Wireless Connection not working post virtual switch
gokul88
I installed hyper v on my machine which is running Windows 8.1. Then I created a Virtual Switch on my wireless network. After that, it was not working in the VM but the wireless connection in the host was working fine. After that, when I connected to a different wireless network, it did not work. I deleted the bridge, uninstalled hyper v, but it is still not working. I installed hyper v again, but it is still not working. The wireless connection connects to the wireless network after putting the password, but does not give network connectivity to the internet.
I need help to get the wireless connection to work again.
Can you post ipconfig /all and your network connections screen. Here is a setup with Hyper-V networking working for both guest and host with Wi-fi and ethernet (you can ignore the disabled VMware adapters). Not the only way of doing it of course :)
Here are instructions for uploading screenshots.
http://www.eightforums.com/tutorials/2598-screenshots-files-upload-post-eight-forums.html
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : ADAM-X201
   Primary Dns Suffix  . . . . . . . :
Ethernet adapter vEthernet (External Wifi Switch):
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #3
   Physical Address. . . . . . . . . : 00-24-D7-83-33-94
   Link-local IPv6 Address . . . . . : fe80::59fc:febf:7781:d26a%23(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.21(Preferred)
   Lease Obtained. . . . . . . . . . : 05 August 2014 12:29:06
   Lease Expires . . . . . . . . . . : 07 August 2014 13:33:31
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 536880343
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-57-20-63-F0-DE-F1-37-C1-87
   DNS Servers . . . . . . . . . . . : 192.168.1.1
Ethernet adapter vEthernet (External Ethernet Switch):
   Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #2
   Physical Address. . . . . . . . . : F0-DE-F1-37-C1-87
   Link-local IPv6 Address . . . . . : fe80::f5c3:90b4:8714:3f12%17(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.20(Preferred)
   Lease Obtained. . . . . . . . . . : 03 August 2014 18:28:07
   Lease Expires . . . . . . . . . . : 07 August 2014 13:33:26
   DHCPv6 IAID . . . . . . . . . . . : 250666737
Mobile Broadband adapter Mobile broadband:
   Description . . . . . . . . . . . : Qualcomm Gobi 2000 HS-USB Mobile Broadban
d Device 9205
   Physical Address. . . . . . . . . : 00-A0-C6-00-00-00
Wireless LAN adapter Local Area Connection* 3:
   Physical Address. . . . . . . . . : 00-24-D7-83-33-95
Tunnel adapter isatap.{F66E8199-68A0-42DC-8B72-590855C8282D}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:1ccf:254f:3f57:feeb(Pref
erred)
   Link-local IPv6 Address . . . . . : fe80::1ccf:254f:3f57:feeb%9(Preferred)
   Default Gateway . . . . . . . . . : ::
   DHCPv6 IAID . . . . . . . . . . . : 352321536
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{5F842357-49FF-41AC-B92D-39E941F1E760}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
