Solved Improving remote desktop connection speed
lizard47
I have a home WIFI network set up as per the graphic below.
Using XRDP the Windows box can make a remote connection to the Ubuntu machine, but the connection is so slow that it has no practical use.
I also tried Splashtop, but I was unable to connect to Ubuntu from Windows. Splashtop support were unable to offer the necessary support to resolve the issue (Splashtop for Ubuntu is a Beta version).
As an experiment, I installed the Splashtop client app on an Android tablet. The Android tablet was able to remotely access the Ubuntu machine via Splashtop and the connection is very fast. The Android test suggests to me that there is an issue with the Windows client/Windows settings, perhaps security related, that is causing an extreme slow down of the connection.
Any ideas as to how I could provide a fast remote desktop connection from Windows to Ubuntu for my scenario?
Thanks in advance for any suggestions.
    windows 8.1 pro N
    Digitec
    Intel Core i7 860
    Intel
    4 GB
    AMD Radeo HD 5700
    Windows Security Essentials
Click on RDC choose Show Options, click on Experience tab, experiment with the different options, mine is set to a High-speed broadband connection.
    Win 8.1 Enterprise
    Lenovo
    Intel i5
Thanks for the suggestion, but in this case experimenting with the connection speed options made no noticeable difference.
    windows 8.1 pro N
    Digitec
    Intel Core i7 860
    Intel
    4 GB
    AMD Radeo HD 5700
Fiddle with the ethernet's Speed & Duplex setting?
    Win 8.1 Enterprise
    Lenovo
    Intel i5
RDP will never be as fast as being on the actual machine. No matter what program you use. The closes would be Teamviewer.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
Hi there.
Streaming quantities of video over Wifi is never going to be OK unless you have a Wifi connection of AT LEAST 2 Mbs / sec. RDP sends full screens a lot. You can improve the connection speed if you lower the video quality of what RDP is sending.
The main problem though is likely to be your SLOW WIFI connection. Note - even if your Router can supply a decent WIFI speed your WIFI card might be a LOT slower.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
Thanks for the suggestions/comments. I'll probably give up on XRDP as a solution.
After months of trying, on and off, I finally achieved a Splashtop connection between my Windows PC and the Ubuntu machine. The key change was an iptables command on the Ubuntu side.
For anyone trying to remote into Ubuntu from Windows via Splashtop, there is an excellent guide here:
Cal's Blog: Artist's Essential Tool Guide: How to Make your Android tablet into a Wacom Tablet
In terms of video streaming, I was able to watch a 720p clip for the most part without lagging. This is on the same combination of machines where XRDP was so slow as to be unviewable. Not sure how stable an app Splashtop is for the Windows -> Ubuntu case, so in the longer term I may replace what I've got with a Windows Server/DirectAccess solution.
    windows 8.1 pro N
    Digitec
    Intel Core i7 860
    Intel
    4 GB
    AMD Radeo HD 5700
