Wireless Connection not working post virtual switch
    I installed hyper v on my machine which is running Windows 8.1. Then I created a Virtual Switch on my wireless network. After that, it was not working in the VM but the wireless connection in the host was working fine. After that, when I connected to a different wireless network, it did not work. I deleted the bridge, uninstalled hyper v, but it is still not working. I installed hyper v again, but it is still not working. The wireless connection connects to the wireless network after putting the password, but does not give network connectivity to the internet.
    I need help to get the wireless connection to work again.
    Windows 10 Pro Prieview x64
    Can you post ipconfig /all and your network connections screen. Here is a setup with Hyper-V networking working for both guest and host with Wi-fi and ethernet (you can ignore the disabled VMware adapters). Not the only way of doing it of course
    Here are instructions for uploading screenshots.
    Microsoft Windows [Version 6.3.9600]
    (c) 2013 Microsoft Corporation. All rights reserved.
    C:\Windows\system32>ipconfig /all
    Windows IP Configuration
       Host Name . . . . . . . . . . . . : ADAM-X201
       Primary Dns Suffix  . . . . . . . :
    Ethernet adapter vEthernet (External Wifi Switch):
       Connection-specific DNS Suffix  . :
       Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #3
       Physical Address. . . . . . . . . : 00-24-D7-83-33-94
       Link-local IPv6 Address . . . . . : fe80::59fc:febf:7781:d26a%23(Preferred)
       IPv4 Address. . . . . . . . . . . : 192.168.1.21(Preferred)
       Lease Obtained. . . . . . . . . . : 05 August 2014 12:29:06
       Lease Expires . . . . . . . . . . : 07 August 2014 13:33:31
       Default Gateway . . . . . . . . . : 192.168.1.1
       DHCPv6 IAID . . . . . . . . . . . : 536880343
       DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-57-20-63-F0-DE-F1-37-C1-87
       DNS Servers . . . . . . . . . . . : 192.168.1.1
    Ethernet adapter vEthernet (External Ethernet Switch):
       Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #2
       Physical Address. . . . . . . . . : F0-DE-F1-37-C1-87
       Link-local IPv6 Address . . . . . : fe80::f5c3:90b4:8714:3f12%17(Preferred)
       IPv4 Address. . . . . . . . . . . : 192.168.1.20(Preferred)
       Lease Obtained. . . . . . . . . . : 03 August 2014 18:28:07
       Lease Expires . . . . . . . . . . : 07 August 2014 13:33:26
       DHCPv6 IAID . . . . . . . . . . . : 250666737
    Mobile Broadband adapter Mobile broadband:
       Description . . . . . . . . . . . : Qualcomm Gobi 2000 HS-USB Mobile Broadban
    d Device 9205
       Physical Address. . . . . . . . . : 00-A0-C6-00-00-00
    Wireless LAN adapter Local Area Connection* 3:
       Physical Address. . . . . . . . . : 00-24-D7-83-33-95
    Tunnel adapter isatap.{F66E8199-68A0-42DC-8B72-590855C8282D}:
       Description . . . . . . . . . . . : Microsoft ISATAP Adapter
       IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:1ccf:254f:3f57:feeb(Pref
    erred)
       Link-local IPv6 Address . . . . . : fe80::1ccf:254f:3f57:feeb%9(Preferred)
       Default Gateway . . . . . . . . . : ::
       DHCPv6 IAID . . . . . . . . . . . : 352321536
       NetBIOS over Tcpip. . . . . . . . : Disabled
    Tunnel adapter isatap.{5F842357-49FF-41AC-B92D-39E941F1E760}:
       Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
    Attached Thumbnails Attached Thumbnails network and sharing.PNG   network connections.PNG
Hyper-V Virtual Switch 101: How to create and use Virtual Switches to connect Virtual Machines to Network I will try to make this tutorial as simple and easy to understand as possible. Therefore some examples used might seem to you fellow geeks too simple. However, I ask you to understand that...
Please can you assist with my wireless connection issue. I have just recently purchased the RTL8192CE wireless Lan 802.11 PCI-E NIC and installed it in my shuttle XPC. I am using Windows 8.1 64bit OS. The LAN card is picking up my wireless router fine, but when I enter my router password an...
Hello all, I'm learning windows phone 8, and I want to run the windows phone 8 simulator on my PC ( OS windows 8.1 pro ), but the simulator can not run because it can not create the virtual switch in Hyper-V, and I also can not do it manually :mad:. This is the error when I create the new virtual...
I am running Windows 8.1 Pro with Hyper-V enabled. When I had Windows 8 I could install a Virtual switch with out any problems, since upgrading I can not install a Virtual Switch with External or Internal settings. Not sure if this is relevant or not but when I look at the Ethernet properties...
Hi, I had Hyper-V and Ubuntu running on Windows 8 no problem. I've since done a fresh install to 8.1, and I can no longer create an External Virtual Switch. The button for "Create Virtual Switch" is grayed out when I select "External". I can create Internal and Private switches, but not...
hello when i connect my hp probook 4520s to my sony vpcyb4ajg with Ethernet cable on my Hp wireless disconnects and can not be connected until i disconnect lan cable. but on my sony i have both wired and wireless connections simultaneously hp:win8 x64 realteck Ethernet and atheros wireless sony:...
I have a Win8-64 system hosting a Win8-32 VM. A physical Wifi adapter provides Internet sharing, and a virtual switch provides Internet access to the guest VM via "internal network". However, the Win8-64 host seems to be confused as to which adapter provides Internet access. If I delete the...
