Wifi Auto-Connect to two-wifi APs, problem
    Hi All,
    Win8:
    I have two wifi APs in the home and I have it all set up so that one is the Internet by cell phone tether and the other is the cabled network via the router wifi.
    Works just fine - except.
    On wifi 1, Internet I have it set for "Connect automatically" which at boot up it does.
    On wifi 2, Network I also have it set for "Connect automatically" which at boot up it does NOT do. I have to go in and connect manually even though the "Connect automatically" is checked.
    It seems win8 sees "Connect automatically"and does it but then stops checking other connections. Probably a "feature."
    Is there some way to force both "Connect automatically" to happen?
    Thanks
    There is a group policy setting for this, but even if both are connected you will only be using one of those connections at a time.
    Attached Thumbnails Attached Thumbnails Group Policy for using two connections at once.PNG
    Thanks, I explained that poorly. As well as two APs I also have extra wifi adapters on the PCs I need to access both Internet and LAN without plugging into the LAN. I have since made it work and both wifi are connected. I started out with the information on site linked below, then went from there.
    This link describes for setting up a single wifi, but I duplicated the process for the second adapter.
    win8. Can't automatically connect to Wifi? Solved | Firebird - VB.net
    So, now I have it working for the win8 machine but the win7 still needs some work as it is only connecting to one at a time even though there are two different wifi channels available and the Group Policy has been set.
    Considering the link you posted shows a wired connection I now have no idea what this post is about but the Group Policy setting does allow Windows to pick up multiple connection at start up.
Hi there, I have a new problem that has just cropped up today. I am no longer able to connect to public wifi or my phone's wireless hotspot. My laptop either will not connect or connect with limited access. It has connected without issue in the past and as soon as I returned home it connected to...
Hello, I have tried for a few days to fix this problem myself but now must ask for help. I can connect to other wifi (my parents house, friends house, etc.) no problem. For some reason my home router (Netgear N300) doesn't like me much and all attempts to connect have failed. Also, I have a...
BSOD when trying to connect to wifi in BSOD Crashes and Debugging
I have this middle line DSL through AT&T Uverse. My personal pc connects wirelessly to the router which is hooked up via ethernet cable in the living room to my house pc. At night sometimes the router will seem to half crash, and when I wake, I find a limited wifi connection. On trying to...
Hi All, After much trawling on the net, i have finally given in and am seeking direct help. When i choose the connection's icon from the task bar, to connect to wifi, the connection side bar appears for a brief instant and disappears. At the moment i can connect to the network in my home,...
I prefer to keep my home WiFi network from public view by disabling the SSID broadcast, i.e "hiding" the network. With two modem/routers (a Belkin Play Max F7D4401 ADSL modem/router and now a Cisco EPC2325 DOCSIS modem/router) on two computers (home-built desktop and Acer TM8172T notebook),...
Cannot connect to WIFI in Network & Sharing
I have a brand new Lenovo Ideapad Z585. It has a Broadcom Wireless adapter that will not connect to my home wireless network. I have tried everything I can think of to get it to connect to my Netgear router. When I run Windows diagnostic tools it tells me that there is a problem with the...
hi, i have an alienware m15x r2 which i recently upgraded to windows 8 through a clean install. everything works great except for the wireless, and i cannot for the life of me figure out whats run. ive tried about 10 different wifi points on campus and tried wirelessly tethering tommy phone and...
