wireless signal boost to help low signal from cable tv ?
  1. #21
    Central IL
    Linux Mint 17.2
    Quote Originally Posted by JimJoe View Post
    My brother-in-law suggested splitting off a cable to my hobby shed. So I wouldn't need WiFi out there.
    I don't see how that would fix the drop out during the afternoon of any usable connection from the ISP, which is cableone.net.
    Again, you are mixing two things up. Your wifi has nothing to do with your cable signal for the modem. Same thing with the signal to the modem & node you are on, has nothing to do with the wifi for your LAN.
  2. #22
    Windows 8.1 64-bit
    Quote Originally Posted by broe23 View Post
    I know it has nothing to do with it.
  3. #23
    Central IL
    Linux Mint 17.2
    Then why keep posting it. I was a little uptight earlier. Due to I was drugged up after getting a Migraine Cocktail at the dr's. Three days of having it. Was getting me on my last nerve. So do not take it as if I was chewing you out.
    Just try and keep the two subjects separated. So that it is easier to follow. It would be nice if we could have a sub thread within a thread, when dealing with this kind of issue.
Page 3 of 3 FirstFirst 123
No signal after factory reset in General Support
So I did a factory reset on my pc, came back into the room to see that my monitor (tv) said no signal and my small LG monitor was black so I just assumed it was part of the process. After about 6 to 7 hours of waiting it still remained the same, even after restarting and trying many other methods...
Solved wifi signal strength in Network & Sharing
hiii i have a problem to my wifi signal strenght from this afternoon. before i have getting 5 of 5 bars in my wifi signal i used another wifi router for one day . now i trying to connect to my old wifi it was not connecting ,if connect also signal strenght is 2 of 5 my friends getting 5 of...
Wifi Signal Through Wall? in Network & Sharing
How can I go about improving my wifi signal through walls? My router is located in my living room beside my computer. When I'm upstairs my wifi signal diminishes. This is frustrating and I was wondering how I could go about boosting the signal strength when upstairs. By the way, I don't have a...
weak wi-fi signal in Network & Sharing
I am working on a ladie's laptop and I have just taken advantage of the free upgrade to 8.1. Her original complaint is the connection to the internet is unstable. I did notice that she is using the guest account of the assisted care facility she is living in. That account is sometimes less than the...
Hi. Recently I've experienced weird connection issues without any obvious reason. I haven't installed anything in particular as of late, when I woke up one morning I suddenly just had 1 bar with my wireless connection. 1 day before that I reformated my PC though. I have 2 signal amplifiers in...
No Signal Issue in Graphic Cards
Hello, I've come here for help on a problem that I'm having trouble solving. I'm not completely sure how to fix it because I'm not that well experienced with computer tech other than the basics and a bit more, not much. This being said, I present you with my problem. About a week ago I was...
Black screen, No signal... in Graphic Cards
Ever since I installed windows 8 I've been going through a lot of frustrations. First installation went corrupt in someway because of hybrid standby. I put the pc in standby and an hour later when I resumed, games started crashing. I couldn't even produce a dump file for debugging the problem ! ...
