Weird Connection Problems - Help Needed
BlaiseSilver
Please excuse me in case I don't do something right. I don't know if I am even posting this in the right section. I only created this account to help my friend solve her the problem she is having with her internet.
Basically, whats happening is, it says she is connected to the internet, however, it won't load any site. We've attempted this on Internet Explorer, Firefox, and Google Chrome. The weird thing is, we have found that she can connect to sites by using the site's IP, but not with the actual address. Also, her Skype is working perfectly fine with the connection. Its just, web addresses that cause a problem. There isn't much more information I can give, because I don't know what else is needed. This started on Friday, 5/9/14.
If you need to know this, she is running on Windows 8 and her computer model is a Satellite c55-A and the processor is intel(r) core(TM) i3-3120m cpu @ 2.50ghz 2.50 ghz. The manufacturer is Toshiba.
Also, this was a problem she encountered on any router she connected to.
I would greatly appreciate any help given, helpful or not. However, if we can not get this solved, she will resort to attempting to restore to factory settings.
Open a cmd prompt with admin privileges and type ipconfig /all post it in this thread so we can see particulars of your connection.
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
It sounds like a DNS problem. Skype handles DNS differently so that explains why it's working.
You might start by resetting the router or modem as the ISP's DNS servers appear to be jammed up.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Here you go:
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Trinity
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Qualcomm Atheros AR8162 PCI-E Fast Ethern
et Controller (NDIS 6.30) #2
Physical Address. . . . . . . . . : 00-8C-FA-79-ED-32
Wireless LAN adapter Local Area Connection* 11:
Physical Address. . . . . . . . . : A4-DB-30-69-D0-3E
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Realtek RTL8188E Wireless LAN 802.11n PCI
-E NIC
Link-local IPv6 Address . . . . . : fe80::5f9:a138:b6de:9b2e%14(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.155.46(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 363125552
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-55-40-E6-A4-DB-30-69-D0-3E
DNS Servers . . . . . . . . . . . : 209.62.192.1
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Tunnel adapter isatap.{D2DE7642-CD2F-4413-8931-29B492458729}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Hello Blaise, have you tried resetting the modem or router yet?
You can usually just unplug the modem for a few minutes to accomplish this.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
We've tried many times to no success. As I've said in the main post, this happens on any router she connects to, not just hers.
No connection with any router ok, lets try the most likely problem first. Unzip and run the file below, it will reset everything related to the network stack and then it will reboot your machine automatically.
After the machine reboots perform another ipconfig/all and post the results here please.
  • IPResetALL.zip
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Sorry it took awhile. Here you go.
-E NIC
No change from what I can see here. Have you done any virus scan's lately?
Which anti virus software is installed on this machine?
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Did you run the rest file?
It's required that you answer the questions and confirm things here. :)
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
We are just going to save everything important and restore factory settings. I appreciate you guys trying to help though. Thanks.
have you tryed opening the cmd and typeing in ipconfig /flushdns
If this does not working try right clicking on the network icon on the bottom right and open network and sharing center click change adapter setings right click on the device you are useing and click properites go down to ipv4(Internet protocol version 4) and click properites and see if it is defined auto or not
    Sony Vaio VGN-CR510D
    Intel® Core™2 Duo Processor T5750 @ 2GHz 2M Cache 667 MHz FSB
    Sony
    3GB
    Intel Graphics Media Accelerator (GMA) X3100
    Internet explorer
    Norton
