Intermittent wireless connectivity problems
    Windows 8 Pro
    I have a PC and a tablet, both of which have Windows 8.1 installed, and are regularly updated. I prefer using the wireless connection on my PC, although I do have an active wired connection. Is there a setting somewhere that disables the wired connection automatically when the wireless is active, and also switches back to wired if the wireless disconnects? I have looked into Group Policy Editor at the wireless and wired LAN settings under Network Connections, but don't see any setting to do this automatically.
    It's depend on your network card driver. for example in Intel network cards you can do this with check this option
    Windows 8 Pro
    Confused
    exactly where do I find the page you showed me. I thought it would be in Device Manager/Network adapters/LAN adapter or Wireless adapteer
    Central IL
    Linux Mint 17.2
    Quote Originally Posted by leathrpaws View Post
    That is the Administrator page for Proset tools. Only installed, if you select that feature, when installing Proset tools for an adapter with a Intel chipset.
Hi, I'm using Asus N550JV (on latest updated Windows 8.1), which includes integrated Atheros wireless network Adapter. The laptop keep losing Internet connectivity many times. The following behavior is causing the laptop to lose its Internet connectivity on a random basis: a. downloading large...
:confused:HELP:cry: with Toshiba Satellite C-50A5177WM Laptop. The problem I am having is that wireless connectivity becomes intermittent while trying to browse websites, Web pages just lag an stop loading altogehter I use a usb Wireless Adapter to be able to navigate but even then it also...
Hey all. I've browsed a number of prior threads with similar issues seeking out a resolution, and have had no luck, so I decided it was time to go direct. For about a week now, my computer has had intermittent internet access. It'll work anywhere from about 10 seconds to 45 minutes or so before...
limited wireless connectivity in Network & Sharing
Hello form Macedonia, dear friends. Could someone of you please help me? I have problem wit limited wireless connectivity on my laptop (Samsung) but also on my iPhone 4 and my wife`s LG optimus 5 duo all at the same time. I changed yesterday my router speedport which performed wireless...
Hi all, Every 5 - 20 minutes on my CenturyLink home internet, I get Limited access internet only. Troubleshooting or turning on / off airplane mode typically solves it. I tried Device Power Management (not allowing it to turn off the adapter to save power) but that hasn't helped. I disable /...
Hi, I have quite much trouble with my WiFi when I'm trying to connect to wireless networks. There are like 3 or 4 kind of problems, which occur at quite random intervals, and are really annoying. My problems: I start my windows 8, and try to connect to a wifi, but it says it cannot connect...
i have a sneaking suspicion that i'm inadvertently causing a function action to shut off wireless. i'm in tablet mode so not sure. any ideas? - System
