wireless signal boost to help low signal from cable tv ?
    Windows 8.1 64-bit
    We have a nice signal from the router until about the same time each day. Only cable tv modem is available. Evidently the country neighbors do lots of internet during the afternoon.
    Is there a way to boost the signal coming down the cable line ? The cable tv company has installed new cables from the pole into the house. We have installed all new cables in the house.
    All of the boosters I've seen are for after the wireless signal gets to the cable modem.
    Thanks !
    Jim
    This is a known issue with cable connections. When its not heavily used the signal, speeds can be good, but when it is used heavily things can deteriorate.
    However, how do you know that the cable signal is changing? Unless someone from the cable company has measured the cable signal you don't know that is what is causing the problems. I don't think the signal level on the cable side will affect the wi-fi signal level on that side. They are two separate functions. If your wi-fi signal is deteriorating it has to be some other interference.
    Going back to the cable signal level, I had a change every day around 1PM and the cable modem would lose sync. It turned out to be a bad underground cable between the main cable distribution amp and an intermediate amp in our neighborhood (every thing is under ground). It took a special crew to find and fix this, the tech that came to the house knew "nothing". I had to keep calling everyday when it went bad and after the problem went "chronic" then they got the cable crew on it.
    Windows 8.1 64-bit
    My brother-in-law has worked with the cable company over a couple of years for this problem. The house is in a rural area, and the cable company has said the signal to the house does decrease, they just have no idea how to fix it.
    Can't the cable company boost the signal? They did that for mine as it was low. This was after they fixed the problem I mentioned, they did some testing and found the signal level low. They raised the signal level from the distribution amp.
    I don't know of any amp you could get to boost the cable company's signal level. Even if you could, when you have the problem, it would also be boosting the noise and the signal to noise ration may be affected.
    Central IL
    Linux Mint 17.2
    The OP would have to get a Zero Gain Amp. But the problem is that without the company that owns the CATV plant to do something. They are stuck in a fight that they cannot win.
    Windows 8.1 64-bit
    From what my sister said, they are paying extra for a boosted signal.
    None of the other ISPs like AT&T DSL and a new one I don't remember the name of off-hand are available here.
    Quote Originally Posted by JimJoe View Post
    What they are paying for is more bandwidth, most cable companies sell cheap 3 mb down .5 mb up, then there are tiered up to whatever maximum they support. Mine maxes out at 50 down 3 up. You must be out beyond the Fiber Optics cable and on copper which does lose strength over length from the nearest substation. Not really sure, here after Katrina the cable company rebuilt with fiber optics.
    Your other option would be satellite that's everywhere.
    United States
    Windows 8.1 Pro 64-bit
    Yea, it's not the strength of the signal it is the bandwidth. The cable can only support so much throughput at any time. What you are experiencing is what we satellite internet people live with 24/7.
    Windows 8.1 64-bit
    I think they are paying for 50 megs. There are several splitters in the basement to make connections for the tv and the internet.
    If we do buy a zero gain amp, it will be placed at the first splitter.
    Hafnarfjörður IS
    Hi there
    What about one of those WIFI extenders -- just plug it anywhere you can receive WIFI in your house and it's a ZERO configuration thing -- they really work well on boosting even a tiny Wifi signal.
    I see you really want to boost the Cable companies INPUT signal -- however if you have your Wifi extender right NEAR the input box you can still boost a very weak signal (and you can daisy chain these - so you could have another one if you need to boost yet more further away). - Degradation (i.e speed loss ) is minimal on TWO boosters -- I haven't tried 3 --I don't have THAT big a house or grounds !!!!.
    If your normal network name is DOGSDINNER then you'll see another network with the name DOGSDINNER-EXT. 2nd one if you use more than one is DOGSDINNER-EXT1. You just ensure you connect to that one if the signal is stronger --same password / firewall / port forwarding etc as your "Base" network. Just Plug 'n Go.
    Works brilliantly. Doesn't matter if it's a Cable router or "Classic telephone Broadband" into a bog standard router.
    This is the sort of device I mean -- you could probably source it cheaper than the UK -- UK always hideously expensive PLUS 20% VAT as well !!! but you should get an idea of the device.
    NETGEAR WN3000RP Universal WiF... | WN3000RP-100UKS | £44.99 | Insight UK
    If this isn't the problem then I've mis-understood the question -- from your post I assume that your signal is too weak in some places in your house --this device will boost it enormously.
    Cheers
    jimbo
Page 1 of 3 123 LastLast
No signal after factory reset in General Support
So I did a factory reset on my pc, came back into the room to see that my monitor (tv) said no signal and my small LG monitor was black so I just assumed it was part of the process. After about 6 to 7 hours of waiting it still remained the same, even after restarting and trying many other methods...
Solved wifi signal strength in Network & Sharing
hiii i have a problem to my wifi signal strenght from this afternoon. before i have getting 5 of 5 bars in my wifi signal i used another wifi router for one day . now i trying to connect to my old wifi it was not connecting ,if connect also signal strenght is 2 of 5 my friends getting 5 of...
Wifi Signal Through Wall? in Network & Sharing
How can I go about improving my wifi signal through walls? My router is located in my living room beside my computer. When I'm upstairs my wifi signal diminishes. This is frustrating and I was wondering how I could go about boosting the signal strength when upstairs. By the way, I don't have a...
weak wi-fi signal in Network & Sharing
I am working on a ladie's laptop and I have just taken advantage of the free upgrade to 8.1. Her original complaint is the connection to the internet is unstable. I did notice that she is using the guest account of the assisted care facility she is living in. That account is sometimes less than the...
Hi. Recently I've experienced weird connection issues without any obvious reason. I haven't installed anything in particular as of late, when I woke up one morning I suddenly just had 1 bar with my wireless connection. 1 day before that I reformated my PC though. I have 2 signal amplifiers in...
No Signal Issue in Graphic Cards
Hello, I've come here for help on a problem that I'm having trouble solving. I'm not completely sure how to fix it because I'm not that well experienced with computer tech other than the basics and a bit more, not much. This being said, I present you with my problem. About a week ago I was...
Black screen, No signal... in Graphic Cards
Ever since I installed windows 8 I've been going through a lot of frustrations. First installation went corrupt in someway because of hybrid standby. I put the pc in standby and an hour later when I resumed, games started crashing. I couldn't even produce a dump file for debugging the problem ! ...
