Weird Connection Problems - Help Needed
    Please excuse me in case I don't do something right. I don't know if I am even posting this in the right section. I only created this account to help my friend solve her the problem she is having with her internet.
    Basically, whats happening is, it says she is connected to the internet, however, it won't load any site. We've attempted this on Internet Explorer, Firefox, and Google Chrome. The weird thing is, we have found that she can connect to sites by using the site's IP, but not with the actual address. Also, her Skype is working perfectly fine with the connection. Its just, web addresses that cause a problem. There isn't much more information I can give, because I don't know what else is needed. This started on Friday, 5/9/14.
    If you need to know this, she is running on Windows 8 and her computer model is a Satellite c55-A and the processor is intel(r) core(TM) i3-3120m cpu @ 2.50ghz 2.50 ghz. The manufacturer is Toshiba.
    Also, this was a problem she encountered on any router she connected to.
    I would greatly appreciate any help given, helpful or not. However, if we can not get this solved, she will resort to attempting to restore to factory settings.
    Please.
    Open a cmd prompt with admin privileges and type ipconfig /all post it in this thread so we can see particulars of your connection.
    It sounds like a DNS problem. Skype handles DNS differently so that explains why it's working.
    You might start by resetting the router or modem as the ISP's DNS servers appear to be jammed up.
    Quote Originally Posted by DMHolt57 View Post
    Here you go:
    Microsoft Windows [Version 6.2.9200]
    (c) 2012 Microsoft Corporation. All rights reserved.
    C:\windows\system32>ipconfig /all
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : Trinity
    Ethernet adapter Ethernet:
    Description . . . . . . . . . . . : Qualcomm Atheros AR8162 PCI-E Fast Ethern
    et Controller (NDIS 6.30) #2
    Physical Address. . . . . . . . . : 00-8C-FA-79-ED-32
    Wireless LAN adapter Local Area Connection* 11:
    Physical Address. . . . . . . . . : A4-DB-30-69-D0-3E
    Wireless LAN adapter Wi-Fi:
    Description . . . . . . . . . . . : Realtek RTL8188E Wireless LAN 802.11n PCI
    -E NIC
    Link-local IPv6 Address . . . . . : fe80::5f9:a138:b6de:9b2e%14(Preferred)
    Autoconfiguration IPv4 Address. . : 169.254.155.46(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.0.0
    Default Gateway . . . . . . . . . :
    DHCPv6 IAID . . . . . . . . . . . : 363125552
    DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-55-40-E6-A4-DB-30-69-D0-3E
    DNS Servers . . . . . . . . . . . : 209.62.192.1
    Tunnel adapter Local Area Connection* 13:
    Description . . . . . . . . . . . : Microsoft 6to4 Adapter
    Tunnel adapter isatap.{D2DE7642-CD2F-4413-8931-29B492458729}:
    Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
    Hello?
    Hello Blaise, have you tried resetting the modem or router yet?
    You can usually just unplug the modem for a few minutes to accomplish this.
    Quote Originally Posted by chev65 View Post
    We've tried many times to no success. As I've said in the main post, this happens on any router she connects to, not just hers.
    No connection with any router ok, lets try the most likely problem first. Unzip and run the file below, it will reset everything related to the network stack and then it will reboot your machine automatically.
    After the machine reboots perform another ipconfig/all and post the results here please.
    Weird Connection Problems - Help Needed Attached Files
    Sorry it took awhile. Here you go.
    -E NIC
Page 1 of 2 12 LastLast
Some weird problems lately in General Support
sfc /scannow = No problems Dism = No problems System fully updated RAM diagnostic and Checkdsk come up clean. Problem 1: "Invalid Registry Entry" error when opening files: Has happened with mp4's and PDFs so far. Reboot or login/out fixes it temporarily. My PC is on 24/7 so it will...
Network Connection Problems in Network & Sharing
A couple of days ago when I opened IE I got an error message saying I was not connected to a network. I was, with internet access, and I knew this was okay as my partner was sitting 3 feet away using the internet on his machine. I eventually resolved the issue by doing a System Restore but the same...
Hello. About a month ago I saw for the first time the username system on Windows 8. I have never created as much I remember a username in my computer. However, suddenly this new thing popped before my eyes. But it was'nt a request or something reasonable that Windows noted me. It claimed that my...
Okay so my laptop is a Toshiba Satellite C55D-A-13U, runs Windows 8.1 and has some serious issues. It's a month old and has 8GB of RAM, AMD A6-5200 APU, Radeon HD Graphics and 1TB hard drive. And also it barely works at all, which just doesn't make any sense. My problem is that when I'm on the...
Weird problems after restoring Windows 8 in Performance & Maintenance
Hello, I had some heating problems with my laptop and it turned out that it is the hard disk and I had to replace it. To keep my configured Windows and all applications I have made a backup which I installed on the new hard drive. Now I have some issues with my Windows that I can't resolve -...
Solved Browser Connection Problems in Browsers & Mail
Hi guys, I have just upgraded from Windows 7 Home Premium to Windows 8 Pro and am extremely frustrated with my browser connection. I say browser rather than internet as that seems to be running fine with feeds on the start screen and uploads/downloads continuing in the background with no issues...
Internet connection problems in Network & Sharing
Hello, Firstly I'm no computer expert atall so I might be showing my ignorance here. I've just got a Sony Vaio with windows 8 which initially worked ok, but now won't connect to the internet atall, either with the ethernet cable or on wi-fi. Windows diagnosis does nothing. It was working...
