 2017-06-02 20:30 - 03635200 _____ (Microsoft Corporation) C:\Windows\system32\tquery.dll
2017-06-15 17:59 - 2017-05-15 05:44 - 04170240 _____ (Microsoft Corporation) C:\Windows\system32\win32k.sys
2017-06-15 17:59 - 2017-05-15 05:42 - 00107520 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\tdx.sys
2017-06-15 17:59 - 2017-05-15 05:19 - 25738752 _____ (Microsoft Corporation) C:\Windows\system32\mshtml.dll
2017-06-15 17:59 - 2017-05-15 04:55 - 05975040 _____ (Microsoft Corporation) C:\Windows\system32\jscript9.dll
2017-06-15 17:59 - 2017-05-15 04:32 - 07077376 _____ (Microsoft Corporation) C:\Windows\system32\glcndFilter.dll
2017-06-15 17:59 - 2017-05-15 04:11 - 20274688 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mshtml.dll
2017-06-15 17:59 - 2017-05-15 03:54 - 15252992 _____ (Microsoft Corporation) C:\Windows\system32\ieframe.dll
2017-06-15 17:59 - 2017-05-15 03:52 - 03240960 _____ (Microsoft Corporation) C:\Windows\system32\wininet.dll
2017-06-15 17:59 - 2017-05-15 03:48 - 05274112 _____ (Microsoft Corporation) C:\Windows\SysWOW64\glcndFilter.dll
2017-06-15 17:59 - 2017-05-15 03:44 - 04549120 _____ (Microsoft Corporation) C:\Windows\SysWOW64\jscript9.dll
2017-06-15 17:59 - 2017-05-15 03:38 - 07796736 _____ (Microsoft Corporation) C:\Windows\system32\Windows.Data.Pdf.dll
2017-06-15 17:59 - 2017-05-15 03:30 - 13664768 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ieframe.dll
2017-06-15 17:59 - 2017-05-15 03:16 - 05268992 _____ (Microsoft Corporation) C:\Windows\SysWOW64\Windows.Data.Pdf.dll
2017-06-15 17:59 - 2017-05-15 03:15 - 02767872 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wininet.dll
2017-06-15 17:59 - 2017-05-15 03:06 - 07441240 _____ (Microsoft Corporation) C:\Windows\system32\ntoskrnl.exe
2017-06-15 17:59 - 2017-05-12 11:58 - 01985536 _____ (Microsoft Corporation) C:\Windows\system32\DWrite.dll
2017-06-15 17:59 - 2017-05-12 11:18 - 03714560 _____ (Microsoft Corporation) C:\Windows\system32\wuaueng.dll
2017-06-15 17:59 - 2017-05-12 08:36 - 22361848 _____ (Microsoft Corporation) C:\Windows\system32\shell32.dll
2017-06-15 17:59 - 2017-05-12 08:32 - 19788672 _____ (Microsoft Corporation) C:\Windows\SysWOW64\shell32.dll
2017-06-15 17:59 - 2017-04-02 22:40 - 02013016 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\ntfs.sys
2017-06-15 17:58 - 2017-06-02 21:15 - 00337408 _____ (Microsoft Corporation) C:\Windows\system32\SearchProtocolHost.exe
2017-06-15 17:58 - 2017-06-02 21:12 - 00468992 _____ (Microsoft Corporation) C:\Windows\system32\mssph.dll
2017-06-15 17:58 - 2017-06-02 21:12 - 00248832 _____ (Microsoft Corporation) C:\Windows\system32\mssphtb.dll
2017-06-15 17:58 - 2017-06-02 21:06 - 01001984 _____ (Microsoft Corporation) C:\Windows\HelpPane.exe
2017-06-15 17:58 - 2017-06-02 21:01 - 00774144 _____ (Microsoft Corporation) C:\Windows\system32\mssvp.dll
2017-06-15 17:58 - 2017-06-02 20:03 - 00903168 _____ (Microsoft Corporation) C:\Windows\system32\SearchIndexer.exe
2017-06-15 17:58 - 2017-06-02 19:58 - 02551808 _____ (Microsoft Corporation) C:\Windows\system32\mssrch.dll
2017-06-15 17:58 - 2017-06-02 19:25 - 00272896 _____ (Microsoft Corporation) C:\Windows\SysWOW64\SearchProtocolHost.exe
2017-06-15 17:58 - 2017-06-02 19:24 - 00391680 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mssph.dll
2017-06-15 17:58 - 2017-06-02 19:17 - 00699392 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mssvp.dll
2017-06-15 17:58 - 2017-06-02 19:02 - 02751488 _____ (Microsoft Corporation) C:\Windows\SysWOW64\tquery.dll
2017-06-15 17:58 - 2017-06-02 18:43 - 01920000 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mssrch.dll
2017-06-15 17:58 - 2017-06-02 18:43 - 00710144 _____ (Microsoft Corporation) C:\Windows\SysWOW64\SearchIndexer.exe
2017-06-15 17:58 - 2017-05-16 04:58 - 00121184 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\tm.sys
2017-06-15 17:58 - 2017-05-15 05:26 - 00576512 _____ (Microsoft Corporation) C:\Windows\system32\vbscript.dll
2017-06-15 17:58 - 2017-05-15 05:19 - 01364040 _____ (Microsoft Corporation) C:\Windows\system32\gdi32.dll
2017-06-15 17:58 - 2017-05-15 05:10 - 00817664 _____ (Microsoft Corporation) C:\Windows\system32\jscript.dll
2017-06-15 17:58 - 2017-05-15 04:31 - 01033216 _____ (Microsoft Corporation) C:\Windows\system32\inetcomm.dll
2017-06-15 17:58 - 2017-05-15 04:22 - 00499200 _____ (Microsoft Corporation) C:\Windows\SysWOW64\vbscript.dll
2017-06-15 17:58 - 2017-05-15 04:19 - 00806912 _____ (Microsoft Corporation) C:\Windows\system32\msfeeds.dll
2017-06-15 17:58 - 2017-05-15 04:10 - 00663552 _____ (Microsoft Corporation) C:\Windows\SysWOW64\jscript.dll
2017-06-15 17:58 - 2017-05-15 04:04 - 00315224 _____ (Adobe Systems Incorporated) C:\Windows\SysWOW64\atmfd.dll
2017-06-15 17:58 - 2017-05-15 04:03 - 00373080 _____ (Adobe Systems Incorporated) C:\Windows\system32\atmfd.dll
2017-06-15 17:58 - 2017-05-15 03:46 - 00880640 _____ (Microsoft Corporation) C:\Windows\SysWOW64\inetcomm.dll
2017-06-15 17:58 - 2017-05-15 03:40 - 00693248 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msfeeds.dll
2017-06-15 17:58 - 2017-05-15 03:37 - 01544704 _____ (Microsoft Corporation) C:\Windows\system32\urlmon.dll
2017-06-15 17:58 - 2017-05-15 03:27 - 00800768 _____ (Microsoft Corporation) C:\Windows\system32\ieapfltr.dll
2017-06-15 17:58 - 2017-05-15 03:13 - 00136904 _____ (Microsoft Corporation) C:\Windows\system32\wuauclt.exe
2017-06-15 17:58 - 2017-05-15 03:11 - 01314816 _____ (Microsoft Corporation) C:\Windows\SysWOW64\urlmon.dll
2017-06-15 17:58 - 2017-05-15 03:11 - 00710144 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ieapfltr.dll
2017-06-15 17:58 - 2017-05-15 03:06 - 01737600 _____ (Microsoft Corporation) C:\Windows\system32\ntdll.dll
2017-06-15 17:58 - 2017-05-15 03:06 - 01502000 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ntdll.dll
2017-06-15 17:58 - 2017-05-13 02:05 - 00035840 _____ (Adobe Systems) C:\Windows\SysWOW64\atmlib.dll
2017-06-15 17:58 - 2017-05-13 01:16 - 01084928 _____ (Microsoft Corporation) C:\Windows\SysWOW64\gdi32.dll
2017-06-15 17:58 - 2017-05-13 01:13 - 01559552 _____ (Microsoft Corporation) C:\Windows\SysWOW64\DWrite.dll
2017-06-15 17:58 - 2017-05-13 00:51 - 00029696 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wuapp.exe
2017-06-15 17:58 - 2017-05-13 00:50 - 00124928 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wuwebv.dll
2017-06-15 17:58 - 2017-05-13 00:48 - 00081920 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wudriver.dll
2017-06-15 17:58 - 2017-05-13 00:47 - 00726528 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wuapi.dll
2017-06-15 17:58 - 2017-05-12 13:10 - 00044032 _____ (Adobe Systems) C:\Windows\system32\atmlib.dll
2017-06-15 17:58 - 2017-05-12 11:48 - 01377792 _____ (Microsoft Corporation) C:\Windows\system32\FntCache.dll
2017-06-15 17:58 - 2017-05-12 11:11 - 00035840 _____ (Microsoft Corporation) C:\Windows\system32\wuapp.exe
2017-06-15 17:58 - 2017-05-12 11:10 - 00140288 _____ (Microsoft Corporation) C:\Windows\system32\wuwebv.dll
2017-06-15 17:58 - 2017-05-12 11:07 - 00409088 _____ (Microsoft Corporation) C:\Windows\system32\WUSettingsProvider.dll
2017-06-15 17:58 - 2017-05-12 11:06 - 00095744 _____ (Microsoft Corporation) C:\Windows\system32\wudriver.dll
2017-06-15 17:58 - 2017-05-12 11:04 - 00897024 _____ (Microsoft Corporation) C:\Windows\system32\wuapi.dll
2017-06-15 17:58 - 2017-05-12 11:00 - 02240512 _____ (Microsoft Corporation) C:\Windows\system32\wucltux.dll
2017-06-15 17:58 - 2017-05-11 03:19 - 00101720 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mountmgr.sys
2017-06-15 17:58 - 2017-05-07 01:05 - 01094656 _____ (Microsoft Corporation) C:\Windows\system32\localspl.dll
2017-06-15 17:58 - 2017-05-07 01:04 - 00865792 _____ (Microsoft Corporation) C:\Windows\system32\win32spl.dll
2017-06-15 17:58 - 2017-04-07 02:37 - 00445440 _____ (Microsoft Corporation) C:\Windows\system32\certcli.dll
2017-06-15 17:58 - 2017-04-07 02:16 - 00615936 _____ (Microsoft Corporation) C:\Windows\system32\wpd_ci.dll
2017-06-15 17:58 - 2017-04-07 01:50 - 01436672 _____ (Microsoft Corporation) C:\Windows\system32\lsasrv.dll
2017-06-15 17:58 - 2017-04-07 01:46 - 00434688 _____ (Microsoft Corporation) C:\Windows\system32\schannel.dll
2017-06-15 17:58 - 2017-04-07 01:46 - 00324096 _____ (Microsoft Corporation) C:\Windows\SysWOW64\certcli.dll
2017-06-15 17:58 - 2017-04-07 01:35 - 01362432 _____ (Microsoft Corporation) C:\Windows\system32\gpsvc.dll
2017-06-15 17:58 - 2017-04-07 01:15 - 00358912 _____ (Microsoft Corporation) C:\Windows\SysWOW64\schannel.dll
2017-06-15 17:58 - 2017-04-07 00:44 - 00087040 _____ (Microsoft Corporation) C:\Windows\system32\wpdbusenum.dll
2017-06-15 17:58 - 2017-04-02 23:49 - 00186880 _____ (Microsoft Corporation) C:\Windows\system32\dpapisrv.dll
2017-06-14 23:50 - 2017-06-14 23:50 - 00441514 _____ C:\Users\admin\Downloads\Workshop prensetation (2017-06-15).pptx
2017-06-14 22:48 - 2017-06-14 22:48 - 00220315 _____ C:\Users\admin\Downloads\2017 DIA US FDA IND-NDA training_참석 보고서_RA2.pdf
2017-06-12 23:00 - 2017-06-12 23:01 - 82711281 _____ C:\Users\admin\Downloads\하백의 신부 24권.pdf
2017-06-12 22:51 - 2017-06-12 22:51 - 89597004 _____ C:\Users\admin\Downloads\하백의 신부 23권.pdf
2017-06-12 22:39 - 2017-06-12 22:44 - 172352490 _____ C:\Users\admin\Downloads\하백의 신부 22권.pdf
2017-06-12 22:24 - 2017-06-12 22:45 - 182432206 _____ C:\Users\admin\Downloads\하백의 신부 21권.pdf
2017-06-11 22:57 - 2017-06-11 23:13 - 186491651 _____ C:\Users\admin\Downloads\하백의 신부 20권.pdf
2017-06-11 22:30 - 2017-06-11 22:31 - 215972423 _____ C:\Users\admin\Downloads\하백의 신부 19권.pdf
2017-06-11 22:08 - 2017-06-11 22:14 - 220259079 _____ C:\Users\admin\Downloads\하백의 신부 18권.pdf
2017-06-11 21:22 - 2017-06-11 21:30 - 223225649 _____ C:\Users\admin\Downloads\하백의 신부 17권.pdf
2017-06-11 21:04 - 2017-06-11 21:26 - 139014144 _____ C:\Users\admin\Downloads\하백의 신부 16권.pdf
2017-06-11 20:08 - 2017-06-11 20:09 - 152617578 _____ C:\Users\admin\Downloads\하백의 신부 15권.pdf
2017-06-11 19:51 - 2017-06-11 19:51 - 80586312 _____ C:\Users\admin\Downloads\하백의 신부 14권.pdf
2017-06-11 19:02 - 2017-06-11 19:04 - 56334517 _____ C:\Users\admin\Downloads\하백의 신부 13권.pdf
2017-06-11 17:21 - 2017-06-11 17:22 - 56511869 _____ C:\Users\admin\Downloads\하백의 신부 12권.pdf
2017-06-11 16:32 - 2017-06-11 16:33 - 60168335 _____ C:\Users\admin\Downloads\하백의 신부 11권.pdf
2017-06-11 15:48 - 2017-06-11 15:48 - 26885328 _____ C:\Users\admin\Downloads\하백의 신부 10권.pdf
2017-06-11 15:40 - 2017-06-11 15:41 - 43683972 _____ C:\Users\admin\Downloads\하백의 신부 9권.pdf
2017-06-11 15:25 - 2017-06-11 15:29 - 66268536 _____ C:\Users\admin\Downloads\하백의 신부 8권.pdf
2017-06-11 15:17 - 2017-06-11 15:17 - 77906381 _____ C:\Users\admin\Downloads\하백의 신부 7권.pdf
2017-06-11 15:13 - 2017-06-11 15:13 - 25302027 _____ C:\Users\admin\Downloads\하백의 신부 6권.pdf
2017-06-11 15:10 - 2017-06-11 15:10 - 21076036 _____ C:\Users\admin\Downloads\하백의 신부 5권.pdf
2017-06-11 14:54 - 2017-06-11 14:54 - 18550047 _____ C:\Users\admin\Downloads\하백의 신부 4권.pdf
2017-06-11 14:34 - 2017-06-11 14:35 - 32992986 _____ C:\Users\admin\Downloads\하백의 신부 3권.pdf
2017-06-11 14:29 - 2017-06-11 14:32 - 51864359 _____ C:\Users\admin\Downloads\하백의 신부 2권.pdf
2017-06-11 14:15 - 2017-06-11 14:16 - 61943464 _____ C:\Users\admin\Downloads\하백의 신부 1권.pdf
2017-06-06 23:08 - 2017-06-06 22:59 - 00041607 _____ C:\Users\admin\Desktop\checklist (1).xlsx
2017-06-06 12:34 - 2017-06-06 12:34 - 00164720 ____R (RaonSecure Co., Ltd.) C:\Windows\SysWOW64\CKAgent.exe
2017-06-06 12:34 - 2017-06-06 12:34 - 00164720 ____R (RaonSecure Co., Ltd.) C:\Windows\system32\CKAgent.exe
2017-06-04 12:32 - 2017-06-04 12:32 - 00047592 _____ C:\Users\admin\Downloads\onejav.com_eyan088.torrent
==================== One Month Modified files and folders ========
2017-07-03 22:09 - 2017-01-03 21:47 - 00003876 _____ C:\Windows\System32\Tasks\User_Feed_Synchronization-{E0C21BB2-BB83-4968-9198-FDA22208C6DA}
2017-07-03 22:09 - 2017-01-02 12:49 - 00000000 ____D C:\ProgramData\NVIDIA
2017-07-03 22:08 - 2017-01-29 23:39 - 00000000 ____D C:\Program Files (x86)\Steam
2017-07-03 22:06 - 2014-11-21 11:30 - 01433666 _____ C:\Windows\system32\PerfStringBackup.INI
2017-07-03 22:06 - 2014-11-21 10:38 - 00485112 _____ C:\Windows\system32\perfh012.dat
2017-07-03 22:06 - 2014-11-21 10:38 - 00128552 _____ C:\Windows\system32\perfc012.dat
2017-07-03 22:06 - 2013-08-22 22:36 - 00000000 ____D C:\Windows\Inf
2017-07-03 22:00 - 2017-01-15 21:33 - 00000000 ____D C:\Program Files\Panda Security URL Filtering
2017-07-03 22:00 - 2017-01-02 12:36 - 00000000 ____D C:\ProgramData\NVIDIA Corporation
2017-07-03 22:00 - 2013-08-22 23:45 - 00000006 ____H C:\Windows\Tasks\SA.DAT
2017-07-02 21:31 - 2017-01-02 12:19 - 00003600 _____ C:\Windows\System32\Tasks\Optimize Start Menu Cache Files-S-1-5-21-3449503849-2698387126-3059338809-1001
2017-07-02 21:18 - 2017-01-02 12:36 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
2017-07-02 21:17 - 2017-01-02 12:36 - 00000000 ____D C:\Program Files\NVIDIA Corporation
2017-07-02 20:13 - 2017-03-25 01:22 - 00000000 ____D C:\Users\admin\AppData\Roaming\uTorrent
2017-07-02 19:35 - 2013-08-23 00:36 - 00000000 ____D C:\Windows\system32\NDF
2017-07-02 18:01 - 2017-02-18 00:12 - 00000000 ____D C:\Users\admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Steam
2017-07-02 18:01 - 2013-08-23 00:20 - 00000000 ____D C:\Windows\CbsTemp
2017-07-02 17:11 - 2017-01-02 12:19 - 00000000 ____D C:\ProgramData\Package Cache
2017-07-02 17:09 - 2017-01-03 21:57 - 00000000 ____D C:\Program Files (x86)\Google
2017-07-02 16:22 - 2017-01-02 12:36 - 00000000 ____D C:\Users\admin\AppData\Local\NVIDIA
2017-07-02 16:22 - 2017-01-02 12:14 - 00000000 ____D C:\Users\admin
2017-07-02 16:21 - 2017-01-15 21:36 - 00000000 ____D C:\ProgramData\Malwarebytes
2017-07-02 16:21 - 2017-01-03 21:57 - 00000000 ____D C:\Users\admin\AppData\Local\Google
2017-07-02 16:21 - 2013-08-23 00:36 - 00000000 ___HD C:\Windows\ELAMBKUP
2017-07-02 16:21 - 2013-08-23 00:36 - 00000000 ___HD C:\Program Files\WindowsApps
2017-07-02 16:21 - 2013-08-23 00:36 - 00000000 ____D C:\Windows\SysWOW64\Macromed
2017-07-02 16:21 - 2013-08-23 00:36 - 00000000 ____D C:\Windows\system32\Macromed
2017-07-02 16:21 - 2013-08-23 00:36 - 00000000 ____D C:\Windows\registration
2017-07-02 16:20 - 2017-01-02 12:36 - 00000000 ____D C:\Program Files (x86)\NVIDIA Corporation
2017-07-02 16:15 - 2017-03-15 21:45 - 00000000 ____D C:\Users\admin\AppData\Local\CrashDumps
2017-07-02 11:46 - 2017-03-05 18:54 - 00000000 ____D C:\Users\admin\AppData\Local\Adobe
2017-07-02 11:37 - 2017-03-05 18:55 - 00000000 ____D C:\Users\admin\AppData\LocalLow\Adobe
2017-06-30 23:31 - 2017-04-25 19:35 - 00000000 ____D C:\Users\admin\Documents\Black Desert
2017-06-27 17:06 - 2017-03-18 11:26 - 00004258 _____ C:\Windows\System32\Tasks\Adobe Flash Player PPAPI Notifier
2017-06-27 17:06 - 2017-03-18 11:26 - 00004116 _____ C:\Windows\System32\Tasks\Adobe Flash Player Updater
2017-06-22 11:02 - 2017-01-29 22:57 - 03228296 _____ (AhnLab, Inc.) C:\Windows\system32\btscan.exe
2017-06-22 07:06 - 2013-08-23 00:36 - 00000000 ____D C:\Windows\rescache
2017-06-18 23:56 - 2013-08-22 22:25 - 00262144 ___SH C:\Windows\system32\config\ELAM
2017-06-18 21:33 - 2017-01-23 21:38 - 00000000 ____D C:\Users\admin\AppData\LocalLow\AhnLab
2017-06-18 21:32 - 2017-01-23 21:38 - 00000000 ____D C:\Program Files (x86)\Wizvera
2017-06-18 00:15 - 2017-05-05 21:53 - 00000000 ____D C:\Program Files\Microsoft Silverlight
2017-06-18 00:15 - 2017-05-05 21:53 - 00000000 ____D C:\Program Files (x86)\Microsoft Silverlight
2017-06-18 00:15 - 2013-08-22 23:44 - 00587368 _____ C:\Windows\system32\FNTCACHE.DAT
2017-06-17 23:40 - 2013-08-23 00:36 - 00000000 ___RD C:\Windows\ToastData
2017-06-16 22:04 - 2017-01-02 12:14 - 00000000 ____D C:\Users\admin\AppData\Local\Packages
2017-06-16 22:04 - 2013-08-23 00:36 - 00000000 ____D C:\Windows\AppReadiness
2017-06-16 22:03 - 2017-05-05 21:53 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
2017-06-16 22:03 - 2017-03-25 09:18 - 00000000 ____D C:\Windows\system32\MRT
2017-06-16 22:00 - 2017-03-25 09:18 - 133627792 ____C (Microsoft Corporation) C:\Windows\system32\MRT.exe
2017-06-12 20:30 - 2017-04-12 20:19 - 00401408 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxsmb.sys
2017-06-12 20:30 - 2017-04-12 20:19 - 00285184 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxsmb10.sys
2017-06-12 20:30 - 2017-04-12 20:19 - 00201728 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxsmb20.sys
2017-06-03 11:31 - 2014-11-21 19:14 - 00835576 _____ (Adobe Systems Incorporated) C:\Windows\SysWOW64\FlashPlayerApp.exe
2017-06-03 11:31 - 2014-11-21 19:14 - 00177656 _____ (Adobe Systems Incorporated) C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
==================== Files in the root of some directories =======
2017-06-25 01:08 - 2017-06-25 01:08 - 0000017 _____ () C:\Users\admin\AppData\Local\resmon.resmoncfg
2017-01-02 12:22 - 2017-01-02 12:22 - 0000000 ____H () C:\ProgramData\DP45977C.lfl
2017-05-18 21:11 - 2017-05-18 21:11 - 0000016 _____ () C:\ProgramData\mntemp
Some files in TEMP:
2017-04-25 19:36 - 2017-07-03 22:22 - 0000072 _____ () C:\Users\admin\AppData\Local\Temp\a6688a40030bc1da5839b9d5a4fd73a9.dll
2017-04-25 19:36 - 2017-07-03 22:25 - 0000000 _____ () C:\Users\admin\AppData\Local\Temp\f4f08310fb10a66c0aa4808000146ccc.dll
2016-12-21 13:43 - 2016-12-21 13:43 - 0015872 _____ () C:\Users\admin\AppData\Local\Temp\NsisCrypt.dll
2017-01-23 21:44 - 2006-11-02 22:15 - 0145184 ____R (Microsoft Corporation) C:\Users\admin\AppData\Local\Temp\ose00000.exe
2017-01-23 21:42 - 2015-08-12 17:53 - 0029504 _____ (SoftCamp Co.,Ltd.) C:\Users\admin\AppData\Local\Temp\SCSKSender.exe
2017-01-15 21:32 - 2017-01-15 21:32 - 57657832 _____ (Panda Security, S.L.) C:\Users\admin\AppData\Local\Temp\{A797B11A-6E7F-4594-AA94-63BF812C4226}.exe
==================== Bamital & volsnap ======================
(There is no automatic fix for files that do not pass verification.)
C:\Windows\system32\winlogon.exe => File is digitally signed
C:\Windows\system32\wininit.exe => File is digitally signed
C:\Windows\explorer.exe => File is digitally signed
C:\Windows\SysWOW64\explorer.exe => File is digitally signed
C:\Windows\system32\svchost.exe => File is digitally signed
C:\Windows\SysWOW64\svchost.exe => File is digitally signed
C:\Windows\system32\services.exe => File is digitally signed
C:\Windows\system32\User32.dll => File is digitally signed
C:\Windows\SysWOW64\User32.dll => File is digitally signed
C:\Windows\system32\userinit.exe => File is digitally signed
C:\Windows\SysWOW64\userinit.exe => File is digitally signed
C:\Windows\system32\rpcss.dll => File is digitally signed
C:\Windows\system32\dnsapi.dll => File is digitally signed
C:\Windows\SysWOW64\dnsapi.dll => File is digitally signed
C:\Windows\system32\Drivers\volsnap.sys => File is digitally signed
LastRegBack: 2017-07-02 10:39
==================== End of FRST.txt ============================
    windows 8.1 64x
wow there are alot of things on there. I've copied and pasted both text files.
Your help will be very appreciated.
Best regards,
Pat.
    windows 8.1 64x
What is this in english there are a few of these errors
오류 코드: 126
Stop bonjourthis isnt used and gives strange errors
Set your dns to 208.67.220.220 & 208.67.222.222
run this to get rid of the junk UnCleaner – The Unnecessary Files Cleaner Solution - Josh Cell Softwares
    win 8 pro
Sorry for the inconvenience. Let me translate:
Description: WLAN 확장성 모듈을 시작하지 못했습니다. (WLAN Extensibility Module has failed to start)
모듈 경로 (module Pathway): C:\Windows\system32\Rtlihvs.dll
오류 코드 (Error Code): 126
So based on my quick serch, it says somethings wrong with my wireless card. But as i mentioned, same problem persists when i use ethernet cable as well...hummmm
THank you for all your attention to this matter.
Your help is VERY appreciated.
Best regards,
pat.
    windows 8.1 64x
Thank you for your suggestion, Samuria.
So as you've suggested, i've deleted bonjour app.
Also reset my DNS to what you've suggested.
This so far hasn't fixed the situation.
One thing that i've noticed tho, is that while trying to download UnCleaner, the download will occur very fast, but will get stuck at 99% for about 5 ~ 10 minutes.
After completing, however, it says the file was corrupt and was unable to get the installation file to work.
So my conclusion is that the problem has something to do with near the end of download, maybe the finishing part of the download activity (i have no idea what to call this) might have an error. As im not experienced with computers, this is just my non-computer brain thinking.
Is this even possible? some program within my computer showing errors and therefore leading to incomplete download?
This occurs with basically everything that i try to download (eg. games, browsers, utilities, etc). Even pictures won't completely load to perfection.
Maybe my computer is just messed up...
Anyways your advices will be very helpful!
Best regards,
Pat.
    windows 8.1 64x
