Network Wifi Connection Problem
    Hi,
    So The Problem is that i changed my SSID on my router because i have created a hotspot by mistake with a same
    SSID of my router Wich is named DJAWEB and it was annoying so i changed my router`s SSID To Djaweb it worked fine but i still see the other SSID (DJAWEB) of my computer hot spot and i couldnt remove it or forget it by using the only way wich is(image attached):
    so any ideas how to turn off hotspot(network sharing) and remove that annoying SSID from my wifi connection (image attaced):
    To manually turn the Hosted Network off, enter the following into an elevated command prompt:
    netsh wlan stop hostednetwork
    You can also disable the Msoft virtual WiFi adaptor in Device Manager by going to the View tab then enabling "show hidden devices" you can then right click the virtual adaptor to disable as shown in the pictures.
    How to Delete or Forget Wireless Network Profiles in Windows 8.1
    Attached Thumbnails Attached Thumbnails Screenshot (4).jpg   Screenshot (5).jpg
    Quote Originally Posted by chev65 View Post
    You can also disable the Msoft virtual WiFi adaptor in Device Manager.
    Hi,
    i Couldnt find Microsoft virtual WiFi adaptor in Device Manager.but i did the first one you told me
    Central IL
    Linux Mint 17.2
    You need to also go into the registry and delete any entries from it. See Delete Wireless Network Profiles in Windows 8(.1) - Microsoft Community Also some good information at http://www.thesysadminhimself.com/20...windows-8.html
    Do a "netsh wlan show all" in a Command window as Administrator, and you will pull all of the wifi profiles on your machine.
well i already use a program From Baid* i want to play game with friend, so they connect their laptop to my WiFi from a Program they laptop shows it already connected, so they launch the game and create a room at Multiplayer, well i have 2 friend so we have 3 laptops here, included mine my...
Hi All, at my home, i got internet connection from coaxial to my modem.. i had tried couple time to hug up internet from Modem through Wan port to my laptop network port by RJ-45 but the internet status said not working(yellow sign at the network icon on task bar". I tried 3 of my laptops,...
I just bought a new computer and it has a wireless adapter already plugged in the USB internally. It is a Realtek RTL8811AU Network Adapter. I am running off wifi on other devices in my home right now and the connection is perfect for those. When reading the reviews for my computer, which is this...
Is there a way to setup network profiles or something so that when I bring my Surface Pro to work and connect to the wireless network there it will use the static ip address I have but when I disconnect and then connect to my home wifi it will go back to DHCP? On my MacBook Pro I can go into the...
Hone Network WiFi Problem in Network & Sharing
Hi Guys Just wondered if anyone could assist. Plan skybox - ethernet - router A (access point) - wifi - Main router - pc? - internet. trying to set up router A with laptop BUT can not get to talk to Main router and hence internet. Laptop connects to router A and can access setup page...
Hey people :) Here's my problem. I use the windows 8. Accidentally i disabled my wi-fi connection (like in the picture im doing with the other connection), and since then, i wasnt able to get it able again... 15280 Now, as you see in the same picture, the Wifi connection, as well as the...
I am trying to update my home computer from Windows 7 to Windows 8. I already purchased windows 8 for download but I encountered a problem when trying to download. When running the install the program states I need to uninstall Intel(R) Pro Network Connection 12.1.11.0. However if I uninstall...
